AKASA Silver Mountain 2
Add Your Comments
Another top peformer — Joe
SUMMARY: Very good performance, although somewhat weighty for mounting on a single lug.
Akasa 2
Size: 60 x 72 x 73mm high; Weight 580 gms; Fan: YS Tech 38 cfm @ 6800 rpm
Crazy PC was nice enough to send over an AKASA Silver Mountain 2 to test out. This is a pin-fin, all copper heatsink that is silver plated. I doubt that it adds anything to cooling, but it does make for a pretty picture and marketing tag-line.
This is the successor to an earlier model whose base measured 60 x 60mm – the “2” is 10 mm longer on one side.
This heatsink is no light-weight; weighing in at 580 gms (about 1¼ pounds), this is a serious chunk of copper. Note that the Akasa’s clip engages one socket lug – this IS NOT a heatsink to leave on if you are transporting your PC to a LAN party. I would feel a lot better if the clip engaged all three lugs.
If you look closely at the base,
Fins Close
you can see small “cut marks” – it looks like the pins (252 in all) are punched into the base and these marks are as a result of this process. Performance will depend on how well the pins are mated to the base.
The base
Base
is very smooth and flat – a nice job.
The fan is mounted on a skirt which raises the blades above the pins – helps to reduce noise somewhat. The fan is YS Tech NFD126025BB-2F, rated 38 cfm @ 6800 rpm. I measured noise with a Radio Shack sound meter 8″ from the fan’s intake at 69 dBA, about the same noise as a Delta 38. This fan is rated at 7.2 watts and comes with a four pin adapter; there is an rpm wire which plugs into a fan header so you can monitor rpms.
The clip requires a screwdriver to mount. I found it easy to mount – the slot for the screwdriver is secure enough so the potential for a slip appears minimal. Although I’m getting used to these, I still don’t like them because doing this inside a cramped case is not fun.
THE TEST
The Akasa was first tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences. I then tested it on an Iwill KK266+ and Shuttle AK31, modified to read AMD’s on-die diode, as an example of what users might see on their systems.
TEST RESULTS – CPU Simulator
Heatsink
Die Temp
Ambient Temp
Delta
C/W
Akasa SM2, 77.3 watts
46.5 C
20.1 C
26.4 C
0.34
TEST RESULTS – Motherboard
CPU/Motherboard
CPU Die Temp
Ambient Temp
Delta
C/W
CPU Back Temp
Palomino 1200, Iwill KK266+, 55 w
34.6 C
21.4 C
13.2
0.24
36.2 C
XP @ 1467, Shuttle AK31, 65 w
38.7 C
19.8 C
18.9
0.29
34¹ C
¹In-socket thermistor temp
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU core temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Die Simulator results place the Akasa Silver Mountain 2 in the top rank of heatsinks (Heatsink Ranking).
CONCLUSIONS
The Akasa Silver Mountain 2 does a very nice job, and why not? Lots of pins, lots of copper and lots of air flow (and noise) – works every time!
Thanks again to Crazy PC for sending this our way.
Email Joe
Leave a Reply
