Like it says – Joe
SUMMARY: Anything but the “razor blade” works well.
Applying thermal grease to get a uniform pattern is an important part of getting the most out of CPU cooling. It used to be that the accepted method was to apply a thin coat using a razor blade of the edge of a credit card. Most performance thermal compounds in use today are lightly bulk loaded thin or wet compounds that spread easily, but a compound that has a bulk loading >90% will not spread using the razor blade technique.
Alternatives to the razor blade have included a number of patterns. To ascertain how effective these are, I applied thermal grease (Tuniq TX2) to a pane of glass and then clamped a second pane over it to simulate heatsink clamping to a CPU’s IHS. It was baked for about ten minutes at 150ÂșC to accelerate spreading. I tried five different spreading schemes:
- Razor blade
- Straight line
- Pea size
- Rice gain size
- “X”
The following pic shows these patterns:
After clamping and baking, the following pic shows how the grease patterns fared:
The WORST pattern was the razor blade – blame my application technique, but when you think about it, any ridges or gaps in applying grease may result in coverage gaps – a closer view:
Of the other techniques, all of them will spread nicely over time. I think, however, the best method is to use any technique that starts with grease in the center of the IHS and spreads from there. Personally I believe the best technique is the “pea” approach – this concentrates grease over the hottest point of the IHS (the center) and spreads out uniformly from there. Any excess will be squeezed out.
CONCLUSIONS
Forget the razor blade and go for the pea.
Related posts:
- Five Thermal Grease Test
- Thermal Grease– Optional?
- Thermal Grease Test
- Silver Thermal Grease Test
- EVGA Frostbite Thermal Grease for Sub-Zero Overclocking
Tags: Cooling
10-27-10 01:14 PM
10-27-10 01:20 PM
tons of reviews out there, this one's good, if a bit limited...
http://skinneelabs.com/tim2010part1.html
mx2 is sorta being surpassed now and falling to artic silver 5's place as the old top dog.
10-27-10 01:52 PM
YMMV
10-27-10 02:09 PM
I tried it and works very nice the pea method(rated the best due to not bubbles of air)
If there is something wrong with it let me know
http://www.youtube.com/user/yaochoon#p/u/17/ffK7L0Qj13Q
10-27-10 02:20 PM
For a TIM review to be really meaningful, recording and reporting things like this are important in order for the reviewer to understand how much variation there is:
http://skinneelabs.com/tim2010part1.html?page=4
The big TIM roundups mostly get it wrong, because the amount of time required to do it right is prohibitive for actually doing it. That's why Cam only did a limited number of products here.
10-27-10 03:23 PM
10-27-10 04:08 PM
12-01-10 12:52 AM
Anyhow... mort, think about that milled IHS for a minute, how does that affect surface area or TIM spread, and so on? There are many reasons why we do not mill the IHS's on our chips.
Robots, yup, pretty much (no sarcasm, it is the truth). And to make matters worse, we're both in an automation kick trying to remove all the manual steps we possibly can.
12-01-10 01:02 AM
12-01-10 01:26 AM
I think the initial batch of 7 TIM's (I think we're up to 50+ in total) will be out around Xmas time, but I'm 99% sure there are changes coming to the current TIM bench. We've settled on 5 mounts at three different mount pressure/contact settings (think bondline thickness), so a total of 15 mounts, each at 10 hours duration. The change I spoke of will be in one of the pressure/contact settings... just didn't turn out like initially planned.
BTW, the amount of awesome data coming from the TIM bench is going to make your head spin. Vapor may have grown a bit tired of me asking questions as we were going through the initial data.
12-01-10 01:36 AM
12-01-10 03:46 AM
12-01-10 05:59 AM
Lot's of people do things they haven't really reliably tested... Often times people tend to think something is better, but they don't have the means or process to accurately observe differences and gauge results. More often than not, people prefer the way they do things, regardless of what may have been demonstrated elsewhere to "be better".
12-01-10 06:38 AM
As far as the video and thermal compound application is concerned:
1. In many of the shots the TIM was applied too thick or not spread completely by the pressure the person applied.
2. TIM is only designed to fill the imperfections between the heatsink and CPU heat spreader and should be as thin as possible and providing 100% contact on the heat spreader
3. Different TIMs spread differently based on viscosity and chemistry
4. All TIMs flow with heat meaning that what you saw in the video changes with heat/pressure and time
5. The air trapped in the first application appeared to be induced by the bending of the plexiglass used to show the spreading action. There was also way too much TIM which is why air could remain between the heatsink and plexiglass
6. While the highest heat is concentrated in the center of the CPU heat spreader any of the methods that do not cover the entire CPU heat spreader with a very thin layer of TIM may be giving up a bit of thermal conduction and thus CPU cooling?
In my instrumented testing of heatsinks and TIMs over many years the best results come from using the thinnest TIM application (almost translucent in appearance), evenly spread across the entire CPU heat spreader. That being said the difference in CPU temp between just enough TIM and too much IME is typically 1-2 C max. A small tube of TIM last me for many CPU applications.
The reason why you want the thinnest application of TIM is because even the best TIM is not 100% thermally conductive. Thus the the thicker the TIM the less efficient the heat transfer compared to 100% contact of the CPU heat spreader and heatsink.
People are free to use whatever TIM and application method makes them happy. I'm just the messenger so use the info. as you please or completely discard it.
12-02-10 04:56 AM
What is the best solution?
I always put a small drop on the cpu and the tim never went outside of the surface nor wasn't fully applied on it...
12-04-10 07:15 PM
Ive tried a few diff application techniques, and the pea works for me the best with IC7.
Hey skinnee nice Greyhound, I have one too
12-05-10 09:41 PM
i was going to write one up for the community. looks like you beat me to it
12-05-10 09:49 PM
