3R System Poseidon WCL-03
Kit test – Joe
SUMMARY: Entry level kit with very modest performance.
WCL-03
The good guys at 3R System Co. were nice enough to send a sample of the Poseidon WCL-03 watercooling kit. The kit features a waterblock with an aluminum base:
Base
The base is adequately finished.
The kit includes:
  1. Aluminum waterblock with integrated pump, aluminum radiator and water tank
  2. Fan bracket with low noise fan
  3. AMD / Intel P4 CPU mounting brackets and screws
  4. Thermal grease
  5. Mounting pad
  6. Manual
Key Features:
  • Magnetic Pump integrated with waterblock
  • Pump Head: 400 mm (16 inches)
  • Pump Flow Rate: 500 ml/min (about 8 gal/hr)
The kit features an integrated waterblock/pump arrangement:
Pump
Pic courtesy of 3R System
What looks like a fan is a magnetic flywheel which drives the impeller inside the waterblock. As you can see from the specs above, this is a very low flow system – about 8 gallons/hr (3R System spec); note also that the system’s head is minimal – 16 inches.
The radiator features a plenum on both sides and tubes between:
Rad
The black item on the front allows mounting the radiator to a standard 80 mm fan hole pattern.
The WCL-03 inlcudes a separate reservoir
Tank
which clips onto the top of the radiator.
The parts that ship with the kit
Parts
allow mounting options for AMD Socket A and Intel P4 CPUs.
The 80 mm radiator fan is very low noise – it turns at a leisurely 1400 rpm, with low cfms as a result
  1. 3R System Poseidon WCL-03Cu
  2. 3R System Poseidon WCL-02
  3. BeCooling Watercooling System
  4. Jetart Aquacool Liquid Cooling System
  5. No-Name Watercooling System
Tags:
