Danger Den GPU Maze4 Waterblock
Waterblock Test – Joe
SUMMARY: A very good choice for GPU cooling, with low pressure drop.
WB
The good guys at Danger Den were nice enough to send a Maze 4 GPU Waterblock to test out.
Danger Den’s GPU Maze4 GPU Waterblock features
  • ½” Chrome fittings
  • Copper base
The base
Base
appears well machined – I could feel no ridges.
THE TEST
The Danger Den GPU Maze4 Waterblock was tested using the CPU Die Simulator and Waterblock Test Rig.
WATERBLOCK TEST RESULTS
Test Conditions: Inlet Water Temp: 28.5 C; Mounting force: 15 pounds; Heat Load: 70 Watts.
Plot
Waterblock
C/W
Pressure Drop – psi
Pressure Drop – inches H2O
0.17
0.26
7.2
NOTE: These results are NOT comparable to tests done by others.
Unrounded data: 0.171 C/W with 0.0005 std dev.
Test Results indicate that the Maze 4′s pressure drop (or head loss) across the waterblock is low; flow resistance at this level means that daisy-chaining it with a low pressure drop CPU waterblock and moderate waterpump is an OK move. Decreasing waterflow to 0.5 gpm increases die temps by about 2.0º C, while increasing flow to 1.5 gpm decreases die temps by 1.0º C.
For a comparison of the Danger Den Maze 4′s performance to other GPU waterblocks tested to date, see Overclockers.com Waterblock Test Results.
CONCLUSIONS
Danger Den’s Maze 4 GPU Waterblock is a very good choice for GPU cooling, with its low pressure drop and good performance; this is particularly important you use daisy-chaining to cool other components.
Thanks again to Danger Den for sending this our way.
  1. Danger Den Chipset Maze4 Waterblock
  2. Danger Den Maze4
  3. Danger Den Pin-Fin Waterblock
  4. Danger Den Copper Waterblock
  5. Danger Den TDX
Tags:
