Kit Test – Joe
SUMMARY: Versatile, easy to mount two-piece entry level watercooling kit.
The good guys at Eastar Trading GmbH (Germany) were nice enough to send a sample of their Aquamate watercooling kit to try out. This is a compact two-piece kit – the waterpump is integrated into the waterblock as a single unit. The kit includes parts for LGA775, AMD 64 S754/S939/S940, P4 478, AMD S462 and Intel Xeon. The kit comes fully charged with liquid, so there is no filling involved.
System Specs:
- Waterblock and Pump:
- Size: 50 x 50 x 77 mm
- Power: 4 watts
- Pump Specs: 500 L/hour waterflow, head 1.5 meters
- Weight: 200 grams
- Life Expectancy: 50,000 hours
- Connector: 3 Pin
- 120 mm Radiator:
- Size: 160 x 120 x 40 mm
- Material: Aluminium
- Fan Power: 1.8 watts
- Fan Speed: Variable 1200 – 1900 rpm
- Connector: 3 Pin
- Fan Size: 120 x 120 x 25 mm
Related posts:
- Aqua Joe Watercooling Kit – Preliminary Test
- Watercooling Kit Mods
- AMA Aragon 900 Watercooling Kit
- Watercooling Case and Kit Roundup
- Titan Watercooling Kit TWC-A04
Tags: Cooling
