Cheese it! It's The Coppers, ORB!
Add Your Comments
UPDATE 10/6/00:
Well, I polished up both sides of the copper plate, as shown below. The “scratch” you see is barely visible – the flash’s angle I had to use highlights any marks on the plate.
Cu Plate
I mounted it again with the following results:
Copper Polished: Idle 42C/108F, Prime95 46C/113F
Duron 650 @ 900, 1.82v, ambient temp 21C/70F, temps on ASUS A7V, Motherboard Monitor.
The ambient temp is a little higher, so basically no change from earlier results. Damn! Thought we had something here, but that’s the way it goes. Pablo sent in his experience with the ORB HERE, which pretty much parallels the results I achieved.
The one plus I give to the ORB is that it’s a lot quieter than some other heatsinks around.
SUMMARY 10/3/00: Adding a copper plate to hold the HP ORB results in OK temps, but not outstanding. More lapping to ensure better contact may drive temps down some.
ORB
Shown above is the HP ORB in it’s “natural” environment; I bought one from from All Electronics (catalog numbers are CF-75 and CF-82) this way to see if there was anything else that could be used for cooling. Don’t waste your money – the plate on which the ORB sits is really big and I can’t see a use for it; if you buy one, just get the ORB.
THE COPPER PLATE
The objective was to use the four holes that come standard on all Socket A motherboards to mount the ORB onto a copper plate and then bolt this onto the CPU.
I ordered some copper plate from Metals on-line that measured 2″/50mm x 3.25″/83mm. The motherboard holes measure 2 5/8″/66mm x 1 7/16″/36.5mm. On the ASUS A7V, there’s a lot of real estate for cooling solutions like this; the ABIT KT7 is a little less accommodating, but the ORB can just squeak in. This pic shows the ORB on the ASUS A7V:
Top
It clears the DIMM slot with a little room to spare, but not much.
METALSMITHING
To put this together, I drilled and tapped the following:
  • Four holes to mount the copper plate to the ORB;
  • Four holes for bolting the plate to the motherboard.
Measuring clearances is really critical – you have to offset the ORB relative to the socket so that is clears the A7V’s power riser while not interfering with the DIMM slot.
I first tried this with an aluminum plate to see what problems I would encounter, and I think the best approach is to measure and drill the motherboard holes first, mount it on the board, then position the ORB and draw its base on the plate. Then drill and tap four holes to mount the ORB onto the plate.
Bolt
In the detail shot above, you will note I had to drill out an indentation on the ORB so the screws would clear the ORB’s base. I used 4-40 bolts for all mounting bolts. I also used rubber grommets in the motherboard’s holes for insulation.
This shows the finished product; the copper plate is secured by four bolts which surround the CPU’s core. Make sure you clear the core! The ORB’s base is about 1/4″/5mm beyond the copper plate.
You can also see that the ORB’s edge interferes with the bolt’s clearance by a small margin.
RESULTS
Well, I wish I could tell you I had uncovered the Rosetta Stone for AMD cooling, but not so. It wasn’t shabby, just not as good as I thought:
Copper: Idle 42C/108F, Prime95 45C/113F
Aluminum: Idle 47C/116F, Prime95 51C/123F
Duron 650 @ 900, 1.82v, ambient temp 20.4C/69F, temps on ASUS A7V, Motherboard Monitor.
This is about 1C/2F worse than an Alpha PAL6035 with a YS TECH 26cfm fan.
I did a “post mortem” on the setup and discovered that the Arctic Silver grease left a void where the CPU core contacts the plate. I think the plate is not as flat as it could be, and it’s back to the shop to do some more sanding. What’s critical is that the copper-ORB joint be as flat as possible, so I’ll work it and see what happens.
CONCLUSION
If you have an ORB kicking around, it’s not a bad cooler. Whether the work involved is worth it is another matter. If you’ve used this for AMD cooling, send an email about your experience.
Email Joe
Leave a Reply
