Cool & Silent Hard Drive Sandwich
Add Your Comments
SUMMARY: A unique and inexpensive DIY hard drive noise damper also provides effective cooling. It may be an ideal solution to lower noise with high performance systems or to cool high-speed hard drives without additional fan noise.
Recently, a new over-clocked 1GHz AMD K7 system raised the noise in my 3-PC networked home office to an unacceptable level. I spent several weeks researching and experimenting ways to reduce PC noise. Eventually, I achieved pretty good noise reduction by dropping the voltage to the fans to 7 volts, applying damping in the case, installing a quiet Enermax power supply and doing other mods to improve airflow and reduce turbulence.
Then I began hearing the annoying high-pitched whine of the 7200-rpm hard drive, which had been masked before by fan noise.
How to get rid of the whine?
QuietPC’s SilentDrive is the only commercial solution I found: an acoustically damped, sealed enclosure for hard drives. It works by absorbing the noise of the HD. A drawback is that the hard drive heat is basically trapped within the enclosure, and users are cautioned not to use drives that generate more than 6.8 watts of heat.
The IBM 75GXP 46G drive is safe, as it generates 6.7 watts of heat. This is the same HD model I use in 2 of my systems. Postings on hardware forums suggested, however, that many users were less than comfortable with how hot their 7200-rpm drives were getting in SilentDrive.
The question became: How to get rid of the whine without overheating the drive?
There are HD cooling fans, but these would probably do little to cool a drive mounted inside a SilentDrive. One consideration was the Vantec Ultimate Hard Drive Cooler, which uses a kind of heatsink and fans to cool the drive. However, no noise reduction for the device is claimed, and I really did not want any more fans.
Parts
The solution I eventually came up with is a “noise-sink” that also acts as a heatsink: 2 heavy pieces of aluminum with the hard drive sandwiched in between – thus my moniker for the device. The accompanying pics pretty much tell the story, but here are the details:
  • Four bolts and nuts are used to clamp the hard drive tightly between two 3/8″ thick 5.5″ x 8″ aluminum plates, each weighing 630g (22oz). Care must be taken not to over-tighten to avoid potential damage to the HD. Dense foam is wedged around the open sides. I found the sheet metal lying around as scrap in a machine shop and had it cut and drilled for me; I knew my hand held power tools would not be happy working with this thick aluminum.
  • HD vibrations are drawn into the heavy aluminum and converted more into heat than noise, as the mass of the aluminum plates makes them difficult to vibrate. Higher frequency noise (the whine) bounces off the aluminum plates, and then gets absorbed by the foam. The noise reduction ranges from 6 to 15 dB in the frequencies between 400 Hz and 5000 Hz where human hearing is most sensitive.
  • The close coupling to the aluminum more than doubles the cooling surface and mass. There are significant air gaps between the HD and the metal plates on both sides of the HD. I did not consider using thermal compound – the gaps are too big. Still, maximum temperature is reduced from 45°C down to 38°C (that’s a 13°F difference). In normal use, the HD temperature rarely exceeds 30°C, compared to 40+°C without the sandwich mod (an 18°F difference).
    Side
  • The drive sandwich assembly rests on the bottom of the case, just behind the front case fan, which provides additional airflow cooling. A thin piece of foam that came in a motherboard box is used as a damping “bed”.
  • The HD Sandwich may be ideal for noise reduction and cooling in water-cooled systems where the hard drive is often the loudest component.
In Case
Noise Analysis
A demo copy of SpectraRTA software and the microphone of a cheap computer headset plugged into my SB Live! Soundcard were used for noise analysis. The measurement setup was as follows:
Mic
1) I isolated the hard drive acoustically in a filing cabinet drawer to reduce interfering noise from other sources. A thick piece of foam in the bottom of the drawer helped reduce reflections. The mic was placed directly on the top center of the drive. A lengthened IDE power cable from a PC allowed the drive to idle. No IDE data cable was used, as the distance to the computer was far too long.
2) Three sets of measurements were made:
  • Drawer closed and no drive inside, as a reference.
  • Bare drive running idle.
  • Drive running idle in Cool/Silent Sandwich, with foam.
The results can be seen in the accompanying images. There is hardly any noise reduction in the lower frequencies. Between 400 Hz and 1.6 KHz, the average noise reduction is well over 10 dB, which is very significant, with peaks of 15 dB or more. Human hearing interprets 10 dB to be twice (or half) as loud. Between about 1.6 KHz and 4-5KHz, the noise reduction is more modest, averaging about 6-9 dB.
Compare
Other aspects of the noise measurements:
  • The peak at 50-60Hz on all 3 curves is the resonance of the drawer air cavity.
  • The big peak at 100-125Hz, which occurs only with the HD on, is the low frequency HD resonance, picked up at a disproportionately high level because the mic was touching the drive. (It’s like placing your ear directly on it – you’d hear a lot more low frequency noise than usual.)
  • The mic is not calibrated, nor is its frequency response known. This does not matter, however, as the only real significant data is the difference between the red and blue curves, which is the actual noise reduction effected by the HD sandwich.
Subjectively, with the HD sandwich idling outside the case, it is possible to hear a trace of the “whine” when I bring my head within 2 feet. There is audible noise with seek and write operations. When the HD assembly is in the closed case, if the fans are all turned off, the HD is barely audible.
When the system is operated normally, any trace of hard drive noise (including seek) is completely masked by the quiet “shhhhhh” of the fans. (NOTE: You may not get the same results. For example, if your other components make less noise or if your case is less insulated, you may hear the sandwiched hard drive.)
Temperature Analysis
Drive on Plate
A Veriteq 1000 data logger with the amazing accuracy of ±0.1°C was used for temperature measurements. I used an external “raw” 100K thermal sensor about the size of a flea, insulated the leads and stuck it in the top front corner of the HD, in a tiny cavity just beneath the top metal cover:
Probe
It was the only place on the top, closest to the platters, where I could place the thermistor with the metal sandwich on.
Veriteq
The data logger was set to read once a minute – every 60 seconds, it turns on, records the temperature, then turns off. The HD was placed on top of the PC case (for convenience). Measurements were taken as follows:
1) I ran Sisoft Sandra’s HD burn-in utility for an hour with the bare drive, and then downloaded the data into the Spectrum program that comes with the data logger. Spectrum allows the data from loggers to be output as graphs or in numeric form.
2) This was repeated with the drive sandwich on. The starting temperature of the drive with the sandwich was 10°C higher, as I was too impatient to wait for the drive to cool down. But the temp still stayed 7°C lower after an hour!
Curves
The results can be seen in the accompanying chart. You can see how much slower the temp rises with the sandwich – the temperature gain for the whole hour is just 5°C (9°F), from 33°C to 38°C. This compares favorably to a whopping 22°C (39.6°F) rise in one hour without the sandwich. If the second test started with the sandwiched HD at 23°C like the bare HD, at the 5°C/hr rate, it would have taken 3 hours to reach 38°C! Would this really happen?
Sandwich
Intrigued, I ran Sisoft Sandra burn-in again with the sandwiched HD, this time with the starting temperature at 22°C. This chart is also shown: it took exactly 2 hours to reach 38°C. However, during the next hour, the temperature only rose 1.5°C! You can see how the slope of the curve becomes flatter and flatter over time, which suggests the reaching of equilibrium. In other words, the Sandra HD burn-in can’t heat the drive much more.
At 3.5 hours, when I decided my hard drive had taken enough of a beating and stopped the burn-in, the temperature was still just 39.7C. At this rate, it might have taken another hour or two to hit 40°C. I didn’t need to find out how exactly long any more.
Although this data is not included because of its unwieldy size, I also logged temps over a 24 hr period with the drive mounted normally in the computer, then again for 24 hrs with the sandwich on and the drive placed in the case (as described earlier). With the sandwich on, the temp rarely exceed 30-32°C, and reached a peak of 38°C during the 24 hours. With the drive mounted normally, the average temp was 39-42°C, and hit peaks of 46°C at times. (Generally, MBM5 shows my case temp to be 30°C or lower.)
Many hardware websites praise fan-equipped hard drive coolers for achieving just a couple of degrees of cooling. In this context, the HD sandwich’s cooling is pretty amazing especially as cooling is not even its main function.
The Bottom Line: My HD sandwich works well. It quiets the HD substantially, keeps it much cooler, and cost me just US$12 to implement.
Mike Chin
Leave a Reply
