An Evaluation of the ThermoChill Radiators
Bill Adams’ testing with conclusions for all radiators.
Rads
Five ThermoChill radiators were tested to ascertain their air and liquid side flow resistances, and to determine their heat dissipation characteristics. Additional data was also developed to describe the effect on flow resistance of different connecting fittings and to illustrate the effect of different coolant to air temperature differentials. A variety of fans were tested to enable users to obtain an insight as to their expected performance and to quantify the benefit of using two fans in a push-pull arrangement.
Radiators Tested and an Outline of the Test Conditions and Methods
The radiators tested were the HE 80.1, the HE 92.1, and the HE 120 series; being the HE 120.1, HE 120.2, and HE 120.3. The latter three being the same core but lengthened to accommodate one or two additional 120mm fans.
As their names imply, the radiators are sized to fit the fan of that size; the HE 80.1 width being just slightly larger than the fan at 82mm, with the bottom extending 22mm and the top 28mm. The others are slightly wider than the fans, extending 9mm on either side for the HE 92.1 and 2mm for the HE 120 series. The top and bottom extended lengths are also slightly longer being 34mm and 26mm for the HE 92.1 and 29mm and 26mm for The HE 120 series.
The connections are female 3/8” BSP, which has a 1 thread per inch difference as compared to NPT. BSP barbed fittings are available in the US, though not common, but both metal and plastic NPT sealed without difficulty. Worth noting is that the connectors are machined from brass and quite stout.
Three radiators were tested comprehensively: The HE 80.1, the HE 92.1, and the HE 120.2; while all were tested for liquid side flow resistance and dissipation with selected fans of the low, medium, and high flow types.
Coolant flow rates were measured with a Danfoss MAG 5000 flow meter with the MAG 1100 ¼ in. magnetic flow tube, differential pressures with a Foxboro 823DP differential pressure transmitter and Digitek digital gauge, temperatures with a Fluke 2180A Digital RTD Thermometer with multipoint RTD selector, and the coolant temperature maintained with a Haake A82 Recirculating Chiller.
The coolant flow rate set points were 1.1, 1.9, 3.8, 5.7, 7.6, 11.4 lpm (0.3, 0.5, 1.0, 1.5, 2.0, and 3.0 gpm); and the air flow was set on the basis of the radiator backpressure at 3.7, 12.5, 37.4, and 62.3 Pa (0.015, 0.05, 0.15, and 0.25 in. H2O).
The air flow was generated with a voltage controlled blower assembly, and quantified by calculation using a Kunz 441S thermal anemometer. Air pressure was measured using a Energy Conservatory digital low pressure differential manometer.
The coolant to air temperature difference (“C” as defined below) used for this testing was 5.0°C, representative of a very well designed watercooling system with considerable ‘excess’ radiator heat dissipation capability. This is a very important distinction as a radiator’s heat dissipation is directly related to the temperature difference between the air and liquid sides. It will be shown that the coolant flow rate will slightly affect the heat dissipation, and that the air flow rate will strongly affect it; but the temperature difference is the defining parameter.
The following equations were used to calculate the radiators’ performance from the collected data:
For thermal resistance, or C/W (having the units °C/W):
C = [(Tinlet coolant + Toutlet coolant) ÷ 2] – Tinlet air      all in °C, and
W = m * Cg * (Toutlet – Tinlet)
where W = Watts
m = mass flow rate, kg/sec
Cg = specific heat capacity,
for H20, 4186 J/(Kg°C)
This reduces to:
W = (lpm * 4186 * ΔT) ÷ 60
Bill Adams
Radiator Test Results
Before reviewing the individual radiator results the effect of the air to coolant temperature differential must be well understood.
Graph 1
Graph 1
From the above graph it is clear that as the air to coolant temperature difference is increased, likewise is the dissipation. The comparison being based on (Tfluid – Tair) = C versus W, where Tfluid = (Tout + Tin) ÷ 2. The calculated C/W was 0.015 for each of these three tests. (This is a seriously large radiator.)
Conclusion #1:
Any description of radiator capacity MUST define the coolant to air temperature difference for that ‘rating’.
The performance of the three radiators tested comprehensively is shown below.
And to repeat, while the heat dissipation values may seem small, note that the temperature differential is small as well.
HE 80.1 Test Results:
Graph 2
Graph 2
The four curves each show the radiator’s heat dissipation at a specific backpressure, which is also a specific air flow rate for that individual radiator. Of note is the changing relationship between the liquid and air sides; at low to moderate air flow rates the dissipation increases only slightly with the flow rate, while at a high air flow rate there is also a marked increase in cooling capability.
“For the common respective flow rates, the convection heat transfer for air is the limiting parameter for a liquid to air heat exchanger. This is why there are fins (to increase convection heat transfer) on the air side and not on the liquid side for these heat exchangers. For low air flow rates, the thermal resistance of the air side is much more important than the fluid side (except for low fluid flow rates). Increasing the fluid flow rate leads to an improvement for the convection heat transfer, thus a lower thermal resistance, of the fluid side but this is negligible as compared to the air side thermal resistance. Improving the air side convection heat transfer, in other words the air flow rate, leads to a better global improvement.” *
For the HE 80.1 the fan tests were done only at 3.8 lpm (1.0 gpm) and it can be seen that all ‘normal’ air flow rates can be achieved by means of fan selection. From an application perspective it can be understood that using this small a radiator will result in somewhat higher coolant temperatures (to increase the air/coolant differential) and that a higher air flow rate will be needed.
Several fans were tested at 12 and 7V, both singly and in a push-pull configuration. Running the single Delta FFB0812EHE at 7V instead of 12V reduced the radiator capacity by 18%. Running two Panaflo FBA08A12 fans at 12V instead of one increased the heat dissipation by 17%, while running the two Panaflo fans at 7V produced no gain at all compared to the single fan at the same voltage.
It can also be seen that the highest backpressure / air flow rate cannot be attained with any ‘normal’ fan – or reasonable noise level. This is true for all the radiators tested, and may be considered a characteristic of this type of radiator core construction. Likewise, the lowest backpressure air flow rate yielded very poor performance. Fan selection should be based on achieving an air flow rate between the two middle curves, at the upper (37.4 Pa) for maximum performance and towards the lower (12.5 Pa) for low noise.
*Corrections and explanatory comments graciously provided by Antoine Dechaume.
Bill Adams
Graph 3
Graph 3
This is the same data as in Graph 3, but plotted differently to emphasize the effect of increased air flow. The significant increase in heat dissipation at very high air flow rates illustrates that the benefit of very high coolant flow rates can only be had at correspondingly ‘high’ air flow rates – for this radiator. It is suspected that the flow regime may also be in transition within the tubes. Unfortunately, these flow rates are impractical in desktop computer watercooling systems due to pump and fan noise limitations.
Graph 4
Graph 4
From the above graph it is evident that a radiator’s thermal resistance, or C/W, is not a single or constant value; rather it depends on both the liquid and air side flow rates.
Conclusion #2:
Any description of radiator capacity MUST define the air and liquid side flow rates upon which the ‘rating’ is based.
One can also conclude that the very silent Papst 8412NGL fan is not suitable for this application.
Graph 5
Graph 5
This graph is again a re-plotting of the data used in Graph 4, and reinforces the recommendation previously made to select fans to achieve an air flow rate between the two middle measurement points (between 0.28 m³/min and o.75 m³/min airflow for this radiator). The ‘knee’ in the curve is suggestive of a transition in the air side convection rate. But understanding what a fan’s actual output is when matched to a specific radiator is impossible for an end user. (This statement is based on extensive comparative testing of fans and seeing different results with fans having similar specifications.)
HE 92.1 Test Results:
Graph 6
Graph 6
For the test of the HE 92.1, a single Nidec D09T-12PG fan was also tested over the full range of flow rates. It can be concluded from the resultant curve that a fan’s capability at a single coolant flow rate will match the dissipation curve based on the fan’s backpressure capability.
Graph 7
Graph 7
The identical heat dissipation at the 7.6 and 11.3 lpm coolant flow rates indicates that there is no benefit to be had in the radiator by very high coolant flow rates.
Graph 8
Graph 8
Graph 9
Graph 9
Bill Adams
HE 120.1 Test Results:
Graph 10
Graph 10
The HE 120.1 was tested with fans only, in various combinations. Interestingly, two Delta 1212VHE fans at 7V were quite similar in performance to one Delta at 12V, yet the noise was substantially less. These fans might be a ‘solution’ for users interested in a dual performance mode. Again, the Papst low noise fans were not good performers.
Graph 11
Graph 511
HE 120.2 Test Results:
Graph 12
Graph 12
Here it can be seen that the two Delta 1212VHE fans perform excellently at 12V, and when under-volted to 7V for lower noise, still retain 67% of their capability. The Papst 4312L fans conversely, have only moderate capability at 12V and deliver little when under-volted to 7V.
Graph 13
Graph 13
Again it can be seen that the radiator benefits little from the 11.4 lpm flow rate.
Graph 14
Graph 14
Graph 15
Graph 15
HE Radiator Comparisons
Due to their identical construction, other than their length, the dissipation capability of the HE 120 series can be extrapolated as shown in this graph.
Graph 16
Graph 16
The ThermoChill radiators’ flow resistance at different flow rates can be compared in this graph:
Graph 17
Graph 17
As expected, the HE 80 has the highest flow resistance followed by the HE 92.1. Due to the additional number of tubes in parallel, the HE 120.1 has the lowest resistance with higher resistances from the HE 120.2 and HE 120.3 due to their increased length.
The connectors utilized also may add to the radiators’ flow resistance and their effect is shown below. The differences shown from the baseline 3/8” NPT x 5/8” barb would apply to all of the HE radiators at that particular coolant flow rate. (To determine the radiator’s total liquid side flow resistance at the flow rate of interest, add the radiator’s resistance to the difference between the connector used and the baseline 5/8’ barb.)
Graph 18
Graph 18
The air side has flow resistance as well, and the HE 80, HE 92.1, and the HE 120.2 are compared below:
Graph 19
Graph 19
Since the air flow resistance of the HE 120 series is the same per unit area, at the same backpressure the air flow volume of the HE 120.1 would be half of the HE 120.2, while the HE 120.3 would be 50% more than the HE 120.2.
Bill Adams
Discussion and Conclusions
The ThermoChill radiators are extremely well built, compact and convenient to use due to the built-in shroud, threaded connections and bleed screw. The combination of these features is unique and affords the watercooling enthusiast a range of solutions to fit any cooling need.
No single ‘value’ is proposed as a rating as there is no even nominal consensus within the watercooling community (I hesitate to say ‘Industry’) as to the characterization of testing and rating conditions. My considered opinion would be to use 3.8 lpm (1.0 gpm) as the coolant flow rate and 10°C as the air to coolant temperature differential. (Note that this conflicts with the testing done for this report. Converting to a 10°C basis would double the dissipation values shown in the graphs; the C/Ws are the same.)
Unfortunately this does not in any way resolve the issue: What is to be the air flow for the ‘rating’ conditions?
Despite my reluctance, and conservatism, the radiators ‘need’ a rating. I would suggest the following:
The defined rating conditions are:
  • 10°C coolant / air differential
  • 3.8 lpm (1.0 gpm) coolant flow rate, and
  • a high performance fan (or fans, mounted on one side only).
Under such conditions the radiators would have the following ratings:
Table 1
Model
Dissipation
°C/W
HE 80.1
100 Watts
0.104
HE 92.1
150 Watts
0.070
HE 120.1
250 Watts
0.039
HE 120.2
400 Watts
0.024
HE 120.3
550 Watts
0.015
Note that the radiators are capable of dissipating more heat than indicated above – the coolant temperature will simply rise until equilibrium is achieved.
A particular difficulty in optimizing radiator performance lies in the area of fan selection. This difficulty is compounded when fan noise is a primary, or significant, concern. Despite the universal existence of fan data sheets, replete with P-Q curves, it is often the case that a specific fan will deliver appreciably better performance than others having similar specs.
The reason for this is not understood by this investigator, but one conclusion is clear: For low noise applications the fan – radiator combination must be tested to assure adequate performance. And if such testing has been done, end users for whom low noise is a primary concern certainly should utilize the specific fan recommended.
Worth remembering: “It is all about air flow, i.e. getting the heat out of the rad. You want to reach the knee of the C/W curve.” **
Many thanks to Karl Smith and more information on the radiators can be found at the ThermoChill website.
**Observation, and more corrections, courtesy of Ralph Nelson.
  1. Replacement Shroud for Thermochill HE120.2 series Radiators
  2. DIY Radiators
  3. Finding and Using Radiators, Part I
  4. Perma-Cool vs Senfu Radiators
  5. Thermochill TA120.3 Review
Tags:
