Maybe this is a cliché, but the NZXT Phantom Case is ready for liftoff. My first impression out of the box was: “this case looks like a freakin’ space shuttle.” Perhaps it was the smooth white exterior with black mesh highlights or the rounded edge of the drive cover? Now, NZXT may not have had NASA engineers design this monstrous full-tower, but the case is impressive between the cooling possibilities, wire-management features and it’s beautiful exterior.
First Impressions
When this huge box appeared on my doorstep, it was clear exactly what was inside. This is no brown box, it is a sleek and gaudy package. The front displays a clear photo of the case, while the back explains the many features of the Phantom. No major dents were found on the box, although there were a few small punctures in the cardboard.
Upon opening the package, I was slightly disappointed to find the white version of the case (as opposed to black or red). White cases evoke a feeling of cheap factory-built PC’s from the 1990′s, plus they are harder to photograph. However, my preconceived anti-White bias was shattered as soon as the case was fully removed from the packaging. The design is quite striking with the combination of straight and curved edges on the front and top of the case. Plus, the mesh fan grills on the top and side panel give the case a chic, futuristic feel.
Right off the bat, several features caught my attention, like the five-channel fan controller, four holes to route water cooling tubes on the back of the case and an E-SATA port on top. The case also felt durable, the side panel did not bend like several other metal-based cases I have tested. Let’s dive into the specifications and features to find out more:
Specifications (Courtesy NZXT)
| Case Type | Full Tower Steel |
| Front Panel Material | Plastic/Steel |
| Dimensions (W x H x D) | 222 x 540 x 623 mm |
| Cooling System | Front 1 x 140 mmRear 1 x 120 mm (included)
Side 2 x 120, 1 x 200/230 mm (2 x 120 mm included) Top 2 x 200 mm (1 x 200 mm LED included) |
| Drive Bays (Screwless Rail Design) | 5 External 5.25″ Drive Bays7 Internal 3.5″/2.5″ Slots |
| Material | Steel with White Finish |
| Expansion Slots | 7 |
| Weight | 24 lbs (11 KG) |
| Motherboard Support | E-ATX, ATX, mATX, ITX |
Features (Courtesy NZXT)
- Maximum Compatibility: Large heatsinks, graphics and E-ATX support
- Excellent Wire Management: Large spacing behind the motherboard provides ample space for wire routing
- Large Expandability: Space for 7 hard drives and five 5.25″ bays
- 7 Fan Cooling Options: Dual 200mm, single 230/200mm, triple 120mm and front 140mm
- Innovative all-new 5.35″ screwless system
- 3.5″/2.5″ SSD support on all 7 drive [bays]
- Dual radiator support and quad watercooling tube cutouts on backplate.
- Rubber PSU and case feet to reduce vibration
- Extra large mesh holes for increased airflow
- Five 20W per channel fan control totaling 100w
- Top mounted USB, audio/mic and E-SATA
- Fan LED on/off function
Phantom Exterior
This case has plenty of mesh to help airflow, plus fan filters help keep the dust out. As mentioned above, the curves and straight edges combine for a futuristic feel. This theme continues when exploring the top of the case as well, with the bright blue power LED, fan controller indicator LEDs and fan LED towards the rear of the case.
Taking a closer look, the typical power and reset buttons are present, plus top-mounted USB, audio/mic and E-SATA ports. The five channel (20w per channel) fan controller switches are located on the top of the case as well. The channels are labeled with diagrams instead of the standard 1, 2,3, 4, 5 numbering system. This is a welcome change because it makes it much easier to keep track of which switch is controlling what fan. No labeling fans or guessing involved. The diagrams illustrate the location of the fan. To make things even easier, NZXT already connected the included four fans to the corresponding channels. Despite my efforts, I was never really able to decipher the speed of the fans when manipulating the switches on the fan controller. I did not have an advanced RPM reading tool, just used my ears to try and listen. There was no discernible difference in sound when the fans were on high or low.
Moving to the front of the case, there is a stylish door hiding the 5.25″ bay covers (which are also mesh) and easily removable. The switch located on the right side of the photo below can be toggled from side to side to remove the bay cover. This method is a whole lot easier than reaching inside the case or prying them out with a screwdriver. My only qualm is that the drive bay door does not lock into place, so the door can easily swing open. This is a minor issue since the case is too large to move around on a regular basis. When the case is perfectly still the drive door will not fly open on it’s own, not even with a Delta screamer pushing 200 cfm directly into the door will cause it to open.
The back of the case is pretty standard with a space for the IO back-plate and PCI/PCI-E cards. Each slot cover is mesh instead of solid aluminum, which again helps air flow freely through the case. Above the IO back-plate is a small black button, which turns the LED in the top-mounted fan on and off. This is a convenient feature if the PC is located in a bedroom. The fan’s bright blue LED can be blinding when trying to sleep. Also, the rear of the case features four watercooling tube cutouts, all .8″ in diameter, which is large enough for most types of standard tubing.
The inside of the case on either side is accessible by thumbscrews, making everyday maintenance or upgrades easy and painless. Time to take off those thumbscrews and explore the inside of the Phantom.
Inside the NZXT Phantom
This case has plenty of cooling configuration options, there are seven places to mount fans, plus plenty of space to add more if you are into case modding. Four fans are included and are already configured to work with the fan controller on top of the case:
- 120 mm fan in the rear above PCI expansion slots
- 2 x 120 mm fans on the side panel
- 200 mm LED fan in the top
Depending on cooling and hardware setup, you may want to reconfigure the fans to suit your needs (I did, see Installation below for details). Each fan mount area also contains a fan filter screen in addition to the mesh as an added layer of protection against dust build-up. Usually smaller fan filters cost a minimum of $3, so including seven of them (as large as 200 mm) with this case is worth $20 at least, probably more.
There are five 5.25″ bays and a whopping seven 3.5/2.5″ bays. The HDD/SSD bays are hard plastic plates that slide in and out of the case. This makes swapping storage easy and definitely makes up for the lack of hot-swappable capabilities on this case. There is quite a bit more to say about the interior of the Phantom, but most of it was uncovered while installing my system.
Installation
The case ships with a visual diagram of the case components and tons of screws, all clearly labeled to avoid any confusion. The labeling is helpful, as it can be difficult to tell the difference between the small screws. NZXT also threw in some zip ties for wire management and a PC Speaker plug.
To sum up, installation went about as smoothly as possible. No major problems to report while mounting the motherboard. My setup is pretty typical, the only wrinkle is my cooling, a CoolIt Vantage self-contained watercooler. The cooler includes an attached 120 mm radiator, which means I could not route the tubing through the watercooling holes on the back of the case even if I wanted to. In order to fit the radiator inside the case, the rear 120 mm fan was moved from the back of the case to the front of the case. In a matter of minutes the CoolIt Vantage was snuggly mounted inside the case.
Up next was the power supply, which was located on the bottom, not the top of the case. A little bit unusual, especially since air flow to the power supply is a concern when overclocking. To my surprise, NZXT has accounted for that with four small rubber braces that the power supply sits atop when mounted in the case. These rubber braces coupled with 2/3 ” of clearance below the case allows for air to flow freely to/from the power supply.
All the expansion slots have thumbscrews, so installing the video card was quick and easy. This is a good feature if you swap out cards on a regular basis for upgrades or benching. If thumbscrews are too much effort for you, then how about using no screws at all? Mounting 5.25″ drives does not require any screws whatsoever. To simplify this, take a look at the below image, then follow the instructions to visualize the process:
- Toggle the NZXT logo switch
- Press the riveted piece inwards, which exposes two prongs (approximately the same size and shape of standard screws)
- Insert the 5.25″ drive
- Press down
- Toggle the NZXT logo switch to lock drives in place
This whole process takes about ten seconds, while you can easily spend a couple of minutes when manually screwing drives into place. This is not a major innovation in the computing world, but the little things really do add up when constructing a PC from scratch.
The rest of the build went smoothly and was pretty typical. When I was ready to string it all together and wire the rig, I noticed plenty of nooks and crannies to hide wires. Plus, there are four dedicated wire management holes strategically located between the motherboard and 5.25″ bays. Now wire management is not one of my utmost concerns, but every enthusiast can appreciate a clean looking build. The only downside is that the rubber guard surrounding the wire management holes falls off easily. If you handle with care, it should not be a problem. In order to get the side panel on behind the motherboard tray, I had to rearrange the wires slightly using the included zip ties.
Final Thoughts
Ultimately, I am not a huge case fanatic, however I was really impressed with this case. For $139.99 at Newegg, this case is a steal. There was almost nothing negative to say about this product, mind you it is my job to look at these products critically. Installation was smooth, especially with screwless 5.25″ bays and thumbscrews in the expansion slots. It was also great not to have to wire up my own fan controller setup, the Phantom was already wired and ready for use. If you are in the market for a new case, the NZXT Phantom will not disappoint.
Pros
- Durable steel construction
- Cooling Friendly Design: four included fans, plenty of mounts for fans of different sizes, space for watercooling equipment and tubing cutouts on the back of the case
- Mesh all over the case helps airflow, but stops dust from entering the case (included fan filters block dust as well)
- Easy-to-mount HDD/SSD and screwless 5.25″ drives
- Wire management holes and plenty of space to hide wires
- Stylish, futuristic looks
- Added value in integrated five-channel fan controller and seven fan filters
Cons
- Drive bay door does not lock into place
- Difficult to decipher RPM with fan controller
Thanks to NZXT for supplying this unit for review.
09-17-10 02:19 PM
09-17-10 02:45 PM
Yeah, the white initially turned me off, but I started to really like it after a while. I was never a fan of white because it always felt cheap, like a 1998 Gateway PC or something, but this white is really stylish.
Matt
09-17-10 02:53 PM
09-17-10 03:04 PM
Matt
09-17-10 03:12 PM
/Star Wars reference.
09-17-10 03:22 PM
09-17-10 03:45 PM
09-17-10 03:59 PM
" nice is case, to have feature and fuctions" Yoda.
09-18-10 09:04 AM
01-26-11 05:59 PM
07-23-11 08:08 AM
07-23-11 10:58 AM
i actualy have one of theese cases on order (should be here next week or so).
i love the built in fan controler, and the spacious interior.
the sleek curves make it realy sexeh
the only thing that i would change is to add a window on the side to show off that lovley interior
(nothing a slight mod wont fix :P), if it had one it would same me some time cutting the thing up. its ALMOAST to pretty to cut up.
07-25-11 04:49 AM
Oops....
07-25-11 12:19 PM
The door on front, well, I've got curious young grandkids. Nice to have the door to hide all the potential for tiny button pushers. Built a caddy to roll it around under my return/desk. Cable management? Let's just say "way too easy". You can quote me on that. Got some sleeved NZXT extensions. Smudges on the plastic shell? Well, a little dab of Armor-all on a washcloth takes care of that. A chamoise afterwards takes care of later wipedowns.
Storm Trooper look? Not for everyone, that's for sure. But then, I went to the opening of Star Wars in 1977 with some friends. So the look is definitely not a problem for me. And after adding a couple of more fans I have a very quiet but cool computer. I say, good job on the box NZXT.
07-30-11 11:05 AM
08-08-11 04:53 PM
