CoolerMaster Jet 7 CPU Cooler
Add Your Comments
A jet engine cooler? Brian Berryman
SUMMARY: A better than average cooler, with an interesting visual theme
wide shot
John over at Jab-Tech was
kind enough to send over one of CoolerMaster’s
new heatsinks to check out.
We’ve all heard the jokes…you get so many fans going in your system that; “My PC sounds like an airplane!”
CoolerMaster, with the Jet 7 (and it’s Jet 4 sibling), have taken that thought and produced a pair of products that actually look like part of
an airplane.
Package
Despite it’s appearance, this product contains no calcium or Vitamin D.
CU
Visually, the Jet 7 is closer to Pratt and Whitney than Hewlett Packard
Rear CU
The “jet engine” theme is continued around the entire blower assembly
There’s also a pair of embedded LEDs included, one front, and one rear. The front LED is a very bright white, and flashes every four or five seconds, the rear LED is
mounted inside that “tail cone”, and as a very bright red (non flashing). These help further enhance the aircraft theme.
As can be seen in the opening picture here, it comes with a pair of brackets, and a bit of wiring. Included in the harness is a fan controller, that
allows variance in speed from 1900 to 3500 RPM. This varies the airflow from the blower to 19.89 to 22.10 CFM as well.
In the little bag visible there, is the knob for the controller, and a spare set of screws for mounting the blower onto the heatsink. It’s installed with chrome screws,
the extra set in the bag are black.
The brackets allow for mounting the fan controller in either an open rear expansion slot, or floppy drive bay. The power lead for the fan is a 4 pin pass-through Molex
type, and there is an additional 3 pin (single wire used) lead for fan RPM monitoring, if desired.
CoolerMaster did their research, and got the visual end of this cooler right. But does is perform as good as it looks?
This product is designed for Socket A and 370 use (AMD and older Intel platforms). CoolerMaster states on the packaging that it’s good for;
  • Intel Celeron up to 1.4GHz
  • Intel P/// up to 1.33GHz
  • AMD Duron up to 1.3GHz
  • AMD Athlon XP up to 3200+ and higher
The testing I did was with my old AMD XP1800+ (Palomino core) mounted on an Iwill XP333-R motherboard, the only combo I had available at the time of testing.
{mospagebreak}
A couple more views;
The Jet 7 uses a hinged retention clip, that hooks onto all six socket lugs. The shape of the heatsink makes it a bit difficult to install, but once it’s on,
it doesn’t move around.
Hinged clip
Looking down into the heatsink shows there’s a good number of fins. These aluminum fins are soldered onto a copper base.
Into the sink
Base
The surface of the copper is a bit rough, with fine scratches left from machining. Hand lapping the base slightly may enhance performance.
Into the fan
Looking into the blower we can see the cage clearly. The benefit of a blower over a typical fan is there’s no ‘dead spot” from the center of the fan.
Usually, that dead spot is centered right over the core of the CPU. With a blower, air can flow freely to all points of the heatsink, especially the center.
Installed
Mounted up on the Iwill.
Logic dictated that facing the front of the blower towards the incoming airflow would yield the best results. Depending on the orientation of the CPU
socket on your motherboard, you may have to rotate the blower on the heatsink to face it the right direction (I did).
If you have a window in the side panel of your case (being a very visually orientated item, a window would make sense), facing it this way also
yields the best view of the Jet 7.
Performance
With the ability to control the blower speed, the sound level can also be controlled, as well. At the lowest setting, it’s a fairly quiet unit. When given full voltage,
it’s got a definitely noticeable whine to it. How (in)tolerable this is will depend greatly on the environment around it. The louder the rest of the system and fans used, the
less of an issue the blower on high would be.
{mospagebreak}
Jet 7 full specs;
  • Socket type: Socket A, 370, 462
  • Dimensions (H/S): 74x60x40 mm
  • Fan dimensions: Blower, 80x80x80 mm
  • Fan Speed: 1900 – 3500 RPM
  • Fan Airflow: 19.89 – 22.10 CFM
  • Fan Noise: 25.1 – 40.4 dBA
  • Voltage Rating: 5.0 – 13.8 V
  • Heatsink Material: Copper base, aluminum stacked fin
  • Weight: 490g
Test Hardware;
  • Motherboard: Iwill XP333-R
  • CPU: AMD XP1800+, Palomino core
  • CPU Speed: 1533MHz, 11.5 x 133FSB, 1.75v
This was mounted in a generic mid-tower case, with one 92mm intake fan, one 92mm exhaust fan, and a 92mm “blowhole” fan over the CPU.
Note: Temps shown as reported in Motherboard Monitor 5, using the Iwill onboard thermistor. Temps taken at 100% load while running the Folding@Home client.
TEST RESULTS
Heatsink
Die Temp
Ambient Temp
Delta
Jet 7, 1950 rpm
37 C
21 C
16 C
Jet 7, 3500 rpm
35 C
21 C
14 C
Not the best I’ve ever seen, but far from the worst.
CONCLUSIONS
Testing finds this to be somewhat better than average, in regards to both performance and appearance. I can’t say I’d recommend this particular heatsink
for any serious overclocking, but it should be capable of cooling a mild push of bus and voltage. The better you case airflow is, the less you might have to wind out
the blower. The more you wind up the blower, the less you might want to overclock, however. 3500 RPM certainly isn’t silent.
Visually, this item is somewhat of a novelty, but one that does perform. It not “all show and no go”.
I’d like to thank John over at Jab-Tech for sending
this out to look at.
Email Brian
{mospagebreak}
I did a bit of “extracurricular” testing with this item.
What I did, was to install the blower onto another heatsink, to see how a blower instead of a fan effects temperatures.
This was the first heatsink I’d ever tried that used a blower for cooling, and I’d always wondered just how much that “dead spot” (under the hub of a standard fan) that’s
frequently discussed really matters.
With that in mind, I tried out the blower in my Intel P4 machine, that uses a Swiftech MCX4000 as a heatsink. I’ve been using a standard Sunon case fan on this. (80x25mm, 39 CFM, Model # KD1208PTB2)
Sunon on Swiftie
Blower on Swiftie
Test Hardware;
  • Motherboard: Abit IC7 v1.0
  • CPU: Intel P4 1.6A (Northwood)
  • CPU Speed: 2310MHz, 16 x 144FSB, 1.65v
TEST RESULTS
Fan/Speed
Fan CFM
Die Temp
Ambient Temp
Delta
Jet 7 blower, 1950rpm
19.89
48 C
23 C
25 C
Jet 7 blower, 3500rpm
21.10
47 C
24 C
23 C
Sunon case fan
39
44 C
21 C
23 C
Note: These temps shown are also as reported with Motherboard Monitor 5, running at 100% load using the Folding@Home client.
Looking at these numbers here seem to back up the notion that the dead spot indeed can effect temperatures somewhat. Despite putting out significantly less airflow, the
blower holds the temperature right about to where the much higher flowing case fan does.
It is, however, a good deal louder in doing it. Well, perhaps not too much louder, but the noise it makes is more of a high pitched whine, as opposed to the droning hum
the Sunon makes. It’s a less desirable noise, to be sure.
Email Brian
Leave a Reply
