Corsair XMS xpert TWINXP1024-3200XL
Memory test – Joe
SUMMARY: Very good RAM, great packaging.
Package
The good guys at Corsair Memory were nice enough to send a sample of their XMS xpert TWINXP1024-3200XL to test. Now this is pretty nifty stuff – an LED display attaches to the DIMMs to read out frequency, temperature and voltage; in addition, you can program it to display a scrolling message – the mind boggles at the thought. Finally, something new under the sun!
Key Features:
  • Large 10-digit alphanumeric display 0.4″ (10mm) tall display
  • Displays real-time memory parameters:
    • Shows measured-on-module voltage
    • Displays temperature under heatsink, user selectable Centigrade / Fahrenheit
    • Integrated crystal measures actual memory frequency
  • Up to three user-programmable scrolling marquee, 23 characters per marquee, adjustable scroll speed
  • Two LED bars show level of memory activity
  • Lighted Corsair sails at each end of display
  • CD with Corsair “Memory Dashboard” software
The Memory Dashboard is a nice feature:
Dashboard
Pic courtesy of Corsair
You can track key variables, among other options – for more details on this see the
Memory Dashboard Manual.
Product Details
Normally with RAM, I take a “beauty shot” and that’s it – one stick is pretty much looks the same as any other. In this case, however, Corsair’s XMS xpert warrants a few pics. First, they are a matched set of DIMMs and LED modules:
Displays
You mate the LED to the DIMM – it’s keyed so you can only snap them together one way:
Fit
The green tab mates to a slot in the LED module.
The assembled package
Assembled
Looks like an “L”:
Edge
The directions suggest that you mount the DIMM first and then snap on the LED module after; you can mount the LEDs such that two adjacent DIMMs will fit no problem. Fire them up and…
Display
Freq
Volt
Temp
There is also scrolling text that I could not capture with a camera (the digits changed too rapidly for the camera) – note that this text can be changed by the user.
{mospagebreak}
The Test
I used the UXD RST Pro2 Memory Tester. RST Pro2 is a stand-alone PCI card that only requires RAM, CPU and video on the motherboard – it is OS independent, self booting and runs 30 different memory tests to determine the point of failure.
Test
Screenshot (literally) of the RST Pro2 test series – note the failure.
In running this test, I used an ABIT NF7-S motherboard, detuning the CPU so that it would not be a factor in testing. The only items populating the motherboard were the RAM, CPU, videocard, floppy and RST Pro PCI card – not much of anything to get in the way. I ran two sticks of 512 simultaneously to test how well they interacted.
Each test loop takes about two hours; if a failure was detected, I stopped the test and ran another series until it passed 5 test loops – about 10 hours for each “Pass”. I ran these tests at voltages ranging from 2.6 to 2.8v.
Corsair XMS xpert Memory Test – 2 x 512 MB
Memory Timing @ Voltage
CPU Setting
Memory Speed
FSB/RAM Ratio
Pass/Fail
5 2 2 2.0 @ 2.7v
5 x 131
437
3:5
PASS
7 3 3 3.0 @ 2.8v
5 x 133
446
3:5
PASS
At Corsair’s spec memory settings (5222), I found it stable up to 437 MHz at 2.7 volts – 9.3% over the spec 400 MHz; increasing voltage to 2.8 volts had no beneficial impact – it would post above that but with increasing errors as speeds went up. It’s possible that some may be able to post and run benchmarks with minor or no apparent errors at speeds above what I found. I suspect going over 2.8v might add a couple of MHz, but IMHO not worth it.
Relaxing timings to 7 3 3 3.0 bumped the speed to 446 MHz – a 11.5% increase – not as much a gain as I expected; relaxed timings such as this will negatively impact on-screen performance, and considering the minimal gain, not worth it.
CONCLUSIONS
Corsair’s XMS xpert does the job nicely at spec memory settings (5 2 2 2.0) at 2.7 volts and can be pushed a little further with detuned memory settings. The LED module and monitoring software make this a very nice package – I can only imagine what messages users might program into the scrolling display.
Thanks again to Corsair Memory for sending this our way to test out and to the good guys at Ultra-X for updating me to RST Pro2.
  1. Corsair XMS TWIN2X-2048 6400C3s
  2. Corsair TwinX1024-3200XLPRO
  3. Corsair TwinX1024-3200LLPRO
  4. Corsair Labs 2009: Home Theater PC Build Log
  5. Corsair TwinX1024-3200LLPRO, Revisited
Tags:
