Copper Foam Heatsink
SUMMARY: Metallic foam structures have interesting properties as a heatsink material.
Cu Foam Fan
The fan pictured above is 70 mm x 10 mm.
I happened to come across a potentially new heatsink material – copper foam. This is derived from a very interesting fabrication process which turns various metals into what looks like metallic sponge. Under a microscope, you can see its sponge-like quality:
Micro
The porous nature of the material allows the relatively easy passage of air/fluids through it (how easy depends on the density of the pores, although the more dense, the higher the pressure drop). For a given size, metallic foams can be 5 to 10 times larger in surface area compared to a similar sized flat plate. The attraction for electronic cooling is its ability to achieve high heat-transfer within a compact footprint¹. For example, some studies have shown that compared to a pin fin array, foam is three times more efficient.
One of the issues with copper foam is its wicking nature – if you solder foam to a plate, you may wind up with substantially less surface area – it does act as a sponge and will wick solder very quickly, filling its pores with solder and thereby reducing its effectiveness. There are techniques which can minimize this effect, such as flame spraying, which must be used to attain maximum heat transfer.
An Example
The pictures below show an example of a dense copper foam:
Cu Foam Cls
The sponge-like structure is evident and a side view shows its continuous structure:
Cu Foam Side
As an example of this technology for use in a heatsink, a layer of copper foam was bonded to a copper plate using thermal epoxy:
Cu Foam HS
The copper plate has a number of holes to enhance airflow through the foam (lateral flow through a large cross section falls off quickly due to its dense nature):
HS Base
The height of this assembly with a 10 mm fan is less than 1″ thick.
  1. Copper Foam Heatsink II
  2. Foam and Flame
  3. Carbon Foam Waterblock
  4. Trig Copper Heatsink T501
  5. How To Screw Up Your Brand New $70 Case with only $5 of Spray Foam
Tags:
