ADATA XPG SX930 240GB SSD Review
Add Your Comments
JMicron recently released their new JMF670H controller, and ADATA was quick to implement this new controller in their new XPG SX930 line of SSDs. This new offering from ADATA comes in capacities of 120, 240, and 480 GB and promises excellent performance while keeping an eye on reliable endurance. Anytime a new controller hits the market, we’re always anxious to find out how it performs. So, let’s get started and see what the ADATA XPG SX930 has in store for us.
Specifications and Features
The XPG SX930 SSDs have been under embargo until recently, so we don’t have a lot of fancy graphics and marketing descriptions to share. However, we were provided a reviewer’s guide that gives us important information to pass along to you. The XPG SX930 SSDs are designed with enterprise grade MLC+ sync NAND flash, which ADATA claims results in high performance, as well as extreme reliability. ADATA further states their strict selection of MLC flash memory will ensure overall system efficiency and speed, which makes these SSDs ideal for gamers in terms of performance and stability.
The features and specifications below were provided by ADATA. Other than what we talked about above, the drive offers a 5-year warranty, supports TRIM, and has DDR3 DRAM for a Cache buffer. ADATA also implemented Pseudo-SLC (pSLC) Cache technology. This technology is normally associated with increased performance, but also helps with overall endurance. The JMicron JMF670H controller is said to compete with the likes of Silicon Motion’s SM2246EN and Phison’s S10 controllers and the price/performance ratio that they offer.
adata_sx930 (26)
The XPG SX930 uses the SATA 6 GB/s (SATA III) interface, even though the push of late is to move SSDs to the PCIe lanes. The cost of PCIe based SSDs still drives a lot of people back to the aging SATA 6 GB/s interface, which continues to be a viable option for achieving a good balance between price and performance.
Features
• Ultra-Fast pSLC Cache technology
• Enterprise MLC plus NAND Flash
• 5-Year warranty
• Advanced BCH ECC Technology
• Supports DDR3 DRAM Cache buffer
• NCQ Support
• Supports Windows TRIM Command
• S.M.A.R.T supported
Specifications
• Controller: JMicron 670H
• NAND Flash: Synchronous MLC plus NAND Flash
• Interface: SATA 6Gb/s (SATA III)
• Capacity: 120GB / 240GB / 480GB
• Channels: 4 Channels
• Size: 100.45 x 69.85 x 7mm (L x W x T)
• Weight: 68g
ADATA’s performance claims vary slightly depending upon the drive’s capacity. Below is the performance breakdown for each of the three offered capacities.
120GB
Up to 560 MB/s Read
Up to 460 MB/s Write
Up to 70K 4K Random Read IOPS
Up to 45K 4K Random Write IOPS
240GB
Up to 560 MB/s Read
Up to 75K 4K Random Read IOPS
Up to 70K 4K Random Write IOPS
480GB
Up to 520 MB/s Read
Up to 420 MB/s Write
Up to 72K 4K Random Write IOPS
Software – ADATA SSD Tool Box
ADATA provides a free download of their SSD Tool Box, which is a full featured set of tools worth exploring. The utility offers system optimization, drive and system information, diagnostics, and the ability to secure erase the SSD.
Retail Packaging/Product Tour
The retail packaging is rather attractive and gives the potential customer a good idea of what they’re buying into. The box front has a window allowing for a view of the drive’s top side and lists many of the SSD’s features. Around back is more information presented in a multilingual format. The kit we were sent for review is what ADATA calls a desktop pack, which means you get a 3.5″ to 2.5″ adapter, mounting screws, and a spacer for 9.5 mm thick applications. A quick start guide is also included in the box, along with instructions on how to get your free copy of the Acronis migration software.
Once out of the package, we can see the drive is decked out with flame style graphics on the top that also has the SSDs branding information. At the bottom of the drive, we find all the bar code information including warranty code and serial number.
Inspecting the inside of the XPG SX930 reveals the memory packages and their ADATA branding, but they are sourced from a third party. Very few SSD makers actually manufacture their own NAND, so no big surprise there. ADATA doesn’t provide a lot of details on the NAND Flash they use other than to simply say “synchronous MLC+ NAND Flash.” So, depending on current availability and market conditions, ADATA is free to explore what fits their designs the best. The below pictures also show you the typical SATA data and power connections, the JMicron JMF670H controller, and the 128 MB NANYA DDR3 memory module used for the Cache buffer.
Testing and Benchmarks
Test System
Here are the components used in our SSD test bed.
Test System Components
Motherboard ASUS Maximus VII Formula
CPU Intel i7 4790K Devil’s Canyon
Memory G.SKill TridentX DD3-2400 MHz 2x8GB @ 1866 MHz 9-9-9-24
SSD Various (See Below)
Power Supply Corsair HX1050 Professional Series
Video Card EVGA GTX 780 Ti Classified
Cooling EKWB Supremacy EVO Water Block – 360 mm Radiator – MCP35X Pump
Today’s comparison samples include three high capacity SSDs in the Samsung 850 EVO (500 GB), Patriot Ignite (480 GB), and the ADATA Premier SP610. We’ll also include data from the Kingston HyperX Savage (240 GB). All of these SSDs were tested very recently using the exact same system components as listed above.
Test Method
Each SSD is Secure Erased to make sure we get the best results possible. We do this before each and every test run to give the comparison samples the best environment possible for testing. Below are the tests we run with a brief description.
  • Crystal Disk Mark – Run at Default Settings (5 Pass)
  • AS SSD – Run at Default Settings
  • ATTO – Run at Default Setting with QD Set to 10
  • IOMeter 2010 – Run Manually with QD32 for the 4K Tests
Performance
Beginning with CrystalDiskMark’s read benchmark, we see the XPG SX930 competing very well in the sequential and 4K tests. It fell a bit behind the other competitors in the 512K and 4K QD32 tests. CDM’s write tests show the XPG SX930 reaching advertised speeds and to be very competitive across the board here.
CDM Read Results
CDM Read Results
CDM Write Results
CDM Write Results
AS SSD read testing shows the XPG delivering solid numbers in the sequential and 4K tests, but it fell a little behind in the 4K-64Thrd run. The write tests showed much better results across the board where the XPG SX930 beat out the Samsung 850 EVO and ADATA SP610 in the 4K-64Thrd test. Access times showed very little difference between all the drives, but the XPG SX930 did have the best result of all in the write test. AS SSD also provides a scoring profile, where the XPG SX930 did pretty well on the write scoring, but not so much on the read side.
AS SSD Read Results
AS SSD Read Results
AS SSD Write Results
AS SSD Access Time Results
AS SSD Scoring Results
IOMeter shows the XPG SX930 doing quite well in the 2 MB read and write tests, and it threw out some decent numbers in the 4K tests as well. IOPS testing showed excellent performance as the read IOPS came in over 70K, and the write darn near hit 80K.
IOMeter 2MB/4K Read/Write Results
IOMeter 2MB IOPS Results
IOMeter 4K IOPS Results
ATTO Bench has the XPG SX930 maxing out at 557 MB/s read and 461 MB/s write. That’s just a hair under advertised speed on the read test and a tad over advertised speed on the write side.
ATTO Bench Read Results
ATTO Bench Write Results
Just to check one other benchmark, we usually give Anvil’s Storage Utility a quick go. Below are the 100% incompressible and 0-Fill results.
Anvil's Storage Utility 100% Incompressible Data
Anvil’s Storage Utility 100% Incompressible Data
Anvil's Storage Utility 0-Fill
Anvil’s Storage Utility 0-Fill
Overall, the performance is as expected from an SSD of this class. It’s obviously not going to set any speed records, but it’s still a very quick SSD.
Conclusion
Now that the SATA GB/s interface is pretty much saturated as far as read/write speeds go, we see SSD manufacturers concentrating more on endurance, reliability, and cost effectiveness. ADATA seems to have done just that with the XPG SX930 as there really isn’t much new to report on the performance front, even with a newly released controller. However, the 5-year warranty exudes confidence in the long-term reliability of the XPG SX930, which is more than the standard 3-year warranty a lot of other SSD makers offer.
As mentioned, performance numbers aren’t earth shattering, but do meet ADATA’s claims. Rumor has it JMicron is considering a firmware update to enhance the read performance of the JMF670H controller, which as our testing shows could stand to be improved a little. That’s not to say the read performance was dismal, but it did fall a bit short compared to our other sample drives during certain test scenarios.
ADATA gave us the following MSRP for the three different capacity XPG SX930 SSDs. We were told the drives should hit eTailers like Amazon and Newegg within the next week or so.
• 120GB $79.99
• 240GB $109.99
• 480GB $199.99
Those prices are pretty much what we see across the board for similar capacity drives from the different manufacturers and are likely to be even a few dollars less once they actually become available to purchase. It’s pretty tough to compete with manufacturers that make their own NAND and controllers, but ADATA seems to be hanging in there. ADATA’s XPG SX930 gives us yet another viable option worth exploring if you’re in the market for a good performing, reliable, and affordable SSD.
Overclockers_clear_approved
Click the Stamp to View Our Product Rating System
Dino DeCesari (Lvcoyote)
Leave a Reply
