Watercooling Kit Test – Joe
SUMMARY: Outstanding performance.
The good guys at 1A-Cooling were nice enough to send a sample of the Blacklord 240 watercooling kit to test. This kit features an external radiator assembly cooled with 2 120 mm fans.
The waterblock ships without the fittings screwed in – easy enough to do.
The base of the fittings includes a neoprene “O” ring to make it watertight. Tubing is attached by unscrewing the knurled ring, slipping it over the tube and tightening. To avoid the tubing from twisting as it’s tightened, moisten the tubing with a little water – it’s just enough lubricant to avoid twisting.
Note the dimple between the fittings – this is where the screw mount rides on the block.
A look inside the waterblock reveals a fairly restrictive design:
It looks as if there is a center channel that then splits out to two exhaust channels. The base is interesting:
It appears that there is a center copper strip between a brass base.
The mounting options cover every conceivable CPU; In addition, mounting force is centered over the CPU:
This is much preferred over other techniques, as the force is directed precisely where it’s needed without the possibility of canting the waterblock slightly off the die; you would be surprised at how much this degrades performance. Included with the kit is a small torque wrench:
A very nice touch! Slip it over the mounting bolt and adjust – I set it to 30 kg in testing.
The radiator is large:
It’s powered by two 120 mm fans spinning at about 2200 rpm; I found noise to be busy – 62 dBA.
Tubing size is 8 mm ID:
The kit ships with a small vial of algaecide, brackets and screws for assembly.
The waterpump is a good one – an Eheim 1048:
This is a nice package that features an integrated reservoir; this is well constructed, using all metal parts. Note that there is no relay to turn on/off the waterpump with the system – adding one is not all that difficult (an example here).
Unfortunately, the sample sent to me was a 230 volt pump – I substituted a 120 volt Eheim 1048 waterpump with an integrated reservoir from another kit for testing purposes.
The Blacklord 240 was tested using the CPU Die Simulator. I found fan noise at about 62 dBA (measured 8″ from the fan’s intake) – not excessively noisy but noticeable; consider adding a rheostat for noise control.
| Kit |
Die Temp
Ambient Temp
Delta
C/W
| Blacklord 240, 2218 rpm, 62 dBA¹ |
31.9
21.0
10.9
0.16
¹Measured 8″ from the fan’s intake; manufacturer dBAs usually measured at 1 meter.
C/W = Delta / CPU Watts
