Ed template
Add Your Comments
The iPhone doesn’t seem to be doing very well.
  Take a look here and here for accounts on what seems to be wrong with it, despite what the involved parties are saying or not saying about it .
 The good guys at JETART were nice enough to send a sample of their CoolStand3 Notebook Cooler to try out. This full size laptop cooler features a swivel base and is powered by a USB port.
{highslide}articles/Jetart_CoolStand3/jcs1.jpg{/highslide}
The two bottom clips flip out to hold the laptop in place.
Key Features
  • Swivel Base
  • Fits 11.1″ to 15.4″ notebooks
  • USB powered – 0.7 volts
  • Size 300 x 276 x 23 mm, Weight 800 grams
  • Fan speed 2000 rpm, 21.3 dBA
A look at the base reveals the swivel – this allows users to mount a laptop and swivel it 360°:
{highslide}articles/Jetart_CoolStand3/jcs4.jpg{/highslide}
Opening the unit shows the underside of the cooler’s top, showing the fan and USB cable:
{highslide}articles/Jetart_CoolStand3/jcs2.jpg{/highslide}
The top is held in place with a metal bracket that adjusts the tilt angle from 20° to 50° in six steps:
{highslide}articles/Jetart_CoolStand3/jcs3.jpg{/highslide}
We’ve said it before and we’ll say it again; to us, such situations have a three word solution: Don’t buy it.  You want to spend money on solutions, not problems.  Unless you’re a certified masochist, why buy a problem?
Think about it.
Ed
Leave a Reply
