ATi HD 5870 Review
I think the price is more than fair enough considering it’s the single most powerful GPU on the market right now. If you’re thinking about picking up a new video card but are short on funds, I would wait a few months until ATI/AMD drops the price on this card. I would expect to see a price drop sometime in December or January.
Coming from an nVidia background, I really didn’t know what to expect from this video card. That being said, I am glad with my purchase! I have been out of the “red” ATI community for quite some time now and was quoted as saying “green 4-life”, that is until I saw what this card is capable of. I have to be honest and say that the nail in coffin for me was the EyeFinity Technology. I have been waiting for some time now for this to be released on a single video card without having to buy a Matrox Triple Head card.
Here’s my test bed:
*GPU* Sapphire Radeon HD 5870 1000 MHz/1300 MHz (core/RAM)
*CPU* Intel Core i7 D0 920 @ 4.3 GHz /Dark Knight
*MB* GIGABYTE GA-EX58-UD3R rev.1.0 Bios F5
*RAM* G.SKILL 6 GB DDR3 1333 F3-10666CL9T-6GBNQ /OCZ Memory Cooler
*PSU* Corsair TX750w
*Storage* Seagate Barracuda 1TB x2 RAID1 ST31000333AS
*Display* (3) Samsung 2333SW 23Inch Widescreen
A Look at the Video Card:
alt
alt
alt
alt
Size Comparison Shot next to GTX 26:
alt
Make no mistake; the video card is fairly huge, roughly 11 inches long. You might want to measure out your case and make sure you have enough room to fit the card, as well as making sure there is sufficient airflow to cool it. That being said, the video card at about 35% fan speed leaves the card idling @ 44-46°C. If you’re looking for an example of loudness, (2) GTX 260′s come nowhere near to the amount of noise the 5870 makes at 100% fan speed. The 5870 sounds like an F-22 on takeoff when it is at 100% fan speed. Some of you may ask “Why would I even have it at 100%?” The answer is simple – you really shouldn’t unless you are gaming or running benchmarks.
Also a question I had before I bought my 5870 was, can you use 4 displays on the card as long as you toggle off one of the active displays?
The Answer is yes! you can hook up 4 screens and use all 4 of them but only 3 at the same time and if you use 3 at the same time, one of them must be the display port connection.
Benchmarks I ran:
3DMark Score/Dj Spiel’s RIG:
21,729 3DMarks
Screen Shot of Dead Space @ 3840×1080 all settings maxed out!
alt
I took videos of:
Crysis Bench Mark/ATI Eyefinitys Technology
Dead Space @ 3840×1080 Resolution *SETTINGS HIGH*
Dead Space @ 3840×1080 Resolution *SETTINGS HIGH/EXTERNAL VIEW*
“Tri Monitor Gaming”
Wolfenstein :
alt
COD4:
alt
Need for Speed: Shift:
alt
Painkiller:
alt
UT200:
alt
You can view the original thread HERE.
  1. Reinventing The ATI 5870
  2. ATI Radeon HD5870 Eyefinity6 Review Roundup
  3. Gigabyte Radeon HD 5870 SOC (Super Overclock) Review
  4. ASUS Matrix 5870 Platinum Review
  5. ATI Radeon HD 5550 GDDR5 Review
Tags:
