Chipset Waterblock Test – Joe
SUMMARY: OK choice for chipset cooling, although pressure drop may be a problem.
The good guys at Asetek were nice enough to send a Chipset Waterblock to test out.
Asetek’s Chipset Waterblock features
- 10mm/½” push-on fittings
- 3/8″ thick acrylic top
- finger screw mounting
- Copper base
The base of the quick connect fittings used in the system are a bit smaller than the 3/8″ ID of the tubing – they measure 9/32″ at the widest point:
The base
appears well machined – I could feel no ridges.
The Asetek Chipset Waterblock was tested using the CPU Die Simulator and Waterblock Test Rig.
| Waterblock |
C/W
Pressure Drop – psi
Pressure Drop – inches H2O
| Asetek Chipset Waterblock |
0.19
0.68
18.8
Unrounded data: 0.187 C/W with 0.0014 std dev.
Test Results indicate that the Asetek’s pressure drop (or head loss) across the waterblock is moderate; flow resistance at this level means that it should daisy-chained with a low pressure drop CPU waterblock. Decreasing waterflow to 0.5 gpm increases die temps by about 2.5º C, while increasing flow to 1.5 gpm decreases die temps by 1.6º C.
For a comparison of the Asetek’s performance to other chipset waterblocks tested to date, see Overclockers.com Waterblock Test Results.
Asetek’s Chipset Waterblock is an OK choice for chipset cooling, although its pressure drop could be a problem daisy chained with a high pressure drop CPU waterblock; at a minimum, adding chipset and GPU waterblocks will require a larger waterpump to extract top performance.
Thanks again to Asetek for sending this our way.
Related posts:
- Asetek Waterblock Review
- Asetek Antarctica Waterblock – Retail
- Danger Den Chipset Maze4 Waterblock
- Asetek Waterblock
Tags: Cooling
