BITSPOWER NP80D
Add Your Comments
Another promising design but a flawed implementation. — Joe
SUMMARY: Interesting design concept that could be executed better.
NP80D
Dimensions: 80 x 60 x 55mm; weight 260 grams; fan 5500 rpm, 29 cfm; 28 fins (BITSPOWER spec is for 31 +/- 1).
BITSPOWER was nice enough to send a sample of their all aluminum BITSPOWER NP80D to test. This is one of the “Wavefins Series”; as you look at the heatsink, it sort of looks like someone sat on it and squished it sideways. What this design attempts is to curve the fins to the fan’s airflow pattern.
Air comes off a fan’s blades at about a 45 degree angle. Fins that are so angled are more effective than a straight fin. By designing a heatsink such that the fins conform to its path off the blades, this loss is minimized.
Another example of mitigating this effect are the Delta fans that incorporate vanes into the base – the vanes straighten out airflow, minimizing loss as airflow hits the fins.
So much for theory. What puzzles me about the BITSPOWER is why they attempt to take advantage of this effect in such a way that they don’t (note: this is my assumption about the design – it could be a marketing effort as well). If you look at the side
Side
you’ll see that the fins are indeed curved. In order for this to work, the fins on each side of the clip must be curved opposite to each other.
Airflow
This diagram (I hope) illustrates how the heatsink should be designed. If you look at one end of the heatsink, half the fins should curve down to the right. On the opposite side of the center, the fins should curve down to the left.
Now here’s the rub: If the fins are not so angled, the fins in the back are in fact fighting against airflow off the fan’s blades and are more ineffective than if they were straight. In fact the airflow is stalled so that half the heatsink is working at 100%, and half is working at far less.
If you look down into the heatsink’s fins
Top
you’ll notice that they do not lie in a straight line, but are slightly angled. I think this is an attempt to adapt to the fan’s radial airflow pattern, although the angle is fairly small.
I give BITSPOWER credit for attempting an interesting design, but execution is questionable.
The base
Base
is smooth and there are no discernible machining marks. The clip is a good one – there is a shelf that you can easily grasp with two fingers so that mounting on the socket is easy.
THE TEST
I prepared the BITSPOWER by boring a hole completely through the base so I could epoxy a thermocouple above the CPU. The thermocouple is attached to an Omega HH23 Digital Thermometer. Ambient temps were measured with a thermocouple placed about 1 inch from the fan’s intake. I used Prime 95 to stress the CPU on an Iwill KK266+, Iwill BD133u (MBM temps are on-die) and Abit KT7. Arctic Silver grease was used in all tests. CPU Case Temp is the temp at that point where the CPU contacts the heatsink, CPU Back Temps are measured by a thermocouple on the center back of the CPU.
I tested the BITSPOWER with the stock fan and a Delta 38. I also tested it on the CPU Die Simulator, as noted below.
TEST RESULTS – CPU Simulator
CPU Die Simulator
CPU Die Temp
CPU Case Temp
Ambient Temp
Delta Die
Delta Case
C/W Die
C/W Case
99 Watts, Delta 38
76.6 C
60.3 C
21.7
54.9
38.6
0.56
0.40
58 Watts, Stock Fan
52.6 C
44.4 C
21.2
31.4
23.2
0.54
0.40
TEST RESULTS – Motherboards
CPU/Motherboard
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
CPU Back Temp
T-Bird @ 1400/Iwill KK266+, Stock Fan (72 watts)
48.2 C
22.7 C
25.5
0.35
38 C
45.2 C
T-Bird @ 1400/Iwill KK266+, Delta 38 (72 watts)
48.6 C
23.6 C
25.0
0.35
36 C
41.9 C
Duron @ 1000/ABIT KT7, Stock Fan (63 watts)
47.0 C
22.5 C
24.5
0.39
43 C
46.8 C
Duron @ 1000/ABIT KT7, Delta 38 (63 watts)
45.1 C
22.5 C
22.6
0.36
40 C
44.1 C
PIII @ 933/Iwill BD133u, Stock Fan (24 watts)
34.8 C
23.2 C
11.6
0.48
38 C
NA
PIII @ 933/Iwill BD133u, Delta 38 (24 watts)
31.9 C
20.9 C
11.0
0.46
36 C
NA
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
The BITSPOWER has some real problems delivering aggressive performance, due, I think, to the heatsink’s airflow stalling. Note, however, Motherboard Monitor temps – look darn good! What’s happening here is very interesting: The fan is blowing LOTS of air at a downward angle onto the motherboard. This does add to CPU cooling, but not to the degree indicated by the in-socket thermistor.
High airflow from the fan onto the board is cooling the thermistor more than the CPU, giving a misleading temp reading. For example, the C/W for the KK266+ with the T-Bird and stock fan using in-socket temps is 0.21 ((38 – 22.7) / 72). The C/W for the PIII with stock fan is 0.61 ((38-23.2) / 24). The PIII temp is the CPU’s internal diode, which is not as affected by board cooling as the in-socket diode.
If we adjust the PIII temp to correspond to CPU Case Temp (Intel docs suggest about a 4 C difference between in-die and case temp), then the PIII C/W at CPU Case is ((38-4)-23.2)) / 24) = 0.45.
Totally unaffected by board cooling is the CPU Simulator, which shows an in-die C/W of 0.54 (analogous to the PIII die temp) and a C/W Case of 0.40 (from the thermocouple mounted into the heatsink’s base), which again is in the ballpark for PIII C/Ws.
As a final test, I ran it against a Glaciator II to see if it could match its overclocking performance, and found that it was stable at least 16 MHz lower and was 5 C higher in Motherboard Monitor. The readings using the motherboard’s in-socket thermistor might be misleading.
CONCLUSIONS
The BITSPOWER NP80D comes in above what we’re comfortable recommending for aggressive AMD cooling.
Email Joe
Leave a Reply
