Cleaning & Improving Cooling On HP ZE5500-Series Laptops
HP
I’ve had my HP ZE5517EA laptop for almost 1.5 years now. Lately it sometimes BSOD’s or simply locks up. It’s been returned to HP when it was still under warranty but they sent it back, stating “fault not reproduced, updated BIOS and restored original system software”.
Of course the fault was still there. After reading a few things online about clogged-up cooling causing laptop failures, I eventually decided to take it apart myself to clean the cooling system and improve it with Arctic Silver 5 compound. There’s almost no info to be found about taking this laptop model apart.
I know this particular model comes in a lot of flavours and is still sold with AMD’s or Intel’s Celeron-D and Centrino technology today! Some have a single or multiple fan-configuration, floppy or flashcard drive, some have wireless on board, some don’t etc. etc. I hope this article can be used as a general guide on how to safely service your HP laptop with this kind of housing!
  • Be careful with all the fragile connectors. DO NOT use EXCESSIVE force on them or you WILL damage your components!!!
  • When prying on things BEWARE – you can always slip and EASILY scratch a PCB beyond repair!!!
  • Also NOTICE you’ll VOID your WARRANTY by replacing the OEM waxpad, even though it’s a better thermal solution and even though you aren’t modifying anything else!!!)
Turn the laptop upside down and locate the hard disk-bay.
Remove the rubber ‘peg’:
HP
Remove the 3 screws shown:
HP
Remove the hard disk and store it together with its 3 screws and rubber ‘peg’:
HP
Remove the 2 screws at the back of the hinge-covers:
HP
You can now carefully pry out the panel area as shown:
HP
Disconnect the panel connector:
HP
Remove the 4 screws holding down the keyboard:
HP
Slide the keyboard forward and tilt it out:
HP
Disconnect the keyboard by lifting the white tab on the connector while pulling the flat cable out:
HP
At each hinge, remove the screw holding down the 54g antenna PCB (if applicable):
HP
Again at each hinge, remove a total of 6 screws. Watch the tiny blue ground-lead at the left hinge! (Don’t forget to put it back on when rebuilding everything later on):
HP
Disconnect the LCD connector and safely store the screen/lid:
HP
Remove ALL the screws shown on the bottom and back of the housing:
HP
{mospagebreak}
Remove the 5 screws remaining in the top cover:
HP
Disconnect the floppy (or flash card reader?!) connector by pulling the flat cable out; disconnect the scroll pad by lifting the white tab on the connector and pulling the tiny flat cable out:
HP
Tilt out and detach the top cover complete with scroll pad and floppy (or flash card reader?!):
HP
Carefully remove the heatpipe cooling system by loosening the 4 screws in a cross-pattern. Any waxpad or thermal compound will come right off with it:
HP
Carefully remove all the wax or thermal compound residue from the CPU with some alcohol or nail polish remover (make sure not to spill around!!!):
HP
In this case, I will replace the standard aluminum waxpad with some Arctic Silver 5:
HP
Carefully remove all the wax or thermal compound residue from the heatpipe’s contact area with some alcohol or nail polish-remover:
HP
Now clean all components using a vacuum cleaner and a long soft-haired brush, or a can of compressed air, etc. (The glasses are to keep groups of screws separated!):
HP
After everything is dust-free and otherwise cleaned, apply a dab of Arctic Silver 5 or the compound of your liking, and rebuild the entire laptop in reverse order. It’s been a few days now since I’ve done it and no Blue Screen Of Death or lockup so far! The cooling system is noticeably more efficient now. The fan(s) used to run all the time but now they are turning on and shutting off again (Like when this laptop was new, yay!). In fact, I wrote this article on it!
The cat was watching it all in disbelief:
HP
UPDATE:
Since I found out the CPU was socketed and the Radeon IGP345M chipset with shared video also supports 533 FSB, I today succesfully replaced the original Mobile P4 2.3/512/400 D1 1.3V with a Mobile P4 2.8/512/533 D1 1.3V!!! The laptop is clearly feeling snappier even at the lowest 1600 Mhz speedstep due to the faster FSB.
The old CPU was a SL789; the upgraded CPU is a SL725 – both are D1 Northwoods.
I can tell you with the improved cooling, higher FSB and RAM speeds, this laptop feels like a Centrino system (I have a 1.6 Ghz Banias laptop from work.) Future upgrades will definitely include going to 1 GB RAM and a faster HDD.
Here are a few CPU-Z screenshots and a pic of the 2.30 Ghz CPU which, btw, is Priming right now @ 3.2 Ghz 200 FSB(!), 1.475 Vcore, in our kid’s rig with an Asus P4PE mobo:
Screen Shots
Screen Shots
Screen Shots
Screen Shots
{mospagebreak}
UPDATE: I’m getting emails about how I knew I could upgrade the CPU, so this is how I figured it out:
I used reasonable deduction:
At the time I purchased my laptop, the only other offerings in the (P4) range
besides my 2.30/400FSB were 2.66/533FSB and 2.80/533FSB. All these laptops
were using the ATi Radeon IGP345M-chipset.
I searched the web to confirm
this chipset supports both 400 and 533FSB CPU’s. Furthermore, when I looked
on the HP support site, I found that any BIOS-updates were the same version
for all these laptops! So they all seem to have the same mainboard.
Then I
looked at the CPU wattages at Intel’s processor spec finder. My old 2.3
draws around 58 watts at full load, a 2.8 draws 68.4 watts, so I knew these
mainboards must at least support that kind of wattage.
When it seemed to be
quite feasible, I bought a used CPU off Ebay and it worked like a charm!
I NEVER had any crash or BSOD since I installed it 6 weeks ago! The RAM is now
running 1:1 instead of 3:4, and even when Speedstep drops down to 1600 Mhz, it
runs with 533FSB instead of 400FSB with my old CPU.
Are other CPUs possible?
I looked it up and a Mobile P4 3.20/533FSB D1 (Northwood) draws
around 76 watts. This is only 7 watts more than my 2.8, so it might work – but would
you want to take the risk of frying your mainboard if its power regulators
just aren’t beefy enough?!
I use SpeedswitchXP, so my CPU runs at 1600 Mhz and
automatically switches to 2800 Mhz whenever CPU load gets above 50%. At
1600 Mhz it works perfectly and keeps the cooling quiet. Maybe it will be
OK when you have a 3.2 that’s at 1600 Mhz most of the time, but if you run
SETI of Folding, it’s a good bet the power regulators and/or cooling isn’t
up to the task with a 3.2.
Share and Enjoy:
  • Print
  • Digg
  • Sphinn
  • del.icio.us
  • Facebook
  • Mixx
  • Google Bookmarks
  1. Improving The Cooling On The Asus Z71V & A
  2. Tech Talks on Laptops
  3. Dell/Quantex Laptops
  4. Improving Power Supply Voltages Without Upgrading or Mods
  5. Laptops 2432
Tags:
