Buzz's GeForce Sandwich
Add Your Comments
GeForce Sandwich
I just wanted to pass on something to the GeForce owners out there to
help cool their cards down to provide more headroom for o/cing.
I made a sandwich cooler using the retail hs/f from my 600E and mounted it on the GPU. I then put the original hs/f from the video card on top of the card were it gets hot also; I had to use 2
pennies (1982 or earlier for all copper version) to raise the
small hs/f on top above the level of the resistors at the top of the card behind the GPU. I sanded them down and cut them into square spacers; I also had to lengthen the power wire to the original video
fan.
RESULTS
Temp before: 59C/139F idle
Temp after: 32C/89F idle
Its an ASUS V6600 Deluxe with dynamic cooling turned off. I’m still doing testing, but I can o/c my memory all the way up to 195 MHz (max on ASUS tweak software) and core to 130 MHz so far with no crash in Q3 demo; I wanted to finish writing this before I try higher in case of a crash ;->
Email Buzz
Leave a Reply
