Duron 650 Overclocking Results
Add Your Comments
SUMMARY: The flexibility of settings FSBs and multipliers gives the Duron some added performance benefits.
As I continue to play with the Duron 650/Asus A7V, I see some value in having the flexibility to vary both the CPU’s multiplier and FSBs. For example, it looks like the stable best I can do with this CPU is 927 MHz (water cooling). Now I can get 927 two ways – 9 x 103 and 8.5 x 109 with the following performance differences:
Benchmark
9 x 103
8.5 x 109
% Diff
Si Sandra CPU/FPU
2591/1292
2595/1292
0.2/NA
Si Sandra Mult Med
3159/4332
3159/4330
NA/NA
Si Sandra Memory
444/548
466/581
4.9/6.0%
3DMark 2000
7399
7532
1.8%
Quake
127.7/123.1
131.4/127.2
2.9/3.3%
Content Creation
33.9
34.2
0.9%
Pi Solver
846
818
3.3%
Duron 650, ASUS A7V, Leadtek GTS2, 128 MB HSDRAM, Monitor @ 800 x 600.
The difference in FSBs of 5.8% translates into 5-6% higher Si Sandra Memory scores – basically a 1-1 benefit. What is interesting is the relatively uneven impact it has on performance; it ranges from about 3% in Quake’s frame rates to less than 1% in Winstone Content Creation – I would have expected more improvement in this app-intensive benchmark.
Kevin Tam sent me a new (to me) benchmark – Pi Solver. What this does is stress the CPU by finding “X” places of Pi – up to 32 million. What’s nice about this one is it not only stresses the CPU but records how many seconds it takes to get “X” places. In this instance, for 4 million places, at 8.5 x 109 it took 818 seconds – 3.3% better than at 9 x 103 (Note: 32 million places @ 927 took 4 hours, 5 minutes and 19 seconds).
The bottom line is that memory intensive apps, like image or sound editing, will show a performance improvement without any penalties (assuming your peripherals like the higher FSB).
Just for giggles, I also benched the Duron 650 with W98SE and W2000 @ 800 MHz with the following results:
Benchmark
W98 SE
W 2000
% Diff
Si Sandra CPU/FPU
2256/1125
2248/1125
-0.4/NA
Si Sandra Mult Med
2750/3771
2684/3441
-2.4/-2.8%
Si Sandra Memory
436/537
446/522
2.2/-2.8%
3DMark 2000
6908
2971
-57.0%
Quake
117.7/113.9
96.8/90.1
-17.8/-20.9%
Content Creation
32.2
42.7
32.6%
Let’s chalk up the gaming gaps to “immature video drivers” and leave it at that. However, the Content Creation scores are a shocker – no doubt NT is “industrial grade”, but by this much?? We have seen similar results with the T-bird, so we will be doing more testing on this issue.
At this juncture, I am pleased with running a Duron 650 at what appears to be a stable 927 MHz (1.85 v) – a 50% overclock. I am going to set this up as one of my main systems, continue to use it in everyday apps and see how it behaves.
Email Joe
Leave a Reply
