Danger Den D5 Monsoon Premium
Add Your Comments
Intro / Closer Look
If you have been following water cooling, Danger Den is best known for their GPU blocks and stylish acrylic cases–I have a Torture Rack myself–, but Danger Den has decided to expand their product line and the first step in this expansion is the D5 Monsoon Premium Bay Reservoir. If you frequent the Xtreme Systems Liquid Cooling section, you have been seeing sneak peeks during prototyping and the final production phase. The popularity of the thread at XtremeSystems is clear evidence of how hungry the community has been for a dual bay reservoir since the Primochill Typhoon III entered the market and was later pulled to correct problems. We have seen prototype images of the Primochill Typhoon 4, so maybe a comparison test will happen in the future. However, the matter at hand here is the Danger Den Monsoon, so let’s focus and start with some eye candy.
Danger Den Boxes containing the Monsoon and the extra annodized face DD sent The typical box contents phot
Still in its shipping foam blanket A better look at the Danger Den D5 Monsoon
In the second photo above, you can spot the additional mounting hardware in the clear plastic clamshell. The Monsoon is not as wide as a standard ATX 5.25″ Bay, Danger Den includes ISO Mounts (Isolation Mounts) to secure the Monsoon in your 5.25″ bays. Since the ATX 5.25″ standard is followed ever so closely by case manufacturers–yes, there is sarcasm in that statement– Danger Den also includes thin pads to help with the snug fit. You will need to do a dry mount to verify whether you need the additional pads along with the ISO Mounts for mounting and to help lessen vibration. On the top side, we also have the two fill ports plugged with standard G1/4 stop fittings nestled into small overflow basins. “Why two?”, you ask. My guess is for maintaining the visual symmetry. And my guess would be wrong… the second port is there as an air release to aid the fill/bleeding process.
With the packaging and unboxing photos behind us, time to take a closer look and cover some details, but I will let you feast on more photos first… Yes, I am fully aware of the dust in the photos, it is winter in Minnesota and dust wins the battle because I value my sanity over trying to clean every speck from the photos.
Danger Den Monsoon D5 gives us the fancy profile pose EK Dual D5 pumps mounted side view EK Dual D5 pumps mounted top view
First, we pop the lid on the D5 cover, which I will say it is nice to have a cover in the first place, this not only adds to the overall look of the Monsoon but hides the ugly caboose on the D5. As I was securing the lid on the back I did notice one issue, the wires appear to be a bit fat for the lid to sit flush. Small issue, but do not be alarmed if you have the same problem. The final two shots of the group are pretty much requirements any time we talk pumps, we just have to show the business end (pump head and volute) of the pump top (bay reservoir). On the inside, we do not get a view of the chamber that feeds the two outlet ports, this is a sealed compartment and I did not want to take the risk of breaking the unit for a single photo. You will have to use your imagination here. Sticking with the inside of the reservoir, the Monsoonr holds roughly 350mL of water, which is a little larger than your standard tube reservoir.
Close up of the light module Light PCB close up Danger Den Monsoon assembled and ready for testing
The last photos we have to share are of the integrated lights (wired for 5v and ground) with the control buttons on the face. The button on the left (when looking at the face) controls the outer lights, right button the inner lights. Buttons are simple on/off, which for me took me a minute to figure out the overly simple controls. I also snapped a shot of the light PCB in case you were wondering how you could replace the LEDs with the color of your choice. Presently the only LED color options are red, blue and UV. The last photo of the set is the Monsoon re-assembled and ready to hit our pump bench.
Continue reading at Skinnee Labs to get all the performance details…
Leave a Reply
Discussion
  1. skinnee
    I finally got my hands on the XSPC, more testing to come. :)
    Also, I am going to try this article layout for most pumps/tops... but it is a struggle to write this much good information about a pump top.
    Very cool Skinnee,
    I don't know about anyone else but I know that your testing has been the deciding factor on many of my purchases.
    I only wish you had more products to test and the time to do them :D
    skinnee
    I'm sure the article will be full of useful info, just like all your others :)
    Look forward to the review, Skinnee
    I agree Bijiont, I bought the XSPC dual over this because of price primarily (and the fact that this wasn't out a month ago :D)
    Looks pretty sleek, the front looks nicer than the XSPC imo, but the pump protruding from the back like that is kinda meh, idk.
    Very nice review, it was an interesting read as always from Skinnee.
    I just can't justify the price when I can get a XSPC for less than half of a Monsoon.
    That is just me.
    brings up the interesting question of whether or not to split your loop, and what an interesting question it is. I think that there's no real way to say whether or not it would benefit without looking at individual setups. Great writeup skinnee, it's given me something to think about!
