Dynatron DC1206BM-Y
Very good performance; a skived copper heatsink for P4 cooling – Joe
SUMMARY: Very good performance at reasonable noise levels.
DC1206BM-Y
Size: 88.5 x 62.6 x 40.6 mm; Weight: 488 grams.
The good guys at Dynatron were nice enough to send over a sample of their P4 Heatsink DC1206BM-Y. (Note: This model is identical to Model # DC1206BM-Y/X, which is for INTEL ® Xeon Socket 603/604 use). This is a copper skived unit that weighs in at 488 grams. Skived heatsink are literally carved from one piece of material – in this case, a piece of copper. There are no joints between the fins and the base, and as such there is no efficiency loss.
The fan is an Top Motor Model #DF1206BH, a 60 x 10mm unit rated at 24.4 cfm @ 5300 rpm, 40 dBA¹. I found it to be tolerably quiet – I measured its noise at 58 dBA with a Radio Shack sound meter 8″ from the fan’s intake, substantially less than a Delta 38 (about 69 dBA). It’s also safe to use on most motherboard fan headers (3.5 watts).
The base is fairly well finished:
Base
There are visible polishing marks that can be slightly heard when dragging your fingernail over it.
The mounting bracket is a good one:
Bracketp
Mounting requires removal of the motherboard; the back plate is held in place with four screws. Once in place, the system is very secure and clipping the heatsink in place is very easy.
THE TEST
I tested the Dynatron DC1206BM-Y on an Acorp 4S845A motherboard with a modified P4 1500 to read CPU case temps. I also tested it on a simulated P4 die which is still undergoing testing. For now, we’ll continue ranking based on motherboard results. The fan averaged 5166 rpm in these tests.
TEST RESULTS – Motherboard
Motherboard
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
Acorp 4S845A
32.3 C
20.4 C
11.9
0.21
30 C¹
TEST RESULTS – P4 Simulated Die
Heatsink
Die Temp
Ambient Temp
Delta
C/W
Dynatron DC1206BM-Y, 74.8w
36.7 C
19.9 C
16.8
0.22
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
