DIY SocketA/370 to P4 Adapter
Add Your Comments
How-to recycle socket heatsinks to P4 use – Hatim
Adapter
After checking out the post on the SocketA/370 to P4 heatsink solution,
I couldn’t resist showing you what I had done a few months ago.
It’s completely home grown as you can see…and takes less than 15 minutes
to do. My favourite HHC-001 finally got itself a home in my P4 machine.
Simple nuts, bolts, an aluminium angle to extend to the P4 hole
configuration and that’s it! Looks a little crude though, but I like it
that way 😉
Cheers!
Hatim
Leave a Reply
