Enermax T.B. Apollish and T.B. Vegas Quad Fans Review
Ladies and Gentlemen! Welcome to the Big Top! Step right up and prepare to be amazed! A grand light show awaits your senses! Tonight we shall be experiencing Enermax 180 mm fans with Blue LEDs, with Red LEDs, and with four LEDs of splashing, flashing color! And to up the ante, there is a switch on each fan to select any of three speeds! And to top it off, these fans are affixed to their frames with “Vortex” swirl airfoils that straighten the flow coming from the fan. Step right up and come inside!Blaze-400px
This review will focus on Enermax’s Advanced versions of their 180 mm T.B. Apollish red and blue LED fans, as well as the Advanced T.B. Vegas Quad four-LED fan with special effects. These fans were made with fun in mind, but they provide some serious cooling, and careful attention was paid to their design. They are well worth a look.
Enermax is a company well known to computer enthusiasts. Founded in 1990, they sell a lot of products, from fans to heatsinks to cases to PSU’s. The Advanced series has been the company’s update to a number of its fans. Each of the Advanced fans has a three-position switch on the hub that allows a user to select either the speed or the speed range (on PWM fans) to adjust the airflow/noise of a fan. In essence, you buy three fans. No more guessing as to how much of a fan you need.
tbapollish_18_dimension
Diagram From Enermax
T.B. Apollish Features
(from the product page) Model UCTA18A-R / UCTA18A-BL:
  • 18/20cm giant fan for better cooling performance
  • Compatible with 18cm and 20cm mounting holes
  • Shift Speed Control providing 3 cooling modes
  • Patented circular type LED with up to 18 diodes
  • Vortex frame design concentrating airflow to cool hotspot
  • Focus blades centering the light to increase brightness
  • Turbine blades for high-pressure airflow
T.B. Vegas Quad Features
(from the product page) Model UCTVQ18A
  • Blue/Red/Green/White 4-color LED with 6 lightening modes
T.B. Apollish Specifications
Model
Ultra Silent Mode
Silent Mode
Performance Mode
Dimension (mm)
180 x 180 X 20 mm
Speed (RPM)
600(±10%)
900(±10%)
1200(±10%)
Air Flow (m 3/h)
116.55
174.81
209.77
Static Pressure (mm-H2O)
0.895
1.512
2.240
Noise (dBA)
15
18
20
Rated Voltage (V)
12
12
12
Input Current (A)
0.25
0.30
0.50
Input Power (W)
3
3.6
6
MTBF (hour)
50,000
LED Color
Blue or Red
LED Number
18
LED Type
Circular Type LED
Accessory
4 x screws; 1 x 4 pin fan power adapter
Safety & EMC
CE, ROHS
 Note from Enermax: Please wipe the fan blades softly with a microfiber cloth instead of rinsing the fan blades with water. Do not use alcohol or chemicals.
T.B. Vegas Quad Specifications
Model
Ultra Silent Mode
Silent Mode
Performance Mode
Dimension (mm)
180*180*20 mm
Speed (RPM)
600(±10%)
900(±10%)
1200(±10%)
Air Flow (m3/h)
116.55
174.81
209.77
Air Flow (CFM)
68.60
102.89
123.47
0.895
1.512
2.240
Noise (dBA)
15
18
20
Rated Voltage (V)
12
12
12
Input Current (A)
0.30
0.35
0.55
Input Power (W)
3.6
4.2
6.6
MTBF (hour)
50,000
LED Color
4-Color (Blue, Red, Green and White)
LED Number
24 (4 Colors *6)
LED Type
Circular Type LED with 6 Modes
Accessory
4 x screws ; 1 x 4 pin fan power adapter; 1 x adhesive tape
Safety & EMC
CE, ROHS
Packaging and Accessories
Enermax 18 cm fans come in windowed cardboard boxes with slick facing. You can see the fan inside. The features and specs are on the outside.
Packaging
The accessories include four fan screws, which are to be expected. But dig, Enermax uses a Molex adapter that can accommodate PWM on the fan end. That’s a pretty good accessory.
Accessories
The Fans
The T.B. Apollish and T.B. Vegas fans look pretty much the same when they are not lit.
Apollish Red
T.B. Apollish Red
T.B.Vegas  Quad LED
T.B. Vegas Quad LED
The switches are easier to reach than the switches on their 120 mm Advanced fans. In fact, you can stick your finger up to the fan and change speeds without seeing what you are doing – you can’t hurt yourself. In fact, that’s how I changed the speeds on these things while they were on the test box (more later).
Enermax 180mm Exhaust
Apollish Blue
T.B. Apollish Blue
The slender fan blades bear a remarkable resemblance to their first generation, pre-Batwing 14 cm T.B. Silence blades. Since Enermax advertises these as “turbine blades,” it makes sense.
T.B.Silence 14cm, original
T.B. Silence 14 cm, Original
Each blade has a reflective part that takes up half the width of the blade and runs along the length to the end, reflecting the LED’s shining along the rim. In the picture below you can see the reflective part of the blades. The back rim has some LEDs on it.
T.B. Vegas LED Close-up – Reflective Blades
Here is a close-up of some “focus blades.”
Focus Blade Closeup
Focus Blade Close-up
Putting it all together, we see the whole fan here. You can also see the paddle of the T.B. Vegas that allows you to change the light show. Finally, you get a nice view of the dual 20 cm and 18 cm screw holes at the corners of the fan.
Enermax T.B.Vegas
Enermax T.B. Vegas
Testing Setup
The fans were run in free air to register speed and noise. Sound Pressure Level was measured with a Tenma 72-942 Noise Meter mounted on a tripod, placed 10 cm from the fan. The SPL can, in theory, be adjusted downward 20 dB to get the noise corresponding to a distance of 1 meter. Since an 18 cm fan subtends a large disk at a mere 10 cm, expect the noise readings to overstate the SPLs produced by the fans. To preserve of the data across multiple reviews the method will remain constant. Unless an anechoic chamber can be obtained, this is the best we have.
Measuring outflow from a fan presents problems. If you put an anemometer head up against a fan to measure its output, you only get a portion of the airflow because of the air shadow created by the hub. However, at a distance of 1.4 x the fan diameter allows for mixing to overcome the air shadow caused by the hub, but only if all the outflow is captured.
The output airflow of these fans were tested in an 8.5 x 10 inch box, 11 inches long, or 1.55 times the diameter of the fan. The input and exhaust openings were 172 mm diameter circles. What goes in must come out, and what each fan put into the box was measured as it came out by an AN100 Extech anemometer. The anemometer head was introduced into the exhaust airflow and the flow was averaged across ten readings. It may under-read the airflow because the air coming from the fan expanded into the box before exiting. A cylindrical air passage would help that, but we will have to make do with what we have.
Test Equipment
Results
As you can see, the Enermax fans pretty much matched their specs. As expected, the fans measured as noisier than specified.
Enermax 180's - dBA+CFM
Lights! The LEDs!
The Blue LED fan was gorgeous. The T.B. Vegas fan was dazzling. So, I set up the Red LED Apollish. It flashed a rich red, then went dark. Huh? Dark fan? I soon had the culprit… a wire had come loose (see the left picture). Was it reparable? Ha! An adventure awaits! You would RMA a dark fan, but I get the pleasure of fixing it. I love fixing things.
When you want to repair something, it is best if you have an unbroken specimen to look at. Hence, a shot of the Blue LED fan hub. Hmm. Two wires soldered on each of the 12 Volt and ground soldering nubs. That would be hard to do with a precision soldering iron, and mine is not precision.
Apollish Red - loose wire
T.B. Apollish Red – Loose Wire
Apollish Blue - intact wires
T.B. Apollish Blue – In Tact Wires
So, I soldered a single bridge wire to each nub, and soldered the two pairs of fan wires to the bridge wires. It was a crude repair, and I wasn’t sure of the polarity. Further, I didn’t want to risk burning out a PSU testing a fan. So, I used a 9-Volt battery to test it.
A Crude Repair
A Crude Repair
Fan Testing Without a PSU
Uh-oh. The fan spun, but remained dark. I de-soldered the fan wires, reversed the polarity of the LED wires, re-soldered, and tested again. This time the fan ran and the LED’s lit up. All fixed! And did you notice? The reverse polarity did not kill the LEDs.
It was a nice adventure, while it lasted. On to the light show! Here you have the 180 mm T.B. Apollish fans, with their red and blue LEDs.
Apollish Red - Lit
T.B. Apollish Red – Lit
Apollish Blue - Lit
T.B. Apollish Blue – Lit
Now we explore the six modes of the T.B. Vegas. Here are a couple of shots from the Sparkle mode. Your eyes process light better than cameras with their virtual shutters. The pictures below will give you a bare idea of the flickering light patterns in this mode.
TB.Vegas Sparkle mode
TB. Vegas Sparkle mode
More Sparkle
More Sparkle
Then there is the Triple Propeller mode, and what I call the casino mode.
Triple Propeller
Triple Propeller
T.B.Vegas - Casino mode
T.B. Vegas – Casino Mode
Does the Fan Click?
I went back and did some voltage testing. I have a GA-P55M-UD2 motherboard that can manually vary the voltage of the CPU fan. I hijacked that, and put a Y-cable on it. On one arm of the Y, I put the Enermax 18 cm Red, on the other arm I put an analog voltmeter:
4v 0 rpm No LED na
5v 600 rpm No LED clicks
6v 750 rpm dim rustles
7v 830 rpm LED quiet
8v 933 rpm LED quiet
9v 1011 rpm LED quiet
10v 1056 rpm bright quiet
11v 1155 rpm bright quiet
11.8v 1201 rpm bright quiet
The fan did not run below about 5 volts. The LEDs were dark at that Voltage, and the fan clicked. A dim glow appeared around 6 volts, and the fan rustled. At 7 volts and above, the fan’s LEDs shone ever brighter, and there was no clicking at all.
Conclusions
As we have seen before, the Enermax fans matched their specs. When companies do this, you can partly base your fan-buying decisions on specs – always a good thing.
These fans are fun. They also focus the airflow with their spiral airfoils. Those actually work, by the way. And you can switch speeds, which gives you a your choice of speeds rather than buying three fans to pick out the one that best suits your needs.
Availability
180 mm T.B. Apollish Red $19.99 at Newegg, $19.99 at NCIX US
180 mm T.B. Apollish Blue $19.99 at Newegg, $19.99 at NCIX US
180 mm T.B. Vegas $24.99 at Newegg, $24.99 at NCIX US
Enermax Triple Play
Enermax 180 mm fan Pros
  • Bright, cheerful LEDs
  • Three-position speed switch that is easy to reach
  • Air-focusing spiral airfoils
  • Molex adapter is compatible with PWM fans
  • Dual screw hole sets for 180 mm and 200 mm fans
  • No clicking when the LEDs shone
Enermax 180 mm fan Cons
  • None
Click the stamp for an explanation of what it means.
 - Ed Hume (ehume)
Tags: , , , , , , , , , , , , , ,
6 Comments:
Bobnova's Avatar
Those are pretty seriously glorious fans.
Thanks for the review, and for getting the equipment to do fan reviews right! That's rare and awesome.
Robert17's Avatar
Nice review. Those are some serious blowers, worthy of consideration. Thanks for your efforts.
kamran's Avatar
it looks really ugly and stupid with all the 3 colors blue or red only isn't bad ! i didn't really like the look, the airflow and temps may be good
ehume's Avatar
They are neither ugly nor stupid, and one nice thing about the T.B.Vegas is you can turn the lights off. And you're right about the airflow. Those 180mm babies really blow some air. I was surprised that the thin blades on the impeller do such a good job of getting air through the "vortex" vanes. But it happens.
One thing: I compared my 8x8x8 box (for 140mm fans) before and after I put in a cylindrical air path. The airflow as measured went up 11-12%. So if the same holds true for other large fans, the 180mm fans would be right on spec, rather than essentially on spec.
kamran's Avatar
i ment the look is only looks ugly for me !
i would turn them only blue btw i dont know if its camera but there are lines showing the color, i dont really like that my current fans are transparent and when they rotate they make a flat surface with red light !
ehume's Avatar
If you see lines, it's the shutter speed.
Leave a Comment
