D-TEK White Water Waterblock
Add Your Comments
Waterblock Test – Joe
SUMMARY: Excellent choice for CPU cooling with moderate power waterpumps.
DT WW
The good guys at Cooltechnica were nice enough to send a D-TEK White Water waterblock to test; this is the original aluminum topped block and represents a bit of history – in its day, this design broke new ground. The White Water is a flow impingement design with micro-channels. As such, this waterblock has a moderate pressure drop and requires a waterpump of sufficient power to extract top performance.
THE TEST
The D-TEK White Water was tested using the CPU Die Simulator and Waterblock Test Rig.
WATERBLOCK TEST RESULTS
Test Conditions: Inlet Water Temp: 28.5 C; Mounting force: 15 pounds; Heat Load: 70 Watts.
Plot
Waterblock
C/W
Pressure Drop – psi
Pressure Drop – inches H2O
D-TEK White Water
0.13
0.82
22.7
NOTE: These results are NOT comparable to tests done by others.
Unrounded data: 0.130 C/W with 0.0025 std dev.
Test Results indicate that the D-TEK White Water’s pressure drop (or head loss) across the waterblock is moderate; resistance such as this means that White Water needs a moderately powerful waterpump to extract maximum performance, especially if other components in the system are restrictive.
For a comparison of the D-TEK White Water’s performance to other waterblocks tested to date, see Overclockers.com Waterblock Test Results.
CONCLUSIONS
The D-TEK White Water waterblock is an excellent choice for CPU cooling, although extracting top performance requires a moderate power waterpump. If other components are connected in series, top performance will be compromised.
Thanks again to Cooltechnica for sending this our way.
Disclosure: Joe Citarella has a financial interest in a company developing thermosyphon products for electronic chip cooling.
Email Joe
Leave a Reply
