Noctua P14 and P12 PWM's
Three PWM Fans from Noctua
Add Your Comments
Talk about an embarrassment of riches! In short order, Noctua banged out a bunch of PWM fans at the end of 2011. I thought you’d like to look at three of them. Here are the first two:
Noctua NF-P14 PWM and NF-P12 PWM
What’s that you say? These fans look just like Noctua’s old fans? Well of course they do. They are our faithful old friends, the NF-P14 and the NF-P12 with PWM circuits. Apparently, it took Noctua engineers years to figure out how to make PWM PCB’s the Noctua way, which is essentially perfect. I’ll tell you how well they did later when I test these fans.
So let’s look at the third fan, the NF-F12 PWM:
Noctua NF-F12 PWM and box
Those vanes are called stators. When a fan’s output is blown through properly designed stators, not only does it focus the airflow but it increases the static pressure. Noctua’s PR guy tells me I shouldn’t expect more CFM from this fan, or any better cooling if we put it on an NH-D14, their top cooler. The NF-F12 PWM is designed to push more air through constricted settings, like radiators. But for us air coolers, higher static pressure can overcome the restrictive effects of air filters. That means the NF-F12 PWM should be an excellent case fan.
The Fans
Well, let’s start with the basics: the NF-P12 PWM and the NF-F12 PWM are being sold at retail. The NF-P14 PWM is not. It only comes with Noctua heatsinks, and you can’t buy it separately. So, you’ll see the NF-P14 PWM a little later in the article.
NF-P12 PWM Nine-Bladed Fan
Noctua NF-P12 PWM and its box
NF-P12 PWM and accessories
 The nine-bladed NF-P12 PWM comes with a few accessories:
  • On the left you can see a PWM Y-cable. Both limbs have the ground, 12 V and PWM control lines, but only one has an RPM reporting line. Like the 3-wire that came with the original NH-D14, this Y-cable will not confuse the motherboard with two sets of RPM signals.
  • Then comes the 30 cm (~1 ft) extension cable. This makes up for the fan’s cable only being 20 cm long (eight inches). Most of us don’t need a longer fan cable, but for those who do, Noctua has you covered.
  • There are four “Vibration-Compensators.” They come with all Noctua fans, and you are supposed to use these to fasten the fan to a case. Let me know if you can make them work. I want to know how.
  • There is a packet of four standard fan screws, not shown.
  • In front of the fan is the Low Noise Adapter (L.N.A.), part NA-RC6. It will drop the fan speed from 1300 RPM to 900 RPM — and still lets the PWM signal through.
We’ll do some testing further on. But for now, we have the product page.
 NF-F12 PWM Seven-Bladed Fan
Noctua NF-F12 PWM and accessories
You can clearly see the cushioned corners made of silicone rubber, designed to attenuate vibrations. The diagram on the inside cover of the box illustrates the stepped inlet design, the inner surface dimples, the improved SSO bearing, all you would want to know about this new fan. It even explains that the stators are not evenly spaced around the fan’s circumference. On the next page of the box (as weird as that sounds) you are told the eleven stators are angled at 33°, 35°, 35°, 37°, 31°, 32°, 31°, 32°, 32°, 31° and 31°, going clockwise from the top. There is also a chart that shows how moving the spacing of these stators really reduces some noise spikes. Of course, with no numbers on the chart we don’t know how much difference the irregular spacing makes. But it should mean that we hear less of a tone from these fans.
Here is the Product Page.
The accessories:
  • 30 cm PWM extension cable — check.
  • Screws — check.
  • Low Noise Adapter — Hey! This one is an NA-RC8. It only drops the fan from 1500 rpm to 1200 rpm. Hmm. On the D14 the RC8 dropped my P14 to 900 RPM. The RC6 dropped it to 700 RPM. So they do have different resistances.
  • The Y-cable is the Noctua now-standard (and excellent) PWM Y-cable — check. Note that all the cables are beautifully sleeved.
  • And finally the Vibration-Compensators.
Testing
Open-air Testing
First, I plugged them in to my PSU’s 12 Volt line to learn what their max speeds were. Then I poked a grounded line into each fan’s PWM channel. All three fans went to zero. This is unusual among PWM fans. Most go to some minimum speed. And then on most PWM fans you see a variety of duty-vs-rpm curves where the rpm increases as the “duty” increases (the term “duty” in PWM situations means the percent of time the PWM line is providing 5 Volts to the fan). These curves are often non-linear. We will see what the Noctua curves look like.
I plugged the fans into my new Zalman PWM controller (link). I could then provide approximately 25%, 50% and 75% PWM duty to each fan. To observe the speed of the fan, I sent the RPM line to a fan header on my motherboard and recorded the number shown by ET6, the motherboard utility that measures such things. I also recorded the sound pressure level with my tried and true SPL meter from 10cm directly in front of the fan. Subtract 20 dB and you have the equivalent sound pressure level of what you would hear one meter away.
  Noctua fans   PWM duty  Noctua
 Fan measurements  -0-   ≈25%  ≈50%  ≈75%  100%  Rating
  NF-F12 PWM RPM  -0-  363  757  1123  1470  1500
  NF-F12 PWM SPL  -0-  <12 dBA  15 dBA  22 dBA  28.5 dBA  22.4 dB
 NF-P12 PWM RPM  -0-  330  686  992  1271  1300
  NF-P12 PWM SPL  -0-  <12 dBA  13 dBA  19 dBA  25 dBA  19.8 dB
  NF-P14 PWM RPM  -0-  381  721  991  1225  1200
  NF-P14 PWM SPL  -0-  <12 dBA  17 dBA  24 dBA  29.5 dBA  19.6 dB
First of all, none of the fans clicked at any speed. That’s amazing. Mission One accomplished.
The next thing to note is that, within the broad limits available to test the RPM and the PWM percentage (“duty”), the speeds of these fans scaled linearly with the PWM duty. Again, that represents hard work on the part of the engineers working for Noctua.
Finally, they were quiet. Even the F12, spinning at 1470 RPM, was quiet. Bravo! Note that some of the SPL results could have been quieter than measured. Twelve dBA is the lower limit of the equipment and the environment. Also note that discrepancies between what manufacturers measure and what we measure are normal. More important is that the speeds and sound pressure levels for the PWM P12 and P14 are the same as for their non-PWM predecessors.
NH-D14 Testing
Now it’s time to saddle up and test these fans on the NH-D14. Now, where’s that NF-P14 PWM? Ah! Here it is:
NF-P14 PWM with P12 box
Since the P14 PWM doesn’t have its own box, I put it in front of the P12’s box. They are similar fans, after all.
I have previously posted the particulars of my test rig. It is a fine test of high performance heatsinks and their fans. So how well did these do?
The plain P12 and P14 (stock setup) hold the hottest core of the CPU to a net temperature (CPU core temp minus ambient temp) of 51°C at a cost of 26 dBA, measured from the side. The PWM P12 + P14 hold the net temps to 50.6 °C at a cost of 26 dBA. These numbers are essentially identical, which is astonishing. Those PCB boards for the PWM fans produce the same results as the non-PWM fans. Getting those fans dialed in to work the same as the old fans took a lot of work.
Now, let’s have some fun. Let’s put an NF-F12 PWM on the front as push fan in place of the P12. The F12 + P14 PWM combination holds the net temps to 50.5 °C with an SPL of 26.5 dB, despite the fact that the F12 was running at 1477 RPM, more than 200 RPM faster than the P12. That was hard enough to believe that I ran the test again: 50.4 °C this time.
Here is the chart:
RPM, SPL and TOA for D14 with Noctua PWM fans
So, not only do the PWM fans essentially replicate the non-PWM fans, the F12 cools the same as the P12 on the D14. Is this coincidence or engineering? One thing I did note was that the air I normally feel spilling out the sides of the fin stacks of the D14 (and demonstrate with a tissue) was absent in the front fin stack when the F12 was mounted there. It appears that the F12’s airflow truly is focused, as advertised.
Vibration Compensators
The NF-P14 PWM and the NF-P12 PWM are worthy successors to their non-PWM versions. And the advent of these PWM fans means that the last problem with the NH-P14 has been solved. We have also seen that the NF-F12 PWM is a fine fan in its own right. You water coolers can use this on your rads, and we air coolers will put it in our cases.
I won’t use the Noctua “Vibration-Compensators.” The Noctua pegs are a very tight fit on the F12. I was afraid to put one in because I wasn’t sure I could get it out again without breaking it or cutting it off. The main problem is the length of the pegs: they are way too short. Unless you are willing to grab the end of one of these with needle nosed pliers you will have trouble pulling them into position. It is hard to get your fingers into the fan’s corner to pull the peg through. Look at this:
NF-F12 PWM and Noctua vibration isolator
That picture shows you where the peg will end up once it is in. You can see that grabbing enough of it to pull it to that position might be quite the task. What you need is a longer peg, like this one:
NF-F12 PWM and Nexus vibration isolator
This peg is long enough that you can grab it on the other side of the fan from the case. You won’t have to try to get your fingers into some far corner and struggle to get the peg in. This is a small issue. Just ignore these “Vibration-Compensators.” When you buy the fan, get aftermarket pegs.
Conclusion
In conclusion, these are solid fans:
  • They are quiet
  • They do not click
  • They perform well
  • Their PWM/RPM curves appear to be linear
These fans include excellent accessories:
  • Their power cables are just the right length
  • If you need a longer cable, one is included
  • They include a PWM Y-cable that is well-designed, and not excessively long
  • All cables are handsomely sleeved
Thanks to Noctua for supplying these PWM fans.
ehume
Leave a Reply
Discussion
  1. What?? Who is making fools judgements on the cuts? No one even mentioned them except in the article when he explained them a bit.
    I'm not sure what your game is, but if you came here to just start arguments, let me assure you that your tenure at this forum will be cut very short.
    Start paying attention to any detail will help you not to make fools judgments the strange cuts in the wings of every noctua fan are helping to speed up the air and keeping focused better in here you will see how this cuts are working:
    http://www.noctua.at/main.php?show=nine_blade_design
    in here you will see the focused airflow of a noctua fan compared with any conventional fun
    http://www.noctua.at/main.php?show=focused_flow_system
    If you don’t believe noctuas links I have here for you a test from Silverstone
    http://www.youtube.com/watch?v=rjL6KdV2ag8&feature=related
    They tried to copy Noctuas focus flow system just because it brings results even when they operate in low speed!
    You can also see the new Zalman_CNPS12X with 3 large fans tested resolts in here:
    http://www.benchmark.pl/testy_i_recenzje/Test_Zalman_CNPS12X_-_chlodzenie_procesora_na_3_wentyle-4145/strona/15695.html
    I simply say Noctua, there is no substitute.
    My opinion is that these fans are overpriced. All you really get for your money is higher snob-appeal based on the name. Long-life bearings, OK, but you'll be rebuilding & tossing fans out before they have a chance to wear out, so why bother?
    1300 rpm is slow. Any fan turning that slow is gonna be quiet. Might as well go with some Blademasters and a properly tuned install of Speedfan and you'll have quiet idle and performance cooling when you need it.
    PWM Delta FTW hehe
    Its hard to find a better fan for flow rate, pressure and durability than a delta...for all that performance you get some noise but its not too bad IMHO
    I reviewed a NF12-F for funkykit, it's my daily driver fan now.
    The low rating speaks more of Noctua's honesty than it does it's poor airflow compared to other fans. Most fans are wildly over rated, I think I actually believe Noctua.
    Billys Gates
    Yeah I really don't get why they need to have these colors, even though fans are hidden inside and mostly out of view it would be nice to get them in other colors as well. The rubber mountings however are a nice touch.
    Well, I guess it's to go together with ASUS The Ultimate Force motherboard line. :rofl:
    Actually, they do look nice together.
    One feature I really like on the NF-F12 PWM fans is the soft rubber on the corners to help cut vibration noise down. The rubber corner inserts are removable too, in case you run into a situation where they would interfere with mounting somehow. But I had no problems mounting them on the heatsink I am presently testing with the rubber corners mounted on the fans.
    And synphul, I have to agree with you about the Noctua fan colors. The beige/brown scheme is particularly ugly in my opinion too I wish they had chosen a more nuetral color scheme that doesn't clash so badly with most anything else you put inside your case.
    synphul
    Nice review. Definitely see what you mean about the rubber mounts, way too short. Depending on the type of material (some are soft silicone, others feel like parts of a radial tire), looks like bleeding fingertips or broken fan corners are sure to follow. Would like to give them a try, but I just can't get past that distinct Noctua color scheme. That beige/brown is sure to match..nothing except maybe another Noctua? lol
    The fans are too tough to break with mere rubber pegs, and those pegs won't cut your fingers. You just won't get a good grip.
    Back when I still thought I needed an exhaust fan I tried to mount an NF-S12B in the back of my case. I couldn't do it with the Noctua pegs. I ended up using double-ended pegs for the fan corners away from the side panel (that was before I discovered the isolators linked in the article). The problem with the double-enders was that the rubber was very stiff; they had to be cut or broken off the fan. Where the NF-F12 differs from previous fans it that its screw holes seem a bit smaller -- smaller enough that I don't want to risk putting a Noctua peg in. The Nexus pegs are much softer.
    I have a couple of the NF-F12 PWM fans I received along with a heatsink from them I am presently testing, ehume. I haven't crunched the numbers yet (still collecting data points), but right off the cuff I'm not seeing any performance difference between them and the NF-P14 fans that come with the heatsink. They are very well built fans though and I might swap them out on a watercooled rig for the Swiftech fans on the rad on that system and see what temps do. The Swifty fans are much noisier than the NF-F12 PWM fans.
    I suppose I'll have to post comparison data with other fans. They are quiet and compare well with other fans cooling heatsinks like the NH-d14.
