Corsair Launches Vengeance Pro Series DDR3 Memory
Add Your Comments
Not much needs to be said to introduce the latest news from Corsair out of Computex. See the below press release for full details on the newest Vengeance Pro Series:
Vengeance Pro Memory Module
COMPUTEX 2013 TAIPEI, Taiwan — June 4, 2013 — Corsair, a worldwide designer of high-perform­­­­­­ance components to the PC hardware market, today announced the Corsair Vengeance Pro Series of high-performance DDR3 computer memory for PC overclockers, enthusiasts, and system builders. Available initially in capacities up to 64GB and speeds up to 2933MHz, the Vengeance Pro Series memory modules are designed to set new levels of value and overclocking performance with the 4th generation Intel® Core™ processor family (codenamed Haswell) and previous generation Intel and AMD platforms.
Vengeance Pro Series memory modules are built with eight-layer PCBs and RAM ICs specially selected for speed and overclocking headroom, and like all Vengeance memory, incorporate XMP 1.3 profiles allow for automatic, reliable overclocking. The memory kits are designed with new aggressively styled, aluminum heat spreaders for superior cooling. The memory kits are available in black with silver, red, blue, or gold accents to enable enthusiasts, gamers, and modders to customize the look of their PCs.
Vengeance Pro Series memory is designed to deliver class-leading value and are backed by a life-time limited warranty. An optional Vengeance Pro Airflow fan is available for superior thermal performance at high memory clock speeds.
Technical Specifications
  • Unbuffered DDR3 SDRAM in 240-pin DIMM
  • Aluminum heatsinks (44mm high)
  • 8GB, 16GB, 32GB and 64GB (2×4, 4×4, 2×8, 4×8, 8×8)
  • 1600MHz, 1866MHz, 2133MHz, 2400MHz, 2666MHz, 2800MHz, 2933MHz (requires 4th Gen Intel Core processor)
  • Intel XMP 1.3 (Extreme Memory Profile) support
  • Black with silver, blue, red, or gold accents
Optional Vengeance Pro Airflow Fan
·         Single 60mm ball-bearing fan, speed variable from 2500RPM to 3500RPM
  • Noise level of 21.0 dB(A) at low speeds to 25 dB(A) at high speeds
  • Fan life of 80,000hrs at 25 degree Celcius
  • Variable mounting brackets adjustable between socket formats
  • Replaceable fan shroud cover in red, blue and silver
Memory Kit Configurations
The following Vengeance Pro Series memory kit configurations are available:
Size
Speed
# of DIMMs
Part Number
16GB
2933MHz, 12-14-14-36, 1.65V
4
CMY16GX3M4A2933C12R
32GB
2800 MHz, 12-14-14-36, 1.65V
4
CMY32GX3M4A2800C12R
32GB
2666 MHz, 11-13-13-35, 1.65V
4
CMY32GX3M4A2666C11R
16GB
2
CMY16GX3M2A2666C11R
32GB
2400MHz, 10-12-12-31, 1.65V
4
CMY32GX3M4A2400C10R
16GB
2400 MHz, 10-12-12-31, 1.65V
2
CMY16GX3M2A2400C10R
32GB
2133 MHz, 11-11-11-27, 1.5V
4
CMY32GX3M4A2133C11
16GB
2
CMY16GX3M2A2133C11R
8GB
2
CMY8GX3M2A2133C11
32GB
1866 MHz, 9-10-9-27, 1.5V
4
CMY32GX3M4A1866C9
16GB
2
CMY16GX3M2A1866C9
8GB
2
CMY8GX3M2A1866C9
32GB
1600 MHz, 9-9-9-24, 1.5V
4
CMY32GX3M4A1600C9
16GB
2
CMY16GX3M2A1600C9
8GB
2
CMY8GX3M2A1600C9
Here are some more photos courtesy of Corsair for your enjoyment:
These kits will be expensive, but as Corsair states the quality should be higher than typical memory with the eight-layer PCBs and ICs selected specifically with overclocking in mind. Hopefully we’ll be able to test drive some Vengeance Pro Series memory to see if meets our Overclockers.com performance standards.
Matt Ring (mdcomp)
Leave a Reply
Discussion
  1. I picked up one of these new sets today: 2x4GB 1866Mhz. The specs are nice and so was the price! Looks pretty good also, I had the silver one because it was on sale at about 5$ cheaper than the other colours. :)
    Z77 boards can make up to ~3200 but CPU's memory controller probably won't pass 2800 on air/water.
    Most IB will make stable DDR3-2600 while Haswell can make 2900+. That's why these kits are marked as designed for Haswell.
    I have a failed understanding here.
    My Z77 board claims to be able to handle ram up to 3000Mhz, why does it say i need a Haswell to be able to run close to the 3000mhz with this ram?
