1.8 Northwood Overclocking
Add Your Comments
I can show you my results with the Northwood 1.8a.
This batch overclocks easily to 2.4 GHz at stock voltage.
I’ve been running mine all day with the Intel heatsink and done endless loops of 3DMark2001 and Seti workunits.
I have attached all the screenshots and a scan of the box code.
(Note: I did the cropping.–Ed)
Arith
MemBand
MM
P418A
Prodlink
I have attached all the screenshots and a scan of the box code. It seems that early thoughts on this chip are way off the mark. It is a great overclocker so far.
(Ed.note: While it’s good to have confirmation that the 1.8GHz will hit 2.4GHz without much hassle; it still seems that the 2.0A and 2.2 can reach higher total
speeds than the 1.8. The advantage of the 1.8 is that it can run at 133Mhz without extreme measures, while the others can’t.)
Dylan Williams
Leave a Reply
