COOLINK H2Twin (H2T)
A top performing, twin-fan heatsink — Joe
SUMMARY: Top rank performance with tolerable noise levels.
Coolink Twin
Size: 76 x 95 x 74mm high; Fans: 2 70 x 15mm, 33cfm @ 4200 rpm; Weight: 440 gr;
The good guys at Coolink were nice enough to send some samples of their heatsink called the COOLINK H2Twin (H2T). Coolink is a new face on the US scene. Currently, they are mainly sold in Eastern European markets. They are looking for US distribution, so if interested, drop them a line.
This is a twin fan model with the fans blowing into the center core. The airflow is quite good and there’s a fair amount of air coming off the heatsink’s top. For consumers who like “fail-safe” products, a twin fan heatsink has some attraction.
The fans are Innovative Model #BS701512M – a 70 x 15mm unit rated at 33 cfm @ 4200 rpm. I found them to be slightly noisier than a single YS Tech 26 cfm – I measured their noise at 65 dBA with a Radio Shack sound meter 8″ from the fan’s intake, less than a Delta 38 (about 69 dBA). It’s also safe to use a motherboard fan headers.
Looking down into the heatsink
Top
shows the “H” pattern – we are seeing more variations on this theme in the market recently. The center column distributes heat from the CPU core into the fins radiating from the core. According to Coolink:
The “H” shape aluminum base and fins are copper (inner) and nickel (outer) plated. This copper-plated surface further enhances the heat transfer efficiency.
I don’t know if it makes that much difference, but it’s an interesting detail.
The base
Base
is flat but could stand a better finish – one sample showed pit marks in the base – lapping would be a plus. The base is soldered onto the aluminum top piece. Coolink did inform me that these units are “first production run” and that the finish will be better on subsequent units.
The clip is a good one – engages all three socket lugs. The only drawback is it requires a screwdriver to mount/dismount from the socket.
In summary, an interesting twin-fan, copper base, aluminum extrusion heatsink with a very secure clip.
THE TEST
The COOLINK H2Twin (H2T) was first tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences. I then tested it on an Iwill KK266+, modified to read AMD’s on-die diode, as an example of what users might see on their systems.
TEST RESULTS – CPU Simulator
Heatsink
Die Temp
Ambient Temp
Delta
C/W
COOLINK H2Twin (H2T), 77.6w
47.0 C
19.5 C
27.5 C
0.35
TEST RESULTS – Motherboard
CPU/Motherboard
CPU Die Temp
Ambient Temp
Delta
C/W
CPU Back Temp
Palomino 1200, Iwill KK266+
32.9 C
18.7 C
14.2
0.26
35.3 C
In-socket thermistor per MBM: 25C
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU core temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Die Simulator results place the COOLINK H2Twin (H2T) in the top rank of heatsinks (Heatsink Ranking).
CONCLUSIONS
With a better base finish, the COOLINK H2Twin (H2T) will most likely perform better, pushing it up further in the rankings. All told, this is a nice cooling solution for the performance and fail-safe minded consumer.
Thanks again to Coolink for sending this our way. They are looking for US distribution, so if interested, drop them a line. Their website shows a wide variety of designs available.
  1. COOLINK U2Power (U2P)
  2. Overclockers Tech: Coolink SWIF2 & Noctua NHU12-P SE2
  3. Determining Heat Sink Efficiency Using Thermal Diode Temperatures
  4. JAMITECH 5E34B3
  5. SIBAK IC-01
Tags:
