Antec Jet Cool
Add Your Comments
SUMMARY: A very interesting design, but performance lags well behind the current crop of high performance Socket A heatsinks.
Antec Jet Cool
Measurements: 62mm diameter by 49 mm high; weight 200 grams.
The good folks at ANTEC sent us some heatsinks and a very nice case (review in the works) to test out. Antec has designed a series of heatsinks with the “Jet Cool” label. These feature aluminum fins surrounding a copper core (29 mm diameter by 34mm high). This is not a Delta 38 screamer – the fan is rated at 24 cfm and 35 dBA.
I tested the Jet Cool rated up to 1.5 GHz for Socket A CPUs. Antec indicates a C/W of 0.53 on their literature, definitely on the high side of 0.30 C/W (our recommended minimum for Socket A CPUs). This means that a 70 watt CPU will rise about 37C over ambient.
The copper base came with a thermal pad; I removed it with some difficulty – this was the most onerous pad to remove I have seen to date. I used a razor blade and then cleaning fluid to get all traces off the copper base.
Base
The aluminum fins are not bonded to the copper core; in fact, they can be rotated around the core by hand. Note that air flow is through the fins to the CPU carrier. Heat transfer from the core to the fins is aided by using thermal grease between the base of the aluminum fins and the core, as shown in this closeup:
Detail
The white stuff is the thermal grease between the fins and core. The efficiency of this joint depends on pressure, the thermal efficiency of the grease, and the fit between the fins and the core. Over time, I would be concerned that the grease might run or dry out, greatly impacting performance.
With airflow directed at the CPU’s carrier, you might expect to see some “interesting” temps from the in-socket thermistor. The Antec did not disappoint – as you read through the performance tests, you will see a marked difference between temps at the CPU/back and the MBM readings. If you were to calculate C/Ws from the MBM temps with the Iwill KK266+, you get 0.22 – quite a contrast to Antec’s stated C/W of 0.53.
Clip
The clip is a good one – plenty of space to get your fingers on it and fairly easy to mount and dismount. The trick here is to rotate the heatsink to its final position and then push down on the clip to engage the socket’s lugs.
THE TEST
I prepared the Antec Jet Cool by boring a hole through the base sideways and then through the top of the base to the side hole, so I could epoxy a thermocouple above the CPU; removing the fan is difficult, so I chose this method instead.
The thermocouple is attached to an Omega HH23 Digital Thermometer. Ambient temps were measured with a thermocouple placed about 1 inch from the fan’s intake. I used Prime 95 to stress the CPU on an Iwill KK266, BD133 (MBM temps are on-die) and Abit KT7. Arctic Silver grease was used in all tests. CPU Case Temp is the temp at that point where the CPU contacts the heatsink, CPU Back Temps are measured by a thermocouple on the center back of the CPU.
In this test, I started at 700 MHz with the T-Bird 133 and worked up to 1300 MHz in 100 MHz increments – I’m just showing three of these steps – the results averaged 0.40.
TEST RESULTS
CPU/Motherboard
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
CPU Back Temp
T-Bird @ 700/Iwill KK266+ (39 watts)
43.6 C
27.3 C
16.3
0.42
36 C
44.6 C
T-Bird @ 1000/Iwill KK266+ (67 watts)
54.3 C
28.0 C
26.3
0.39
43 C
56.2 C
T-Bird @ 1300/Iwill KK266+ (93 watts)
64.2 C
28.9 C
35.3
0.38
50 C
67.0 C
Duron @ 1000/ABIT KT7 (63 watts)
59.0 C
28.3 C
30.7
0.49
52 C
56.5 C
PIII @ 933/Iwill BD133 (26 watts)
42.3 C
29.7 C
12.6
0.49
49 C
NA
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Compared to Antec’s stated 0.53 C/W, this test series showed better performance with the T-Bird, although the smaller die Duron and PIII resulted in C/Ws closer to Antec’s.
CONCLUSIONS
While a very interesting design, I think the bond between the aluminum fins and the copper core contributed to its less than stellar performance, compared to other high performance heatsinks. No doubt a Delta 38 would make a difference, but I don’t think the combination would be as attractive as some other options.
The Antec performed pretty much in line with what Antec indicated. This is not an overclocker’s heatsink and falls short of what I would recommend for aggressive Socket A cooling.
Thanks again to ANTEC for sending this our way.
Email Joe
Leave a Reply
