The CoolerMaster Hyper N520 Heatsink Review.
CoolerMaster was nice enough to send a sample of their Hyper N520 Heatsink. This is a five heatpipe heatsink that uses two 92mm fans for active cooling.
Key Features:
- Five heatpipes, 6 mm dimension (three “U”-shapes, two half-”U”)
- Copper base, aluminum fins
- Two 92 mm fans, 1800 rpm, 43.8 cfm, 19 dBA
- Weight 688 grams
- Size 122 x 103 x 141 mm
- CPU mounts for Intel LGA 775, 1366; AMD AM2, AM2+, 939, 754
The base is acceptably flat:
A view from the top shows the staggered 92 mm fans:
Mounts that ship with the fan – I should note that there is a fair amount of assembly required for these mounts; also note that the motherboard must be removed to mount the heatsink:
This shot shows the how tall this heatsink fits on a motherboard – it’s measured from the base of the PCB:
Test Results
The CoolerMaster Hyper N520 was tested on an Asus P5WD2 motherboard with a modified Pentium D 805 to read CPU case temps while running Prime 95 with the following results:
| Test | Die Temp | Ambient Temp | C/W |
| CoolerMaster Hyper N520 |
38.6 | 20.8 | 0.19 |
The temp reading from the CPU’s on-die diode measured 47C. Fan noise from both 92 mm fans was measured 8″ from the fans’ intake with a Radio Shack sound meter and measured 54 dBA @ 1786 rpm; 50 dBA at this distance is very quiet 3 feet from the fan.
Overall these results place CoolerMaster’s Hyper N520 in the upper-middle of heatsinks tested to date HERE.
Conclusions
CoolerMaster’s Hyper N520 delivers good performance at reasonable noise levels. It does take some assembly to set up the mounting systems but not unduly so. Overall a large heatsink with good cooling performance.
Related posts:
- Cooler Master Hyper 212 Plus Heatsink Review
- CoolerMaster Aero4
- CoolerMaster HSC-V62
- CoolerMaster CB5-6G52-01
- Kingwin XT-1264 Heatpipe Heatsink
Tags: Cooling
