Diamond TIM
Add Your Comments
A DIY – Joe
I happened to come across some diamond powder and thought it might be interesting to see what it could do mixed with some plain white thermal grease. Diamond has terrific thermal conductivity – far better than the usual suspects:
Thermal Conductivity of Selected Common Materials
Material
Thermal Conductivity (W·m-1·K-1)
Diamond
895-2300
Silver
429
Copper
386
Gold
317
Aluminium
237
Air
0.0262
Up to four times better than silver – impressive!
The reason diamond is so much better has to do with its crystalline structure – apparently the strong linkages within this matrix conducts heat very efficiently; it also accounts for its other properties, such as its hardness.
The diamond powder I used was 9 microns in diameter – there are many sizes available, including sub-micron diameters. It looks like a fine, gray talcum powder. This material is not cheap, so I only tried the 9 micron size. I used a Glaciator Lite on the die-tester for this test – results below:
The Test
Thermal Grease
Die Temp
Ambient Temp
Delta
Plain White
45.2
22.2
23.0
Diamond + White
47.5
22.5
25.0
This was the best I could do after trying various mixtures – this was about 1 part powder to three parts white grease – other mixtures were worse.
CONCLUSIONS
Making thermal grease is a lot more than just mixing some stuff together – it takes time to test out various formulations, not to mention life-cycle testing. Diamond’s thermal properties are tantalizing and I bet there’s a way to make a superior TIM with it.
Email Joe
Leave a Reply
