Asetek Waterblock
Add Your Comments
SUMMARY: Good choice for CPU cooling.
WB
The good guys at Asetek were nice enough to send a WaterChill kit to test, which includes Asetek’s WaterChill CPU Cooler.
Asetek’s WaterChill CPU Cooler features
  • 10mm/½” fittings
  • 3/8″ thick acrylic top
  • AMD and P4 mounting
  • Copper base
  • “Half Moon” interior design
  • “Quick Connect” fittings
The base of the quick connect fittings used in the system are a bit smaller than the 3/8″ ID of the tubing – they measure 9/32″ at the widest point:
Nip Base
The base features a “half moon” design:
Half Moon
Machined into the base is a semicircular wall located off to the side of the intake fitting. This serves to increase turbulence within the block. The light streaks you see in the picture are machining marks from the cutting tool used to hollow out the base – these are small ridges in the base.
The base
Base
appears well machined – I could feel no ridges.
THE TEST
The Asetek WaterChill CPU Cooler was tested using the CPU Die Simulator and Waterblock Test Rig.
WATERBLOCK TEST RESULTS
Test Conditions: Inlet Water Temp: 28.5 C; Mounting force: 15 pounds; Heat Load: 70 Watts.
Plot
Waterblock
C/W
Pressure Drop – psi
Pressure Drop – inches H2O
0.20
0.56
15.5
NOTE: These results are NOT comparable to tests done by others.
Unrounded data: 0.204 C/W with 0.0018 std dev.
Test Results indicate that the Asetek’s pressure drop (or head loss) across the waterblock is moderate; flow resistance such as this means that it should function well without using a large waterpump.
For a comparison of the Asetek’s performance to other waterblocks tested to date, see Overclockers.com Waterblock Test Results.
CONCLUSIONS
Asetek’s WaterChill CPU Cooler is a good choice for CPU cooling. In addition, with moderate flow resistance, it will perform well with moderate power waterpumps, as long as other components do not unduly restrict waterflow.
Thanks again to Asetek for sending this our way.
Email Joe
Leave a Reply
