Corsair Survivor 32 GB USB Drive
Add Your Comments
Fast access time, huge capacity and rugged – overall a good package – Joe
SUMMARY: Fast access time, huge capacity and rugged – overall a good package.
Pic
The good guys at Corsair were nice enough to send a sample of the Corsair Flash Survivor ™ to try out. This is a 32 GB (yes – 32GB) pen drive that, aside from its stunning size, is ruggedized in an extremely sturdy, waterproof aluminum case.
Key Features:
  • Bootable
    Pic
    Booting the Survivor on a Dell Vostro 200
  • Activity LED to indicate data transfer activities
  • Encased in CNC-milled, anodized aircraft-grade aluminum
  • Water resistant to 200 meters
  • Shock dampening rubber collars
  • USB 2.0, backward compatible with USB 1.1
  • Includes the True Crypt security application (Windows Vista/XP/2000 compatible only)
  • USB extension cable and Dog Tags included
  • Limited 10-year Warranty
  • MTBF 1,000,000 hours
Unscrewing the top reveals the drive:
Pic
To give an idea of its size, its pictured with a US quarter dollar coin:
Pic
Waterproofing is achieved by using a rubber “O” ring which seals the case tightly when screwed down:
Pic
Parts that ship with the drive include a USB extension cable (good for tight-fit situations) and a bead chain with Corsair dogtags:
Pic
This is a very protected drive – drop it, dunk it, wash it, whatever – it will take a LOT of punishment when sealed; the Survivor is the perfect drive to take on a boat.
32 GB Storage Capacity
A 32 GB drive has a LOT of room:
Pic
There are smaller versions available in 4, 8 and 16 GB flavors. This opens the question of what all this space can be used for. In addition to carrying around large files, I see two other uses:
  1. Bootable OS
  2. Portable Application Software
The first is self explanatory – create your own portable PC using another PC’s hardware. The issue you have to deal with is the availability of a USB bootable PC (older PCs will most likely not do this). Most internet cafes should be OK on this score.
The second gets around the bootable issue, but you still need access to a PC. I have listed a number of links at the end of this article which link to a growing list of portable software apps. All this software will run solely on a USB drive – it does not tie to any specific PC to run. Unless you have some very specific software you need, there are enough software choices to cover the usual productivity, internet and email needs as well as some specialized apps.
TrueCrypt Software
I’m not familiar with TrueCrypt and after some searching around found this from TCExplorer:
“TrueCrypt is a free open-source disk encryption software able to create a virtual encrypted disk within a file and mount it as a real disk. The encryption is automatic, real-time (on-the-fly) and transparent. However, a major disadvantage of TrueCrypt is the requirement of administrative privileges on the computers where they are used.
Thus they will not be usable in places such as public libraries and internet cafes, where the computers are typically locked down and the users are given only limited privileges. The purpose of TCExplorer is to overcome this limitation of TrueCrypt by providing an interface, similar to compression and decompression software, where directories and files can be imported and exported easily from TrueCrypt containers.”
There may be other encryption options available – I’d appreciate any comments on this readers may wish to share.
Performance Test
I ran a performance benchmark using HD Tach:
Pic
Highlighted in red is the random access speed – 2.4 ms – this is one fast drive! According to Wikipedia “Random access time (seek time) currently ranges from just under 5 ms for high-end server drives, to 15 ms for miniature drives, with the most common desktop type typically being around 9 ms.” Most flash drives are not this fast, although some high-performance drives may be faster.
However Sequential Read Speed is on the slow side – I’ve seen pen drives in the low 30s for the faster drives, so this is not the fastest around. I used SiSandra to benchmark the Survivor against other flash drives over 1 GB:
Pic
Corsair’s Voyager series beats out the Survivor, but as file sizes increase, the Survivor starts to pull ahead of the competition. Considering that a drive of the Survivor’s size will most likely be used for fairly large files, it appears very competitive.
CONCLUSIONS
Corsair’s Survivor 32 GB flash drive is a must for the road warrior that routinely faces extreme hazards, such as flash floods and rock slides. Its outstanding storage capacity and survivability may seem like overkill to some, but for critical large file portability, a very nice solution.
I can certainly see its use as a bootable travel PC – what better way to take along a PC than in a large, bootable flash drive. The alternative using portable software apps is compelling. I’ve used internet cafes in Europe, South America and the Far East, and if all you need is occasional access and some productivity apps, Crucial’s Survivor looks like a cool way use another PC’s hardware to run your own OS, software and files in privacy.
Street price about $200.
Email Joe
Appendix: Portable Application Software
The following are links to various free portable application software:
Snapfiles.com
Pegtop
PortableFreeware.com
PortableApps.com
Wikipedia – PortableApps
Makeuseof.com – Portable Software
USB Windows
USB Ubuntu
PenDriveApps.com
Portable apps that every tech needs
quate.net
Portable apps for making a USB super stick
Freewarelist portable apps
App-stick.com
Leave a Reply
