Very good PIV performance — Joe
SUMMARY: A very good choice for PIV cooling.
A while ago we took a look at the Alpha PAL 8045 Socket A version. It’s not a stretch (actually, it was) for Alpha to come up with a PIV version; all the elements are there (spring loaded bolts, shroud, etc) and, aside from different sizing, it looks a marginally easier to manufacture. The base
is simpler – no step for a socket cam. The base finish is very good but not exceptional – there are very fine polishing marks on it; lapping might improve performance a tad but I think not worth the effort (the marks are on the base are exaggerated by the flash angle).
The fins are typical Alpha:
Lots of them and hexagonal shaped. All told – typical Alpha quality.
Readers have been asking for a range of fan speeds when I test heatsinks, and I’m in the process of setting up testing for this. In the interim, I tested the Alpha with the following fans:
- Delta AFB0812SH, spec: 47 cfm @ 4000rpm, 40 dBA
- Delta FFB0812SHE, spec: 68 cfm @ 4800rpm, 48.5 dBA
- YS Tech FD1280329B-2F, spec: 56 cfm @ 5400rpm
- Vantec SF8025L (Stealth), spec: 27 cfm @ 2050rpm, 21 dBA
I measured noise using a Radio Shack sound meter placed 8″ from the fan’s intake and found the following:
| Fan |
dBA
RPM
Watts
| Delta FFB0812SHE |
67
4800
10.4
| YS Tech FD1280329B-2F |
71
5500
7.6
| Delta AFB0812SH |
60
4000
6.1
| Vantec SF8025L |
<50
2070
1.2
Manufacturers meter sound at 3 feet from the fan, so the dBAs I measured do not correspond to the manufacturers ratings. However, the relative rankings are roughly similar.
The Alpha PAL 8942 was first tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences. I then tested it on a Lucky Star with a PIV 1500, which is modified to read CPU case temps directly, as an example of what users might see on their systems.
| Heatsink |
Die Temp
Ambient Temp
Delta
C/W
| Alpha PAL 8942/YS Tech 5500rpm |
40.8 C
19.1 C
21.7 C
0.29
| Alpha PAL 8942/Delta 4000rpm |
42.5 C
19.1 C
23.4 C
0.32
| CPU/Motherboard |
CPU Case
Ambient Temp
Delta
C/W
CPU MBM Temp
| Lucky Star, PIV 1500, Delta 4800rpm |
29.6 C
19.5 C
10.1
0.17
25 C
| Lucky Star, PIV 1500, YS Tech 5500rpm |
30.0 C
19.7 C
10.3
0.18
25 C
| Lucky Star, PIV 1500, Delta 4000rpm |
30.4 C
19.1 C
11.3
0.20
26 C
| Lucky Star, PIV 1500, Vantec Stealth 2070rpm |
35.7 C
20.7 C
15.0
0.26
30 C
C/W = Delta / CPU Watts
