Abit KR7A-R PCI Speeds
Add Your Comments
A look at PCI speeds above 133 MHz. – Joe
SUMMARY: Based on UXD’s Diagnostic Card, the Abit KR7A-R does not enable PCI divisors above /4.
Josh was nice enough to send an email asking me to look into the issue of “hidden” /5 and /6 PCI divisors on the Abit KR7A-R. This board uses the Realtek RTM560-266R clock generator, which supports PCI divisors beyond /4.
To test this out, I used my UXD P.H.D. PCI Diagnostic Card which reads PCI bus speeds directly. This card mounts in a PCI slot; after the mobo completes BIOS, the UXD card takes over. Note there is no OS involvement – in running the tests below – the only disc was a floppy.
For these tests, I ran the most conservative memory settings and underclocked a T-Bird 1400 at high FSBs – I ran it at a 6 multiplier. The intent was to read PCI speeds at various FSBs and PCI settings to see what’s going on:
Abit KR7A-R FSB/PCI Speeds
FSB
PCI Speed
PCI Setting
100
33.71
3/2/1
110
36.93
3/2/1
120
40.27
3/2/1
130
43.60
3/2/1
130
32.69
4/2/1
132
44.38
3/2/1
133
44.51
3/2/1
133
33.53
4/2/1
134
45.02
3/2/1
140
FAIL¹
3/2/1
140
35.20
4/2/1
150
37.80
4/2/1
160
40.24
4/2/1
165
41.53
4/2/1
166
41.78
4/2/1
167
42.02
4/2/1
170
42.76
4/2/1
175
44.02
4/2/1
180
45.29
4/2/1
185
FAIL¹
4/2/1
¹UXD failed to boot.
Once you shift to the 4/2/1 setting at 133 MHz, PCI speeds keep on climbing after that. I could not get beyond 180 MHz (which is impressive), but the pattern is clear – if there was a /5 divisor, it would hit at 166 MHz.
As always, a sample of one, but for this particular board, there are no /5 or better divisors. We’ll continue to experiment, but unless the UXD Diagnostic Card is misreading PCIs (it did not for Iwill’s XP333), it does not look like enhanced divisors are enabled.
If I’m missing something in BIOS to enable these divisors, please drop me a line.
Email Joe
Leave a Reply
