Table of Contents
Today we get a sneak peek of what is coming next Thursday. I can’t let the whole cat out of the bag yet but I can let you see its whiskers. All joking aside, there is a Non-Disclosure Agreement (NDA) in place until April 19th for actual performance numbers and benchmarks but AMD is letting us show off their new hardware prior to the actual review. I have the AMD Ryzen+ review kit here and will give a quick rundown of its contents and some of the specifications and features of the upcoming Ryzen+, the all-new X470 motherboards and G.Skill DDR4 which have been included in the kit.
First up though are some glamour shots of the kit and its contents.
In the kit I received, AMD has included the second generation Ryzen CPUs, two X470 motherboards and some new DDR4 from G.skill which is geared for the AM4 platform. The CPUs included are the Ryzen 7 2700X with its Wraith Prism CPU cooler and the Ryzen 5 2600X which is bundled with the Wraith Spire CPU cooler. This was very unexpected, but AMD also included two motherboards in the kit, the X470 Gaming M7 AC from MSI as well as the X470 Aorus Gaming 7 WiFi from Gigabyte. Also included, was a 2×8 GB, dual channel set of the new SniperX memory from G.Skill which has been tested for AM4 compatibility and runs at 3400 MHz, Cl16.
AMD RYZEN 2700X and 2600X
Currently, we are not at liberty to divulge a lot of information regarding the upcoming CPU launch but do have a few pictures of them and their coolers. I’ve also put together a quick specifications table outlining some of the important aspects of the new CPUs. I can say that the new second generation Ryzen CPUs are still compatible with the previously released 300-series chipset motherboards as well as motherboards with the new 400-series chipsets.
You’ll also notice there are fewer SKUs for this launch with only the 2700 and 2600 series CPUs. The 4-core variants launched about a month ago in the form of the 2400G and 2200G APUs. These are the replacements for the series of CPUs ranging from the Ryzen 3 1200 up to the Ryzen 5 1500X. To date, there’s no word or indication of a Ryzen 7 2800X release, at least not to our knowledge.
The second generation Ryzen brings with it updated versions of the Precision Boost and XFR. The new Precision Boost 2.0 was covered in the APU review in February and XFR 2.0 will be covered in the review next week. In short, Precision Boost 2.0 leverages more cores during the boost stage to increase the performance. This is all dependant on temperature, power, and CPU limitations but I did see much higher “all core” boost levels with the APUs.
Below is a table of the Ryzen+ CPU line specifications.
AMD Ryzen+ CPU Specifications
Ryzen 7 2700X | Ryzen 7 2700 | Ryzen 5 2600X | Ryzen 5 2600 | |
MSRP | USD $329 | USD $299 | USD $229 | USD $199 |
Silicon | 12 nm “Pinnacle Ridge” | |||
Socket | AM4 | |||
Cores/Threads | 8-core/16-thread | 6-core/12-thread | ||
Clock Speed | 3.70 GHz | 3.20 GHz | 3.60 GHz | 3.40 GHz |
Boost Speed | 4.35 GHz | 4.10 GHz | 4.25 GHz | 3.90 GHz |
Cooler | Wraith Prism | Wraith Spire | Wraith Spire | Wraith Stealth |
L2 Cache | 512 KB per core | |||
L3 Cache | 16 MB shared | |||
Unlocked | Yes | |||
New Features | XFR 2.0 and Precision Boost 2.0 | |||
TDP | 105 W | 65 W | 95 W | 65 W |
Memory | Dual-Channel DDR4-2933 JEDEC up to 64 GB | |||
PCIe | PCIe Gen 3.0 x16 PEG (x16 or x8 + x8) + x4 M.2 + x4 Chipset | |||
SoC Connectivity | 2xSATA 6 Gbps, 4x USB 3.1, 1xM.2- PCIe 32 Gbps | |||
Chipset | AMD 300 and 400 Series |
Here’s a few pictures of the upcoming CPUs, packaging and coolers.
X470 Motherboards
I’ll start this off with AM4 chipset specifications which are handled best with a nice and neat table below. As a note, the majority of the new features require an AMD 2000 series CPU.
Chipset | X470 | X370 | B450 | B350 | B320 |
USB 2.0 | 6 | 6 | 6 | 6 | 6 |
USB 3.0 (5 Gbps) | 6 | 6 | 2 | 2 | 2 |
USB 3.1 (10 Gbps) | 2 | 2 | 2 | 2 | 1 |
SATA 3.0 | 4 | 4 | 2 | 2 | 2 |
SATAe/PCIe Gen3 | 2 | 2 | 1 | 1 | 1 |
PCIe Gen2 | 8 | 8 | 6 | 6 | 4 |
CPU PCIe Interface | 1×16/2×8 | 1×16/2×8 | 1×16 | 1×16 | 1×16 |
Overclocking | Yes | Yes | Yes | Yes | No |
XFR 2.0 | Yes | Yes | Yes | Yes | Yes |
XFR 2.0 Enhanced | Yes | No | Yes | No | No |
Precision Boost Overdrive | Yes | No | Yes | No | No |
Gigabyte X470 AORUS GAMING 7 WIFI
The Aorus Gaming 7 appears to have a 12-phase power delivery system with an 8-pin and 4-pin EPS 12v power connections for the CPU. They have also included an onboard power switch but it’s located on the rear I/O panel next to the clear CMOS button which is a first for me.
Additional specifications below.
- Socket AM4
- AMD Ryzen Processors
- AMD 470 Chipset
- DDR4 Dual Channel, 4 DIMMs
- 1 PCIe 3.0 x16 + 1 PCIe 3.0 x8
- 1 PCIe 2.0 x4 + 2 PCIe 2.0 x1
- 6 SATA 3, 2 M.2 for SSD
- 2 USB 3.1 Type-C, 1 USB 3.1 Type-A, 10 USB 3.0 and 6 USB 2.0
- Intel GbE Lan, Intel 2×2 AC Wireless
- Realtek ALC1220-VB
- ATX Form Factor 305mm x 244mm
All Images below can be viewed full size by right clicking and opening in a new tab.
MSI X470 GAMING M7 AC
There’s a couple of additions to the MSI worth mentioning here. They have included a BIOS Flashback function, onboard power and reset buttons, and the familiar “Game Boost” knob. There’s also what appears to be a 14-phase power delivery system with 2 x 8-pin auxiliary power connectors.
- Socket AM4
- AMD 470 Chipset
- 2 PCIe 3.0 x16
- 1 PCIe 2.0 x16 + 3 PCIe 2.0 x1
- 2 USB 3.1 Type-C, 1 USB 3.1 Type-A, 8 USB 3.0 and 6 USB 2.0
- Killer E2500 Gigabit LAN, Intel Dual Band Wireless-AC 8265, Bluetooth 4.2
- 8-channel Audio Boost 4 Technology
- ATX Form Factor
G.Skill SniperX DDR4
The G.Skill SniperX line of DDR4 is a fairly recent addition which premiered in January this year. It features speeds ranging from 2400 MHz up to 3600 MHz and judging by the sticker on this package some of them are compatible with the AM4 platform. The RAM below is a 2 x 8 GB, dual channel kit rated for 3400 MHz with 16-16-16-36 timings at 1.35 V using the XMP profile. It’s pretty sharp looking RAM with a black body and black/grey/white camouflage theme on the top bar. These aren’t available in RGB LED models.
There you have it, AMD has given me quite an arsenal of new equipment to test the second generation Ryzen CPUs with. This review kit just arrived Wednesday evening so time will be tight just testing the CPUs. I would like to be able to test both motherboards as well but to do that thoroughly will be difficult with a deadline less than a week away.
So, it’s back to work for me and make sure you tune in here Thursday, April 19th at 9:00 a.m. sharp for the official unveiling of the second generation AMD Ryzen CPUs!
Shawn Jennings – Johan45
Loading new replies...
Benching Team Leader
Senior Member
I once overclocked an Intel
