Asetek WaterChill CPU/VGA/Chipset Power Kit – KT12AT-SL35
Kit Test – Joe
SUMMARY: Superb performance, quality components – an excellent performance kit from the Land of Hamlet.
Kit
Forsooth – the melancholy Prince of Cool, Lord Asetek, hath graciously sendeth unto me a sample of their WaterChill CPU/VGA/Chipset Power kit to my humble abode forthwith with the intent upon their noble minds for me to test and evaluate such as was unto me delivered – a noble endaeavor indeed.
To watercool or not to watercool – that is the question. Whether ’tis nobler in the mind to suffer the slings and arrows of outrageous noise, or to take arms against a sea of troubles, and by watercooling, end them.
I pray you all, season this admiration for a while with an attent ear till I may deliver upon you the witness of this marvel to you.
Key Features:
  • WaterChill CPU Cooler Antarctica block supporting Intel P4 LGA 775 (Socket T)
  • WaterChill Chipset cooler block NB01/P1 supporting Intel, AMD, SIS and VIA chip sets
  • WaterChill VGA cooler block VGA02/P1 supporting Nvidia/Gforce ad ATI/Radeon AGP cards
  • Black Ice Pro TRIPLE Radiator with push on fittings
  • 3 X 120 mm Low Noise Adda Fans
  • 900 liter/hr SACEM Pump with push on fittings
  • WaterChill Control Unit with SafeStartTM, 7 & 12 volt connectors and LED pin
  • WaterChill Plexiglas Reservoir
  • WaterChill Tube Set – 3 meters
  • ALL fittings and mounting accessories are included
  • WaterChill Anti-Algae Fluid – WaterWetter [10ml bottle]
  • Heat Conduction Compound – 2 ml tube
  • Instruction Manuals
Kit Overview
The waterpump inlcudes an acrylic reservoir
Waterpump
and a relay assembly which turns the pump on and off with the PC; in addition, there are 7 and 12 volt settings for the fans:
Relay
The waterblocks include CPU, GPU and chipset:
WBs
The CPU waterblock is the Antarctica:
CPU In
There is a slot which directs the water over its channels. The base is quite good:
Base
However, I could feel slight ridges as I dragged my fingernail over it.
{mospagebreak}
Both the VGA
VGA
and Chipset waterblocks feature “fences” to channel waterflow.
Chip
Finally, the parts shipped with the unit
Parts
are almost enough to open a hardware store – everything is included for setup. The instruction manuals are thorough and cover how to test run the system. Note that the hoses must be pushed all the way into the fittings – one looked OK but leaked, as it was not in all the way. As always, make sure the connections are tight; if not, this bodes some strange eruption to our state.
The Test
Asetek’s WaterChill Power Kit was tested using the CPU Die Simulator; I ran the fans at 7 and 12 volts. I tested the kit using only the CPU waterblock; adding in the GPU and Chipset blocks will marginally degrade performance.
Kit
Die Temp
Ambient Temp
Delta
C/W
Asetek – Fans @ 7 Volts
32.8 ºC
20.7 ºC
12.1 ºC
0.17
Asetek – Fans @ 12 Volts
32.1 ºC
21.1 ºC
11.0 ºC
0.16
Since brevity is the soul of wit, and tediousness the limbs and outward floursihes, I will be brief – let the world take note, Asetek’s WaterChill Power Kit is the most immediate to our throne of watercooling kits (Heatsink Ranking) tested to date.
CONCLUSIONS
What news, my lord? Something is not rotten in the state of Denmark. If you’re thinking of buying a performance watercooling kit, let thine eye look like a friend on Denmark – Asetek’s WaterChill Power Kit is top ranked, in the gross and scope of my opinion.
(With apologies to Bill S.)
{mospagebreak}
A number of readers asked that I do a test with the GPU and Chipset waterblocks in place and compare these results to the system with only the CPU waterblock. The following resulted:
The Test
Kit
Die Temp
Ambient Temp
Delta
C/W
Asetek – Fans @ 7 Volts – CPU WB Only
31.1 ºC
19.2 ºC
11.9 ºC
0.17
Asetek – Fans @ 7 Volts – CPU, GPU and Chipset WBs
31.2 ºC
18.6 ºC
12.6 ºC
0.18
Asetek – Fans @ 12 Volts – CPU WB Only
32.2 ºC
20.9 ºC
11.3 ºC
0.16
Asetek – Fans @ 12 Volts – CPU, GPU and Chipset WBs
32.6 ºC
21.0 ºC
11.6 ºC
0.16
CONCLUSIONS
Adding the additional blocks marginally degrades performance, not enough to really make a substantial difference at the desktop. One reason that the difference is so slight is that the waterpump has enough “overhead” so that the added pressure drop minimally impacts performance, as well as the radiator. Systems with lesser waterpumps will show a much greater performance hit.
Email Joe
Be the first to comment
Leave a Reply
