Computex 2015 - G.Skill Showcases Expanded Product Line And Trident Z DDR4 Memory
Add Your Comments
G.Skill is on the move and will soon make available several new products to the gaming and enthusiast communities. In addition to expanding their DDR4 memory to include the Trident Z series, you can expect to see power supplies, gaming keyboards, gaming mice, and gaming headsets. We received a few press releases from G.Skill about these new offerings, and here they are!
G.SKILL Showcases New Trident Z series DDR4 Memory
G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and solid state storage, showcases the brand new Trident Z series of DDR4 memory designed for PC enthusiasts.
With numerous overclocking records under its belt, G.SKILL TridentX series is known as the most powerful overclocking memory series in the PC enthusiast community. The new Trident Z series comes with high quality aluminum heatspreaders and a customized bar in various colors, providing PC builders the options to match their own system’s color scheme, while maintaining efficient heat dissipation.
The new Trident Z series DDR4 memory will be available in quad channel and dual channel, starting July 2015. Detailed specifications will be announced soon.
Computex 2015- G.SKILL Showcases Ripjaws Power Supply, from 750W Gold to 1250W Platinum 80 PLUS Certified
G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and solid state storage, showcases its new Ripjaws series PC power supply units at Computex 2015.
The G.SKILL Ripjaws series PC power supply units consists of four models ranging from 750 watts up to 1250 watts, suitable for the needs of all PC system builders whether it’s a high-end workstation or a gaming oriented system. All four Ripjaws series PSU feature a full module design that allows cleaner cable management and better case airflow.
The Ripjaws PS750G/PS850G models, certified with 80 PLUS Gold and rated for 90% efficiency, along with the Ripjaws PS850P/PS1250P models, certified with 80 PLUS Platinum and rated for 92% efficiency, can lower your overall operating cost and lower internal system temperature.
All Ripjaws series PSUs are made from the highest-quality materials possible, such as 100% Japanese-made capacitors, for higher reliability and longer lasting lifetime. A unique automated G.SKILL ECO Optimized (GEO) Thermal Fan Control also provides zero fan noise during low load operations. And when it does get warm, the durable double ball bearing 140mm fan cools your PC system quietly and efficiently.
With Ripjaws series PC power supply units, you will have the convenience of a full modular design, superior power performance and efficiency while staying protected with a series of total protection such as OVP, UVP, OCP, OPP, SCP, OTP all bundled into one!
G.SKILL Showcases Ripjaws Series Mechanical Keyboard, Gaming Mouse, and 7.1 Surround Headset at Computex 2015
G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and solid state storage, is excited to showcase a completely new series of high end gaming peripherals at Computex 2015! The new Ripjaws series gaming peripherals include two mechanical gaming keyboards, a RGB gaming mouse, and two 7.1 surround sound headsets.
Fully Customizable Ripjaws KM780 RGB / MX Mechanical Gaming Keyboards
Available in two lighting flavors, full range RGB and crimson red, the KM780 RGB and KM780 MX are fully loaded mechanical keyboards designed and built with durability and practicality in mind for the ultimate gaming and typing experience. Featuring Cherry MX Red and Brown key switches with 50 million key-press lifecycle and a braided 2.0m USB cable, allows the Ripjaws KM780 series keyboard to last for years of daily usage.
g.skill_computex4 g.skill_computex5
The KM780 RGB and KM780 MX keyboard is capable of storing your settings within onboard memory, so you’ll have a personalized keyboard experience no matter which computer you’re connected to. You can store up to three independent modes of settings on the keyboard, easily switchable via Mode hotkeys (M1-M3), each containing its own lighting patterns, macro setup, timer setting, key delay and repeat rate, polling rate, and various other settings, so you can have a personalized keyboard layout for each different gaming character, in-game skillsets, or special macro shortcuts for different applications. Combined with per-key programmability and per-key lighting options, as well as 6 extra dedicated macro keys, the possibilities are endless with the G.SKILL Ripjaws KM780 series mechanical keyboard.
MX780 RGB Gaming Mouse
Designed with the latest technology and customizable to fit your own personal gaming style, the Ripjaws MX780 RGB gaming mouse is ambidextrous and features a height-adjustable palm rest and interchangeable side grips to maximize comfort and support for your hand size and grip style.
Constructed with a 32-bit ARM processor, gaming-grade Avago laser sensor, and Omron micro-switches, the MX780 RGB gaming mouse is capable of 1000Hz polling rate, 8200 dpi, tracking up to 150ips, and 30g of acceleration with a durability of 20 million clicks. Up to 5 individual profiles can be stored within the device, each profile with its own sets of customizable RGB lighting across 4 lighting zones and unique settings for 8 fully programmable buttons.
Also included are gaming grade PTFE glide pads, notched scroll wheel design, and 5 programmable dpi steps with color indicator, making the Ripjaws MX780 RGB the ultimate gaming mouse that adapts to you and your gaming style, not the other way around.
G.SKILL Unified Driver System (G.U.D.S.) Software Suite
The unifying backbone to enable full customizability for the Ripjaws series mechanical gaming keyboard and gaming mouse, is the G.SKILL Unified Driver System. An intuitively designed user interface allows you to navigate easily through all the settings, manage stored profiles, and customize each mode for each of your own personal gaming style or application use. From choosing color and lighting patterns, to personalized key functionality, experience the freedom to explore and express your own gaming style.
Ripjaws SR910 / SV710 7.1 Surround Digital Gaming Headset
Listen to your in-game world expand and come alive on the Ripjaws SR910 in real 7.1 surround sound through 10 discrete audio drivers, or on the Ripjaws SV710 in virtual 7.1 surround sound powered by Dolby Pro Logic IIx through dual 50mm drivers.
g.skill_computex7 g.skill_computex8
Dive into a distraction-free audio experience with a circumaural earcup design, immerse yourself in high-precision positional audio with Xear 3D technology, and enjoy extended gaming sessions in comfortable leatherette lined ear pads. When working with teammates, the built-in ENC (environmental noise cancellation) microphone analyzes and reduces background noise for crystal clear voice communication. Complete with an instant-access in-line control and a full audio control software suite that includes a 10-band equalizer and customizable surround sound speaker positioning, the ultimate audio gaming experience is within reach.
The G.SKILL Ripjaws series gaming gear will be available in 2015 Q3 and detail pricing will be announced soon.
Dino DeCesari (Lvcoyote)
Leave a Reply
