Criticool PowerPlant
Add Your Comments
Simple PC controlled AC relay, but use with caution – Joe
SUMMARY: Simple PC controlled AC relay, but use with caution.
CritiCool PowerPlant
The good guys at CritiCool were nice enough to send a sample of their CritiCool PowerPlant. This is a nifty piece of gear that switches AC power on when the PC is powered up, by use of a 12 volt relay. For those using 120 volt AC waterpumps, this is a desirable addition.
Hooking up the card is simple as 1-2-3:
  • Insert the card in a PCI slot
  • Strip waterpump wires
    Block
  • Insert the Green wire into slot 1 and tighten the screw
  • Insert the Black wire into slot 2 and tighten the screw
  • Insert the White wire into slot 3 and tighten the screw
    Edge
  • Plug the power cord into the card and wall plug
  • If the switch is UP, AC power is ON when the PC turned ON
  • If the switch is DOWN, AC power is always ON
  • An external 12 volt device can also be switched
It’s pretty straightforward – nothing esoteric here.
However, be warned that 120 volt current is ALWAYS running through the card, so touching it when plugged in is a big NO-NO.
CONCLUSIONS
A quick and easy way to add a 120 volt relay to your PC, although exposed terminals are a shock hazard.
Thanks again to CritiCool for sending this our way.
Email Joe
Leave a Reply
