Duron-TBird Head to Head Comparison
Add Your Comments
SUMMARY: Impressive performance, although the T-Bird 750 at twice the cost does not deliver twice the performance. Duron: Price/Performance champ overall.
One of the questions I was asked when we were doing benches on the Duron 650 @ 935 was “How does it compare to the T-Bird?” Not having one, I could not answer the question. Now with the Blue 750 in hand, I ran some benches comparing the Duron against the T-Bird.
I ran two different sets: One comparing the Duron and T-Bird head-to-head, same speed. The second comparing the Duron’s best speed against the T-Bird’s. All tests were on the ASUS A7V with exactly the same components – only the CPU was changed. Results:
Bench
Duron 935
TBird 935
% chg T vs D
TBird 1100
% chg       T vs D
SiSandra CPU
2609/1304
2609/1304
NA
3070/1534
17.7/17.6
SiSandra MM
3188/4370
3186/4370
NA
3749/5142
17.6/17.6
SiSandra Memory
489/599
488/603
NA
489/608
NA
Quake
132.2/127.9
141.6/138.7
7.1/8.4%
152.5/149.1
15.4/16.6%
3DM2000 800x600x16
7545
8150
8.0%
152.5/149.1
15.4/16.6%
3DM2000 800x600x32
6397
6639
3.8%
6796
6.2%
Pi Solver 1M
181 sec
156 sec
-13.8%
140 sec
-22.7%
Content Creation
31.4
33.6
7.0%
36.8
17.2%
ASUS A7V, 935 = 8.5×110, 1100 = 10×110, 1.85 volts, 128 MB HSDRAM 7ns, Leadtek GTS2, water cooled CPU temp 45 C, ambient 26 C.
I did encounter some strange anomalies while benching the T-Bird 750; I did manage to get benches at both 935 and 1100, but at 935 the system just was not stable with the T-Bird. I had many freezes in 3DMark 2000 and Content Creation, while I had NONE with the Duron 650 @ 935. However, the T-Bird ran Prime95 for over four hours at 10 x 110 without a problem, suggesting that the issue may be video related.
I suspected that running the FSB at 110 might be a factor, so I ran the benches with the AMD 750 using 11 x 100 instead of 10 x 110. Result: NO PROBLEMS! I infer from this that perhaps the ASUS A7V may have some stability issues with the more powerful T-Bird. Note that these issues look to be video related – running number-crunching routines like Prime95 or Pi Solver did not exhibit any instabilities.
I will do more experimenting with BIOS settings to see if somehow there are AGP issues that can be resolved.
Meanwhile, I did a set of benches to show the performance difference between running 1100 at 10×110 and 11×100:
Bench
T-Bird 10×110
T-Bird 11×100
% chg
SiSandra CPU
3070/1534
3098/1494
0.9/-2.6%
SiSandra MM
3749/5142
3738/5188
-0.3/0.9%
SiSandra Memory
489/608
457/548
-6.5/-9.9%
Quake
152.5/149.1
149.3/144.4
-2.1/-3.2%
3DM2500 800x600x16
8632
8510
-1.4%
3DM2500 800x600x32
6796
6754
-0.6%
Pi Solver 1M
140 sec
142 sec
1.4%
Content Creation
36.8
34.8
-5.4%
The biggest difference shows up in SiSandra memory scores, with the impact varying across the benches; worst case, expect about a 5% performance hit. In many instances, I doubt you will perceive a difference on the screen. The hit is not too severe and if stability is an issue in your particular app, running at 100 FSB is an OK compromise.
Bottom Line: AMD makes a very impressive CPU, giving Intel a real run for the $, then decides to irreversibly multiplier lock them – effectively thumbing its nose at the “performance market”.
The issue confronting us is the viability of FSB overclocking Socket A CPUs; right now, Socket A motherboards are running “crippled” – none seem capable of getting beyond 120 FSB. Makes you wonder what’s at work here – something we plan to look into more closely.
Email Joe
Leave a Reply
