So you want to overclock a CuMIne with a BX board? Helpful hints.
Things to remember:
1) What PCI divisor is your machine using? If you are trying to run at 115 MHz or better, and your motherboard allows you to use a /4 divisor; use it! Otherwise, you are overclocking every PCI device, and once you get above 120 MHz, a lot of them don’t like that at all.
2) AGP video cards are the biggest challenge to overclocking a CuMine on a BX board. Unlike the PCI divisor on recently produced BX boards, you can’t lower the AGP/bus ratio below 2/3. Some video cards just won’t run at 133Mhz or better. Others will, but you may find that it changes to AGP 1X mode, which may defeat the purpose of the whole exercise for gamers. If that is the case, you can:
3) See how well others have done with the same memory you have. Some memory can run a lot faster than its rated speed. Some can’t. If you have older RAM, you might want to check BX Boards to see how others have done with your RAM. Those shopping for newer RAM can look at BX Boards on PC 133 and a couple of Anand’s articles on the subject.
No guarantees unless the RAM is rated at the speed you want to hit, just likelihoods.
Good luck!
Related posts:
- Coppermine Overclocking and AGP Speeds
- Coppermine Overclocking Issues
- Near-term Athlon and Coppermine Overclocking
- New Coppermine cC0 Chips
- Coppermine cC0 Chips
Tags: Processors
