Cool-Computers Copper Waterblock
Add Your Comments
SUMMARY: A high-performance waterblock for socketed CPUs.
Cool-Computers was nice enough to send a bunch of waterblocks to test out – I am going to report first on the socket version pictured below:
Cool Computer
This block is of the “traditional” design – bored holes with plugs. What’s interesting about this particular block is how close the channels are to the centerline of the block and the location of the water nipples; I think what this does is concentrate the cooling where it’s needed – over the CPU.
The block is nicely finished – no rough edges or burrs. I first ran it to check for leaks – no problem (always run a waterblock outside the case first to check for leaks).
THE TEST
I used my T-Bird @ 1100, 1.85 v, to see how well this block cools. The system included a Pondmaster 1.5 submersible pump and a modified Senfu radiator (takes 3/8″ tubing) at an ambient temp of 22.2C/72F. Temps were measured using the Asus A7V temp probe on the side of the CPU running Prime95.
RESULTS
T-Bird 750 @ 1100, 1.85 v: 41C/106F
As a point of comparison, I ran the T-Bird with the BE Cooling copper block and it recorded 40C/104F – in my book, a draw.
CONCLUSION
I have no hesitation recommending* the Cool-Computers block I tested – nicely made and a competent performer. Notice that the position of the intake nipples may better allow the use of multiple leg mounting clips than some others, although I am sure the ingenuity of our readers can overcome any such trivial obstacle.
*Having said that, I am asking anyone who buys this block to email me if what you receive differs significantly from what’s pictured above. I have not received any complaints about Cool-Computer’s quality. However, I have received emails from folks who have bought other waterblocks we have reviewed and have been sorely disappointed in workmanship.
I can understand when someone sends us something to test, they send a very nice sample. However, if the sample is NOT the same quality as what YOU receive, tell me. I will post your experience as an update – with pictures, if possible.
Reluctantly, I must warn against BE Cooling’s waterblocks at this time; I have received complaints and seen pictures of the finish quality of what was received and, even though performance is not impacted negatively, they look shoddy.
Email Joe
Leave a Reply
