Like is says – Joe
SUMMARY: Quick and dirty Northbridge cooler.
I was at a local computer show last weekend and saw a bunch of 40mm fans for sale – $3.00 each:
I looked at these and thought “Nice size for a chip cooler!” I bought a bunch with the idea that I can always use these. I noted that these are made by Delta with a Fonsan label – model #DFB0412H (40mm x 20mm). I later found a place that sells them in the USA HERE (although there is a minimum order of $25). The specs are 8 cfm @ 7400 rpm, 29 dBA. All I can say is I don’t know where they measured noise, but it sure sounded more than 29 dBA.
For those of you running P4 systems, the Northbridge does get warm. One system I am using is a Gigabyte GA-8IRXP which features this Northbridge heatsink:
It’s just crying out for a fan, and the Fonsan is perfect – fits perfectly on this heatsink. I found some 1″ metal screws and bolted it onto the heatsink. I tested the fan at 5, 7 and 12 volts and found the following:
RPM @ 5v
RPM @ 7v
RPM @ 12v
2434
3845
7368
To cut down noise, I decided to run it at 7 volts, figuring it’s about half the airflow, which should be fine. I cut off the power plug, stripped the fan’s wires and used a spare floppy plug for power:
I inserted the bare wires into the yellow (+12v) and red (+5v) wire connectors – the pin end of the floppy plug is small and I decided this was easier. I then used a zip-tie to hold the wires in place.
The result is the heatsink is cool to the touch and I can’t hear the fan running. There are other 40mm fans that will do fine – I would look for one that runs at high rpms and power it at 5 or 7 volts – cuts the noise with decent airflow.
Related posts:
- Ducts – The Cheap Cooling Solution
- Cheap As Free Air Cooling Mod
- Simple & Cheap Crawl Space CPU Cooling
- Cheap, Clean, Cool and Quiet Case Cooling
- Project 3C (Cheap Chill Cooling)
Tags: Cooling
