Compact mid-level kit – Joe
SUMMARY: Very compact external kit with mid-range performance.
The good guys at Comserver Components were nice enough to send a sample of their Standalone Water Cooling Unit. This is a very compact external unit with about 6′ of 3/8″ OD tubing, so it can be located some distance from the PC. The unit features:
- AC ball bearing 26 dba 120 mm fan
- 12 Ounce aluminum reservoir
- 300 Gallon Per Hour Pump
- Nickel plated, O-ring Push-To-Lock fittings
- Aluminum radiator
A closer look reveals how it gets its compact shape.
There’s not much wasted space here – this diagram gives a good view of how things are stitched together:
Note that the pump is directly bonded to the reservoir – saves a lot of space. One thing I noticed is that the pump makes a “rattling” sound for about a minute, then quiets down – this is the pump cavitating and purging air from the system. The radiator is closely tied to the pump, so lines are kept to a minimum – a very neat, compact design.
There are two waterblocks – a P4:
The base is reasonably flat:
And a Socket A version, which features spring-loaded clips:
The base appears flat and polished:
I tested the Comserver kit using the Die Simulator for both the P4 and Socket A versions. The Socket A clip is easy to mount and engages all three socket lugs; simply screw the bolt in, set it on the lugs, and unscrew until the bolt clears the top of the clip – simple.
However, I did notice that the clip might “hang up” as the clearance between the block and springs is quite tight – this could result in misaligned CPU contact; Comserver is correcting this problem.
Fan noise is tolerable – I measured it at 59 dBA three feet from the fan – not terrible, but definitely noticeable.
| Kit |
Die Temp
Ambient Temp
Delta
C/W
| Comserver, P4, 70.3 watts |
45.0 C
22.1 C
22.9
0.33
| Comserver, Socket A, 70.0 watts |
48.6 C
23.3 C
25.4
0.36
C/W = Delta / CPU Watts
