ASRock Z68 Extreme4 Motherboard Review
Today will we be taking a look at ASRock’s flagship Z68 motherboard, the Z68 Extreme4. Prior to the Z68 chipset’s release on May 11th, one had to choose between using the iGPU on the Sandybridge-based chips (H67 chipset) or overclocking and not using the iGPU (P67 chipset). Z68 chipsets, this motherboard included, have also added some new features such as Intel Smart Response Technology which helps mechanical hard drives perform much faster by using a portion of an SSD as its cache, as well as Lucidvirtu technology which ‘dynamically assigns tasks to the best available graphics resource based on power, performance, and features’. Since we can now have the best of both worlds, lets see how the ASRock Z68 Extreme4 motherboard performs.
Asrock Z68 Extreme4.
ASRock Z68 Extreme4
Packaging and First Look
ASRock has chosen to go with a dark brown pcb with grey/graphite heatsinks along with Blue and White PCIe/PCI slots.
Asrock Z68 Extreme4 Box Front
ASRock Z68 Extreme4 Box Front
Asrock Z68 Extreme4 Box Rear
ASRock Z68 Extreme4 Box Rear
Asrock Z68 Extreme4 Box Inside
ASRock Z68 Extreme4 Box Inside
Unboxed Front
Unboxed Front
Unboxed Rear
Unboxed Rear
Accessories
This top of the line offering from ASRock comes with a generous helping of accessories including SATA3 cables, Molex to SATA power connectors, 2 card CrossfireX connector, and even a floppy ribbon. A couple of special additions are a front USB3 panel that fits in a 3.5″ space on the front of your case (and will also hold a 2.5″ drive, like an SSD). ASRock has also included a 1/8″ to 1/8″ plug for use with On/Off Play Technology.
Accessories
Accessories
Tour of the board
First you can see the Socket layout (Lotes socket for the record),  VRM’s, and ram slots and onboard CLRCMOS jumper in case you get hosed with an extreme overclock (also a button on the I/O panel for those that use a case). In the third picture you can see a really neat feature in my eyes. ASrock included DUAL CPU fan headers towards the top of the board. This is great for those running, you guessed it, dual fans on the CPU heatsink.
Socket area
Socket area
Ram slots
Ram slots
Dual CPU fan headers on the motherboard
In the next shot you can see the Power, Reset, and Debug LED ASRock has put on this board. These features help the case-less benchers not have to jump the headers to reset or power off/on the CPU. The debug feature can help everyone in case there is an issue with the board. These light up a nice red color. Also featured is the heatsink cooler for the PCH (Platform Controller Hub)
Featured below are the rear I/O ports, SATA ports, as well as a picture of the headers on the bottom of the motherboard for USB, front panel audio, case swiches and lights. Front 1394 and even a legacy floppy header (connector included) also come standard. Notice how this board has DVI and VGA ports for use with the onboard graphics Sandybridge offers.
I/O ports
I/O ports
Bottom headers (USB/1394/Audio/Front panel power/reset/hdd etc)
Sata ports
Sata ports
I decided to take of the heatsinks on the board to see what was going on below. Glad I did this, as it seems that the heatsink was not making contact with all the VRM’s properly. I am sure this was an anomoloy out of the factory, but it never hurts to tighten them down a bit with any motherboard you receive. Tightening them down did fix this situation and after pulling them off again showed proper contact.
Socket area without the heatsink
Underside of heatink assembly (note contact in most areas, but not in all)
Specifications and Features
Courtesy ASRock
  • ASRock DuraCaps (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
  • Digi Power, Advanced V8 Power Phase Design
  • Supports Intel K-Series unlocked CPU
  • Supports Intel Smart Response Technology
  • Supports Dual Channel DDR3 2133(OC)
  • Integrated PLX PEX8608 chip onboard to offer sufficient PCI-E lanes
  • Supports ATI Quad CrossFireX , 3-Way CrossFireX and CrossFireX
  • Supports NVIDIA Quad SLI and SLI
  • Supports Intel HD Graphics with Built-in Visuals
  • Multi VGA Output options: D-Sub, DVI-D, HDMI and DisplayPort
  • 2 x Front USB 3.0 ports, 2 x Rear USB 3.0 ports, 4 x SATA3 connectors, 1 x eSATA3 connector
  • Supports ASRock XFast USB Technology, Graphical UEFI, Lucid Virtu
  • Supports ASRock Extreme Tuning Utility (AXTU), On/Off Play, Instant Boot, Instant Flash, Good Night LED, APP Charger, SmartView
  • Combo Cooler Option (C.C.O.)
  • 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec), THX TruStudio PRO
  • Free Software: Cyberlink MediaEspresso 6.5 Trial
  • Free Bundle : 1 x Front USB 3.0 Panel, 1 x Rear USB 3.0 Bracket, 1 x 3.5mm Audio Cable
UEFI Bios
ASRock is also using a UEFI bios (Unified Extensible Firmware Interface). This type of BIOS, as you can see below, has a very nice GUI as opposed to the typical blue and white almost DOS based BIOS of the ‘past’. This BIOS also allows one to use their mouse to click around instead of exclusively using the keyboard. I noticed on my system that there was a slight delay on mouse movements and clicks, but it was an easy thing to get used to. You can also boot from a 3TB HDD with a supporting OS with this BIOS.
There are PLENTY of options for overclockers available here as well. DRAM timings and subtimings, Multiplier, bclk,  the all important PLL override voltage to push extreme clockspeeds and just about any other option full featured motherboards offer.
Bios - Main Page
Bios - Main Page
Bios - Overclock Tweaker (Top)
Bios - Overclock Tweaker (DRAM)
Bios - Advanced
Bios - Advanced
Bios - Hardware Monitor
Bios - Boot Setup
Bios - Boot Setup
AXTU Software
Below you can see ASRock’s all-in-one software tuning application dubbed AXTU (ASRock Extreme Tuning Utility). It’s function, as others just like it, are to control and fine tune different features such as fan control, overclocking options and voltages, OC DNA (Shows bios version and saves user profiles – even share with your settings with friends using the same system), as well as power saving features in a user-friendly interface. As you can see below the interface is straight forward and was very easy to use. The major features overclockers are looking for are present and accounted for. I was unable to adjust bclk from windows, but the multiplier and all voltage adjustments worked fine.
AXTU Hardware monitor
AXTU Fan Control
AXTU Fan Control
AXTU OC DNA
AXTU OC DNA
AXTU IES
AXTU IES
AXTU Overclocking
AXTU Overclocking
Overclocking
Test Setup
  • i7 2600k
  • ASRock Z68 Extreme4
  • GSkill RipjawsX 2133 7-10-7-27 1T, 1.65v @ 1866Mhz
  • HIS 6970 IceQ Turbo
  • Seasonic X750
As most who have Sandybridge chips know, overclocking with this generation of CPU is not exactly the tweak-fest it used to be in order to achieve high clockspeeds out of the CPU. For most users hitting a stable 4.4-4.6Ghz overclock is as simple as leaving the voltages on auto except for Vcore, setting your memory speed, timings, and voltage manually if your XMP profile doesnt want to play nice and of course having adequate cooling. The ASRock Z68 Extreme4 has all the parts to make it happen and then some. It even has an auto overclock feature that you can select from 4.0Ghz to 5Ghz. Using this feature allowed a nice stable overclock to 4.8Ghz (stable under Prime95 Blend for 2 hours). Not bad for just pressing a button!
Pushing past the realm of 24/7 overclocking into the 5Ghz+ range requires a little more bravery with voltage and a few extra adjustments. Overclocking from the bios to 5.4Ghz was still quite simple with this board. I ran in to only one snag. When running 5.4Ghz with heavy CPU loads, the CPU kept throttling back to 40x multiplier. After some help from my peers here, as well as some deeper BIOS sleuthing, I found that as well as setting the “Core Current Limit” to 300 watts (could likely be less), you must enable Speedstep in the bios. In doing so, two more options become available, called Short Duration Power Limit, and Long Duration Maintain. I set both power limts to its max of 300W and left the Long Duration on 1(second). This stopped the multiplier dropping issue and let the fun continue.
Pushing the Envelope/Benchmarking Results
I had no motherboard related issues at all hitting my CPU’s watercooled limit. There was only one difference on this board versus another, more expensive board that made me raise an eyebrow. Where on this other board, I needed 1.51v to run 5.4Ghz with Hyper-Threading ‘benchmark stable’ I needed around 1.55-57v loaded to achieve the same clockspeed on the same benchmarks. Thats not a tremendous difference, but something to note regardless, especially for those who are teetering on the edge of temperature limits where every degree Celsuis counts. Below you will find some results for 5.4Ghz in both 2D (Super Pi 1M/32M, Pifast, Wprime 32M/1024M), and 3D (3DMark06, 3DMark05, and Unigine Heaven -Hwbot version). The benchmarks were all completed in a full install of Windows 7 64bit. The times/scores for these benchmarks compared to other boards seemed well within a ‘margin of error’. Only the best runs are shown.
SuperPi 1M - 6.940s
SuperPi 1M - 6.940s
Super Pi 32M - 6:24.580
Wprime 32M - 4.608s
Wprime 32M - 4.608s
Wprime 1024M - 2:23.721
Pifast - 13.72s
Pifast - 13.72s
3DMark05 - 45288
3DMark05 - 45288
3DMark06 - 34728
3DMark06 - 34728
Unigine Heaven (for Hwbot) 1813.703
Final Thoughts and Conclusion
As you should be able to tell by now, the ASRock Z68 Extreme4 is a feature-laden board that should be able to please just about anyone. It has the ability to overclock with the best of them, as well as packing a several great features. One in particular I would like to mention here is the ON/OFF Play technology. This is a great feature for those who have any music player, be it iPod, or like myself, an Android phone, and would like the audio to play through your PC speakers with the PC on OR off! It was nice to be able to stream Pandora, or my Sirius radio right from my phone to through these speakers. Because I had the PC off, I was saving a fair amount of energy and eliminated the back round noise of my PC. The z68 Extreme4 also sports the new LucidVirtu technology, Xfast USB (boosting your USB speeds), and Intel Smart response Technology (speeds up mechanical hard drives, by using a solid state drive as cache – See this Anandtech.com review on the technology).
Currently the Z68 Extreme4 is available online at newegg.com for $189.99 + SH. This is not a bad price at all for such a robust board. With all the new features the ASRock Z68 Extreme4 has to offer, as well as its very solid overclocking ability, this board should be a consideration for a wide range of PC users and enthusiasts alike. With that said, this board has been Overclockers Approved!
- Earthdog
Tags: , , ,
Leave a Reply
You may use these HTML tags and attributes: <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <strike> <strong>
