Actonica Optical MicMouse
Add Your Comments
Integrated mouse/microphone – Joe
SUMMARY: Attractive mouse/microphone combo with some limitations.
MicMouse
Included in the blister pack is a pair of earphones.
The good guys at Act-On were nice enough to send me a sample of their Optical MicMouse to try out. I know sometimes we might talk to our PCs, but this is the first time where talking to your mouse could actually be considered normal – this mouse has a microphone embedded into it for VoIP or other sound recording use.
Key Features
  • Built-in microphone
  • Optical technology
  • 800 dpi resolution
  • Two buttons plus lighted scroll wheel
  • Left and right hand compatible
  • Plug-and-play USB
  • Size: 113 x 60 x 30mm
  • Cable length: 58″; Tails 24½” tip-to-tip
The mouse itself is quite attractive:
MicMouse
The scroll wheel is lit (red) when powered.
Note that the left and right buttons are not separate from the top shell – they are as light to the touch as any other mouse I have used. The microphone
MicMouse
is built into the center of the mouse, above the scroll wheel. Note that in use, if you use the microphone at the same time you use the mouse, there may be a chance that you might cover up the microphone with your fingers, especially if you use the scroll wheel while talking. The base
MicMouse
features four pads plus the optical sensor array in the center. Overall, a very nice package.
Use Test
As a mouse, the MicMouse functioned very well – light to the touch and responsive. There is no utility packaged with the mouse, so mouse settings are those built into Windows. I tried a number of white surfaces to see how it would track, and one that did stymie the MicMouse was a white mat behind a clear glass on a framed picture – this did not stymie my cordless Logitech, although I can’t say it tracked all that well on it. On plain white paper, the MicMouse had no problems.
In use, I think you’d have to go out of your way to find a surface that would not track well.
I found the microphone quite sensitive – I could get good voice sound recording with the mouse about two feet away; I recorded background noise as well, in this case music playing softly about ten feet away.
However, when recording, if you use the mouse when using it as a microphone, you will pick up noise just from moving the mouse around. In addition, if you click the buttons, you will hear a loud “click” sound in the recording. I thought the microphone would be muffled when I used the scroll wheel, but I found that even covering the microphone with my finger did not substantially lessen its effectiveness.
CONCLUSIONS
As an integrated product, the MicMouse performed quite well in both the mouse and microphone mode. However, do not expect the two functions to perform seamlessly together – you will pick up “mouse sounds” if you use the microphone and mouse at the same time – the button click will be quite distinct and moving the mouse will sound like a slight background distortion.
Overall, if you’re looking to save some space on the desktop, the MicMouse can serve two distinct functions well, and perform two functions simultaneously with the limitations noted – not bad for an MSRP of $22.
Thanks again to Act-On for sending this our way.
Email Joe
Leave a Reply
