be quiet! Dark Rock Pro 2 Review
Add Your Comments
Last time around we took a look at be quiet!’s top-down heatsink, the Shadow Rock TopFlow, which performed well, but had a few clearance issues. The Dark Rock Pro 2 is the next heatsink to go through testing. This heatsink uses the large dual-tower design that has become popular as of late for its performance. So, let’s dig in and see what else be quiet! has to bring to the US market!
Specifications & Features
(Courtesy of be quiet!)
Main Specifications
Overall Dimensions 147 x 138 x 166 mm (L x W x D)
Total Weight 1.25 kg
TDP 220 W
Socket Compatibility Intel: LGA 775/1155/1156/1366/2011/1150
AMD: FM1/FM2/AM2(+)/AM3(+)/754/939/940
Backplate Mounting Yes
Fans 1x Silent Wings PWM 120 mm, 1x Silent Wings PWM 135 mm
Overall Noise Level 13.50/19.80/26.40 dBA (900/1250/100% RPM)
Heatsink Specifications
Dimensions 133 x 124 x 166 mm (L x W x D)
Number of Fins 44
Fin Material Aluminum
Base Material Copper
Contact Surface CNC Machined
Heatpipes 7 x 6 mm
Surface Treatment Aluminum/Dark Nickel Plated
Fan Specifications
Fan Dimensions 135 x 135 x 25 mm, 120 x 120 x 25 mm
Silent Wings Yes
Speed @ 100% 1500 RPM, 1700 RPM
Air Flow @ 12 V 67.8 CFM (113.8 CMH), 57.2 CFM (93.3 CMH)
Air Pressure @ 12 V 1.82 mmH2O, 2.1 mmH2O
Bearing Type Fluid Dynamic
Rated Voltage 12 V
Input Current 0.25 A, 0.20 A
Input Power 2.64 W, 2.40 W
Connector 4-pin PWM
Cable Length 250 + 150 mm, 200 mm
Life Span 300,000 h/25 °C
Service
Warranty 3 Years
No Compromise Silence and Performance
The virtually silent Dark RockTM Pro 2 CPU Cooler puts our famous anti-noise technology where it counts: at the heart of your system. Its double tower, double fan design is perfect for overclocked systems and the most demanding multi-graphics platforms.
Twin quiet-optimized SilentWings® 2 fans with PWM function and seven ultra-high performance heatpipes generate massive 220 W TDP cooling capacity and strikes the perfect balance between intense cooling and deep serenity. Special wave-contoured heatsink fins further minimize noise-inducing turbulence while maximizing heat transfer.
Dark Rock Pro 2: offering the greatest performance-to-noise ratio and highest reliability available.
Very quiet operation
135 mm inner and 120mm front SilentWings® fan with PWM function for optimized fan speed throughout the entire working range provides the perfect balance between superior cooling and quiet. The specially developed wave shaped contour of the heatsink fins optimizes airflow and avoids noise generating turbulence.
Highly effective cooling
Seven ultra-high performance heatpipes with an oxygen-free copper layer help to transport the heat directly to the optimal place of the heatsinks.
First-class materials
Dark nickel-plated metal surfaces and a solid brushed aluminum cover. A stable backplate ensures secure attachment, even when the computer is being transported.
Packaging & Accessories
The box looks pretty good, not gaudy at all. The front has a good picture of the cooler so consumers know what they’re buying, the name “Dark Rock Pro 2,” and the heat dissipation capacity of 220 W. The back of the box goes into more detail with the specifications table and a diagram with top and side views of the heatsink pointing out features. The sides of the box list some high points about the product in five different languages.
Box Front
Box Front
Box Back
Box Back
Box Left
Box Left
Box Right
Box Right
After opening the box, the accessories box rests on top of the well-padded Dark Rock Pro 2. No silica gel this time… The heatsink is protected by two pieces of foam, an L-shaped piece and a flat piece, which form a U shape around the heatsink.
Box Open
Box Open
Nice and Snug
Nice and Snug
The accessories include only what’s needed to mount the heatsink, such as instructions, brackets, screws, nuts, and a backplate.
Accessories
Accessories
Meet the Dark Rock Pro 2
Now we get to take a look at the Dark Rock Pro 2. It’s a rather large heatsink with a similar design of other dual-tower heatsinks, like the Thermalright Silver Arrow, Noctua NH-D14, and Phanteks PH-TC14PE.
Angled View
Angled View
Angled View
Angled View
Angled View
Angled View
Angled View
Angled View
I really like the brushed aluminum top-plate on the Dark Rock Pro 2. They could have rotated the “be quiet!” logo 90° to the right so that it would be right side up when looking into a case window. When looking at the heatsink from the bottom, we can see both towers have the same serrated and inward sloped fins that the Shadow Rock TopFlow used. The fans are installed on the serrated side of the fins from the factory.
Fanless Angled View
Fanless Angled Top View
Fanless Angled Bottom View
On to the included fans. Interestingly enough, the Dark Rock Pro 2 uses two different fan sizes and speeds simultaneously. The outside fan is a 120×25 mm 1700 RPM BQT T12025-MF-PWM fan, and the inner fan is a 135×25 mm 1500 RPM BQT T13525-MF-PWM fan. Something unique about be quiet!’s fans is they don’t have the typical frame of other PC fans. The corners are just single flanges extruding from the center of the fan’s thickness. An obvious downside to this is that the mounting clips can’t be used to mount other fans, so some ingenuity will be needed to get different fans mounted on the Dark Rock Pro 2.
120 mm Fan Intake Side
135 mm Fan Intake Side
120 mm Fan
120 mm Fan Exhaust side
135 mm Fan
135 mm Fan Exhaust Side
Installation
The first step in installation is to attach the brackets to the heatsink base. In my case, I’ll be using the LGA1155/1156 brackets. Each bracket uses two screws to hold it in place, as shown below.
Heatsink Base
Heatsink Base
Brackets Installed
Brackets Installed
Next, the backplate needs to be set up for attaching to the back of the motherboard. There are four screws that need the clear washers to put on them before putting the screws into the correct mounting holes on the backplate.
Backplate and Screws + Washers
Screws Installed
Screws Installed
After the backplate is put in place, clip-on washers are attached to each screw to hold the backplate in place.
Backplate and Washers Installed
Backplate and Clip-on Washers Installed
As with the Shadow Rock TopFlow, I found that turning the Dark Rock Pro 2 upside down and placing the motherboard on top was the easiest way to screw down the heatsink.
Mount Heatsink
Mount Heatsink
Installed
Installed
Potential Clearance Issues
There aren’t as many possible clearance issues with the Dark Rock Pro 2 as with the Shadow Rock TopFlow since it’s not as spread out . However, it does have the most dangerous clearance issue of the fan clips hitting the GPU’s PCB.
RAM
My Dominators, without their heatsinks, just did fit underneath the fan. So, RAM height clearance is right at 43 mm, but that shouldn’t be a problem to the majority of consumers. However, it is something to keep in mind.
Lack of Clearance
Lack of Clearance
RAM Height
RAM Height
GPU
The same clearance issue with GPUs in the top PCIe slot appears with the Dark Rock Pro 2, just as it did with the Shadow Rock TopFlow. The fan clips are touching the screws on the back of the GPU’s PCB, and the heatsink will most likely be installed in this orientation with the fans blowing right-to-left. It can be installed so the air is blowing from the top of the case down to the GPU, but that would counteract the front-to-back airflow of just about all cases out there.
Lack of Clearance
Lack of Clearance
Test Setup & Methodology
Test Setup
Processor Intel i7 3770K @ 4 GHz
Motherboard ASUS Maximus V Gene
RAM Corsair Dominator GT DDR3-1600 6-6-6-20
Graphics Card EVGA GTX 670 SC
Storage OCZ Vertex 2
Power Supply Seasonic SS-1000XP
Equipment
Fluke 52 II Dual Input Thermometer
Tenma Sound Level Meter
NOTE:  The large variance in temps in Ivy Bridge chips due to the TIM-to-IHS interface means that other i7 3770K CPUs could see much lower or much higher temps than my specific CPU.
Methodology
Cooling performance was tested as follows:
  • Disabled all BIOS settings that cause the CPU clock speed and/or Vcore to fluctuate.
  • Arctic Cooling MX2 thermal paste was used for consistency.
  • Both included fans and Gentle Typhoon AP-15 fans were used for testing.
  • Ambient temperature was measured with a Fluke 52 II at ~1 inch from the intake fan.
  • Varied Vcore from 1.050 V to 1.400 V in 0.050 V increments to increase heat.
  • 5-pass 2048 MB RAM LinX  runs at each Vcore interval were used to load the CPU.
  • CoreTemp 1.0 RC4 was used to record minimum and maximum core temperatures.
  • Stopped increasing Vcore once a core reached 90+ °C.
Sound level in dBA was measured 10 cm from the intake fan, and then estimated for other distances using the following formula:
L2 = L1 – 20 * log10(r2/r1)
  • L2 = dBA @ desired distance
  • L1 = dBA @ reference distance
  • r1 = reference distance
  • r2 = desired distance
Why estimate sound level instead of measure at further distances? It’s because the meter I’m using is most accurate between 40-130 dBA, so I wanted to measure really close to the source to make sure I’m in that range to get the most accurate measurements.
Results
Cooling Performance
The competition for the Dark Rock Pro 2, in my testing, is the Prolimatech Genesis using two AP-15 fans. The Genesis is also a dual-tower heatsink, but with one tower parallel to the motherboard and one tower perpendicular to the motherboard. The Dark Rock Pro 2 falls behind the Prolimatech Genesis by ~3 °C on average when using the stock fans, and it’s behind by ~1.7 °C on average when using AP-15 fans. It’s also interesting that the Dark Rock Pro 2 only outperformed the Shadow Rock TopFlow by around 1 °C when both were using their stock fans. I expected a larger gap, but not sure if this is a testament to how good the Shadow Rock TopFlow performs or if the Dark Rock Pro 2 leaves something to be desired.
Rigging up two Gentle Typhoon AP-15 fans  made the Dark Rock Pro 2 perform better by 1-2 °C or so. However, there’s no way to easily mount the AP-15 fans on the Dark Rock Pro 2 because of how be quiet!’s fans are made, so actually trying to swap out the fans for such a small improvement probably isn’t worth the effort to most people.
As in the Shadow Rock TopFlow review, I was hoping to see more of an increased slope in some of the graphed data as Vcore increased, causing the data to spread out towards the end. That would show which heatsinks performed better at the higher heatloads.  However, the i7 3770K is a low power chip, so the heatsinks never seem to get overloaded past their rated TDP. When a heatsink gets overloaded, you’ll typically see a drastic increase in the slope of the graphed temperature data (Example from my Thermalright Shaman review). I look for something like that example in my testing, although not as pronounced for CPUs, to really show which heatsinks are better.
temp_drp2
Sound Level
As mentioned before, sound level in dBA was measured at 10 cm (~4″) from the intake fan, then estimated for further distances 1-5 feet. Also, remember that this measurement was done using an open bench, not in a typical enclosed case. So, if a case is used, then expect to see lower dBA numbers than recorded below. According to the the rated 26.4 dBA at 100% in the specifications table, it looks like be quiet! tested sound level at a distance of around 3 feet and/or used an enclosed case when recording.
The Dark Rock Pro 2 is in the middle of the pack as far as sound level is concerned, being measured at 46 dBA at 10 cm when using the stock fans. Really, all the coolers tested are quiet from a normal distance of around 3 feet, and they will be even quieter when a case is used.
noise_drp2
Conclusion
The Dark Rock Pro 2 is a large dual-tower heatsink in the same class as the NH-D14, Silver Arrow, Genesis, and PH-TC14PE. In my tests, it outperforms all the top-down coolers as expected, but it falls behind the Genesis by ~3 °C on average. Surprisingly, the Dark Rock Pro 2 barely outperforms the Shadow Rock TopFlow by around 1 °C on average, even though it’s much larger and costs almost twice as much. I think this just shows how well the Shadow Rock performs and not that the Dark Rock Pro 2 under-performs, since there isn’t a huge difference between the Dark Rock Pro 2 and the Genesis. As for sound level, the Dark Rock Pro 2 using its stock fan is one of the quieter heatsinks tested. It produces 30 dBA or less of noise at 100% fan speed at typical distances of 2-3 feet, and I wouldn’t expect anything less from a company called be quiet!.
The Dark Rock Pro 2 has a couple of downsides. The major con is that it ends up having the same, if not worse, clearance issue with the fan clips hitting the GPU as the Shadow Rock TopFlow experienced. This can be avoided by installing the heatsink so air blows top-to-bottom instead of right-to-left, but that would disrupt the majority of consumers’ case airflow. The clips could also be wrapped in something like electrical tape to prevent possible shorting. The minor downside is the fan’s frame requires the fan clips to be made such that other typical 25 mm thick fans cannot be installed easily. This is an issue resulting from how be quiet! makes their fans, so any heatsink using their fans will have trouble mounting different fans.
be quiet!’s products aren’t available in the US yet, but the MSRP is $95.00 for the Dark Rock Pro 2. I think $95.00 may be a little high for its performance since that places it up there with the highest of high-end air cooling heatsinks. Unfortunately, I didn’t have access to all the high-end heatsinks for testing for direct comparison.
Overall, the Dark Rock Pro 2 cools well with minimum noise and looks great. However, there may be better performance per dollar options out there that don’t have potential clearance issues with top PCIe cards.
Overclockers_clear_approved
Click the Approved stamp for an explanation of what it means.
– Matt T. Green (MattNo5ss)
Leave a Reply
Discussion
  1. I have just received this beast. I am impressed. It does a bang up job over my old 212. Im seeing as much as 10c diff under load. Good solid performer. Installation was a bit of a challenge but I expected that from such a physically large heat sink. I know some have talked about the clearance. I had no issues as far as clearance. Neither with the RAM (G.Skill Rip Jaws)or video card on an Asus Z68. I am using a Rosewill case. When covered the top of this beast touches the side cover. Overall its a handsome monster and a solid performer. But yous already know that from Matt's review.
    THX Matt
    Z
    PS: very quiet too but yeah, you all know this lolZ
    The storm of reviews from another one of these companies I've never heard of is fascinating.
    Woo for more startups! God knows there needs to be more innovations, the big block of metal with fans attached to it really needs a rethought =P
    Nice find Techjesse! Haven't seen that before, and it's exactly what I was suggesting as a quick fix.
    I was going to get a D14 sent to me from a member, but it didn't work out. I would have definitely noticed that and documented it as well.
    Part of the problem with your "everyday consumer" is they expect everything to work out of the box and may not notice this type of problem until they see the smoke.
    Yeah, all but one of my LGA775 boards had a PCIe x1 in the top slot. My LGA1366 had a x16 in the top. My P67 had a x1. Both of my mATX boards use x16 in the top.
    It seems like the issue effects all mATX/ITX users and some ATX users.
    The main issue I expect is that mobo manufacturers started putting GPUs in that top slot. They spent many many years just using PCIe 1x slots there and then recently changed their minds for 4way CFX/SLI type stuff.
    Phenteks got semi-blasted for it in my review :D
    be quiet!'s coolers are the only heatsinks I've had that have this issue. None of the others in the review, my Venomous X, or old HDT-s1283 had this clearance issue. Whether more coolers have this issue or not, it should still be addressed, in my opinion, especially since it shouldn't take much to fix it.
    It's good to know it's not just be quiet! though. Sounds like Phanteks needs to fix the issue or take it into account in the future as well, but the TRUE is a little old for that :D
    The Phanteks PCDCEC14KDHGUW unit completely obliterates the very top slot (note: most motherboards have a 1x slot at the top not a 16x). The TRUE is close enough to touch the clips to the GPU if the very top slot is used as well. This is a far from uncommon problem.
    Well, both be quiet! heatsinks were sent together, so there wasn't any time for them to fix anything between the two reviews. The fan clip issue has been relayed to be quiet!
    It should be an easy fix in my opinion. They could change the bend angle on the fan clip and/or cover the part that sticks out in a rubber coating. Neither of those options are a major design change.
    It's an easy fix for the everyday consumer as well, they could wrap the clips in a few layers of electrical tape or even bend the fan clips down themselves with some pliers. Of course, the consumer shouldn't have to do this, but at least there are easy ways around it.
