Enermax NAXN ADV 650 W Power Supply Review
Add Your Comments
Previously we looked at a massive (1500 W) Enermax unit, today’s unit is a rather more reasonable 650 W. It also has something interesting, flat cables. Not just flat cables for some connectors, but flat cables for all the connectors! Even the ATX24P connector! Everything! That’s a rather interesting idea if you ask me. Beyond that we also get 80+ Bronze and a sub-$100 price tag, putting this unit straight into what is arguably the toughest price bracket. How will it match up with the competition? We’ll find out!
Features
Direct from Enermax’s product page for the NAXN ADV (not to be confused with a mere NAXN, mind you), we have the features list! My thoughts are in grey italics.
Efficiency
  • 80 PLUS® Bronze
    84 to 88 percent efficiency at 230V and 20 to 100 percent load. 80 PLUS® Bronze certified.
  • ErP Lot 6 2013 ready!
    Help systems to meet the latest EU eco-design directive ErP Lot 6 2013 (< 0.5W in standby mode*) due to an improved, high-efficient 5V standby (+5Vsb) circuitry.
    *only in combination with an ErP Lot 6 2013 ready mainboard
  • ENERGY STAR 5.0 ready!
    Support computer systems to meet ENERGY STAR 5.0 standard.
Power
  • Full GPU & CPU Power
    Massive 12V rails to power high-performance processors and graphics cards. More than 98 percent of the total power of the PSU can be delivered by the key rails only. I count one (1) 12 V rail.
  • Full Gaming Power
    Min. two 6+2P (8P) PCI-E connectors to power the latest high-end graphics cards and multi-GPU systems (CrosfireX™ & SLI™).
Connectivity & Compatibility
  • Flat Cables
    Simplify the cable routing and enhance the airflow inside the case. I don’t know about simplifying, but it certainly makes it easier to stuff ’em behind trays and such.
  • Intel ATX 12V v2.3
    Compliant with the latest desktop power supply design guide. Full support of most current Intel® and AMD® CPU.
  • Worldwide Compatibility
    100-240V AC input with automatic adjustment and up to 99% active Power Factor Correction (PFC) for global usage.
Cooling
  • Silent Cooling
    Durable two ball bearing fan with advanced fan speed control for optimal cooling, minimum noise and longer lifetime. Ball bearings last a very long time indeed. They aren’t the quietest, but the long life helps offset that.
  • SpeedGuard
    Ultra silent and powerful cooling performance due to the advanced and intelligent fuzzy logic fan speed control. Translation: It’s a temperature controlled fan.
  • AirGuard
    Patented air-intake with optimal aero-dynamical design reduces noisy air turbulences. Having looked at the normal looking fan and grill, I’m not sure what they’re talking about here.
Quality & Safety
  • High-quality Japanese Capacitors
    Highest Enermax quality standards for leading stability and maximum durability. That’s an “s” there on capacitors, that means more than one. I’ll check!
  • Non-Stop 24/7 @ 40°C
    Non-stop industrial class performance at 40°C/104°F ambient.
  • SafeGuard
    Multiple protection circuitry of OVP, DC UVP, OPP, SCP and SIP. I have no idea what SIP is. The rest sound good to me.
  • CordGuard
    Fixing the AC cord tightly to avoid accidental shutdowns of your PC. This is pretty cool.
Dimensions & Warranty
  • Compact, Scratch-resistant Housing
    Dimensions: 150 mm x 86 mm x 140 mm (W x H x D)
  • Warranty
    3 years vendor warranty
Included in the delivery
  • NAXN 82+ Advanced power supply
  • AC cord
  • Cable ties
  • 4 screws
  • User Manual
Pretty specific list there. We’ll check that stuff out in the Cables section. Before we get to that though, we have specifications.
Specifications
Model / DC Output +3.3V +5V +12V -12V 5Vsb Peak Power Total Power
ETL450AWT 16A 15A 34A 0.3A 2.5A 495W 450W
105W 408W 3.6W 12.5W
ETL550AWT 18A 15A 42A 0.3A 2.5A 605W 550W
120W 504W 3.6W 12.5W
ETL650AWT 20A 20A 50A 0.3A 2.5A 715W 650W
120W 600W 3.6W 12.5W
600 W of 12 V on a 650 W unit implies a classic layout rather than the bleeding edge DC-DC bits. Not surprising considering the price and market. No word on how long the peak power can be sustained.
Cables & Connectors
ETL450AWT ETL550AWT ETL650AWT
ATX12V
20+4 Pin
1x (55cm) 1x (55cm) 1x (55cm)
CPU 4+4 Pin 1x (60cm) 1x (60cm) 1x (60cm)
PCI-E 2.0
6+2 (8)Pin
2x (50cm) 2x (50cm) 4x (50cm)
SATA 7x 7x 7x
4P Molex 3x 3x 3x
FDD 1x 1x 1x
Pretty good connector selection, I’d like another Molex or two personally but I suspect most people won’t care.
Enough with the text, it’s picture time!
Photos Part One: The Box
The Front Of The Box, Underexposed
The Rear Of The Box, It Says "Capacitor"
The Rear Of The Box, It Says “Capacitor”
One End, With Chart
One End, With Chart
The Other End, Another Chart
One Side
One Side
The Other, Essentially Identical, Side
The box is a fairly unassuming and fairly small affair, not a whole lot going on. The rear does mention a Japanese Capacitor (no s), making me a bit concerned about the specs page and its “Japanese Capacitors” bragging point. The box is fairly informative however, which gains it points in its favor.
Photos Part Two: The PSU
The Box Opens To Deliver A PSU To Your Hands
The PSU, Delivered
The PSU, Delivered
The box is a minimalist affair inside, a couple partitions and a foamed bubble-bag are about all we get.
The PSU arrived looking happy enough though, so the box is apparently good enough.
Fan Side Closeup
Fan Side Closeup
A Label!
A Label!
One Side
One Side
The Other Side
The Other Side
Exhaust Grill, Switch, And Power Plug
The Output End Is Boring
Of note on the PSU itself are the fan grill (aerodynamically perfect and patented, mind you), the crackle/matte black/grey finish (looks good, feels good), and the flat cables. Peeking through the exhaust grill didn’t get me very far manufacturer wise, but it did point out that it’s a group regulated PSU. Also note the little loops under the wall power plug, that’s where the cord retainer clips on.
Photos Part Three: The Cables
ATX24P Cable, Ribbon Style
CPU Power Cable, Also Ribbon
PCIe Cables, More Ribbons
The SATA Cables Are Ribbons Too
Molex and FDD Cable, Also Ribbon
Accessory Pack, Not Ribbon
The cables really are all ribbon style cabling. To keep the ATX24P cable from getting out of hand Enermax used four sections of six pin ribbon, this gives it far greater flexibility than a single 24-pin ribbon or two 12-pin ribbons. Everything else is ribbon cable as well of course! The accessory pack is a bit limited, consisting of four paint gouging silver screws, one power cord (long!) and a power cord retention clip. One thing to note about the power cord is that it is a very tight fit in the PSU. This is excellent, but make sure you’ve gotten it all the way in. Being a tight fit makes the retainer of dubious use, but your mileage may vary on tightness and having the retainer is a nice touch. Usually you only see that on server class PSUs.
Load Testing Part One: Regulation
A decent load test of a PSU requires a decent load. Contrary to what some may believe, that means you need a known load that can fully stress the PSU. Computer hardware does not cut it. Worse, if the PSU fails during testing it might take out the computer hardware anyway. Commercial load testers cost a lot of money. I do not have a lot of money, so I built my own with juicy power resistors and a Toyota cylinder head. It works great. I’ll be using it to load this thing down fairly severely and will check voltages and ripple (more on that later) at various points. The down side to my tester is that the loads it can put on PSUs are fairly coarse, they go in increments of 48 W for 12 V, 50 W for 5 V and 22 W for 3.3V. Those wattages assume the PSU is putting out exactly the official rail voltage, a PSU putting out 12.24 V rather than 12 V will be at 49.9 W per step rather than 48 W. I file that under the “tough beans” category as I figure if a percent or two of load makes that much of a difference, the PSU manufacturer should have hit the voltage regulation more squarely. It does make calculating efficiency difficult at best.  However, given that the input power is read via a Kill-a-Watt, the efficiency numbers are dubious to begin with. Kill-a-Watts are not known for extreme accuracy on things with automatic power factor correction. For this reason, I am not listing the efficiency.
The ATX spec says that voltage regulation must be within 5% of the rail’s official designation, regardless of load. It doesn’t actually mention that the PSU shouldn’t explode, though I expect they figured it was implied. Exploding is a failure in my book regardless.
It is also worth knowing that I will be testing this PSU at both outdoor ambient temperatures (typically between 10 °C and 20 °C here this time of year) as well as in the Enclosure of Unreasonable Warmth. TEUW is a precision engineered enclosure that I use to route the exhaust air from the PSU right back into the intake fan, it is adjustable to hold the intake air temperature at (almost) any level I want it. This way I can test the PSU’s response to hot conditions as well as cold conditions. For the hot testing I will be running the intake temp as close to the unit’s maximum rated temperature as possible. TEUW, in case you’re curious, is a cardboard box. Sometimes a Styrofoam medical supply shipment cooler, if the unit is too efficient for the cardboard box.
Loads (total) 12 V Rail 5 V Rail 3.3 V Rail Kill-A-Watts Temps In/Out
0/0/0w (0w) 12.38  5.02  3.37  2  11/13
96/50/22w (168w)  12.28  5.02  3.34  199  11/15
240/50/22w (312w)  12.19  5.03  3.33  359  11/18
384/50/22w (456w)  12.10  5.04  3.33  522  11/23
576/50/22w (648w)  11.96  5.05  3.31  744  11/26
HIGH TEMPERATURE RESULTS BELOW:
576/50/22w (648w)  11.94  5.05  3.30  748  39/48
Definitely group regulated, but it did a decent job of things. On the 12 V side we have 3.68% regulation. While not epic that’s well inside the +/-5%, also well within the 5% total deviation I want to see. The 5 V rail has a rather impressive 0.6% regulation, making me wonder a bit about what the builders of this unit had in mind when they put this unit together. The 3.3 V rail runs a middle of the road 2.1%. Combined that gives us an average of 2.1%, not bad for a group regulated unit. Not epic either, but totally functional.
The fan makes a bit of noise at idle, at full load it definitely makes it presence known. The idle noise is a combination of airflow noise and ball bearing noise (not offensive in my opinion), at full load it’s almost entirely airflow.
Load Testing Part Two: Ripple
Ripple is fluctuation of the PSU’s output voltage caused by a variety of factors. It is pretty much impossible to have zero ripple in a SMPS computer power supply because of how a SMPS works, so the question is how much ripple is there? In the regulation testing phase we found out how the PSU does at keeping the average voltage at a set level, now we’re going to see what that voltage is doing on really short time frames. The ATX spec says that the 12 V rail cannot have more than 120 mV peak to peak ripple, the 5 V and 3.3 V rails need to stay under 50 mV.
If that isn’t complicated enough for you, there are three forms of ripple to keep track of as well. Long-term ripple from the PSU’s controller adjusting the output voltage and over/undershooting, correcting, overshooting, etc. Medium-term ripple from the voltage controller charging and discharging the inductor(s) and capacitor(s) that make up the VRM, and very short-term ripple caused by the switching itself. The first and second forms are the most important, if they are out of spec it can cause instability at best or damage in extreme situations. The very short-term (I call it transient ripple) flavor is less crucial, excessive amounts can still cause issues though it takes more of it to do so. The ATX spec does not differentiate, as far as the spec goes 121 mV of transient ripple is just as much of a failure as 121 mV of medium or long term ripple.
I test ripple in a few difference ways, first I test it during the cold load testing. It is tested at zero load and maximum load first. During the hot load testing I test the ripple at maximum load again. I have recently started testing ripple at fairly random loads with the unit still hot, it’s a bit unorthodox (a bit? maybe a lot) but has found issues in the past that did not show up with other test methods.
Zero load first, with cold ambients, all scope shots are at 10mV / 5ms.
12 V Ripple, cold, 10mV/5ms, ~10mV ripple
5 V Ripple, cold, 10mV/5ms, ~10mV ripple
3.3 V Ripple, cold, 10mV/5ms, ~12mV ripple
Not much to see here! The 5 V is weird looking, but everything is well within spec.
Full load, cold ambients:
12 V Ripple at Full Load, cold, 10mV/5ms, ~10mV ripple
12 V Ripple at Full Load, cold, 10mV/5ms, ~68mV ripple
5 V Ripple at Full Load, cold, 10mV/5ms, ~20mV ripple
3.3 V Ripple at Full Load, cold, 10mV/5ms, ~20mV ripple
Well within spec on all counts, the 12 V is a bit over half the maximum allowed while  5V and 3.3V are a bit under half. Good all the way around.
Lastly, full load and 39 °C ambients:
12 V Ripple at Full Load, cold, 10mV/5ms, ~64mV ripple
12 V Ripple at Full Load, Hot, 10mV/5ms, ~64mV ripple
5 V Ripple at Full Load, Hot, 10mV/5ms, ~21mV ripple
3.3 V Ripple at Full Load, Hot, 10mV/5ms, ~32mV ripple
When hot the 3.3 V rail picks up some transient spikes, but it’s still well within spec.
No issues in this section at all, though nothing amazing either. It looks like a pretty standard, properly designed, group regulated PSU. Solid ripple control.
Dissection
Disclaimer: Power supplies can have dangerous voltages inside them even after being unplugged, DO NOT OPEN POWER SUPPLIES. It’s just not a good idea. Opening a power supply and poking around inside could very well kill you. Don’t try this at home. Don’t try this at work. Just don’t do it.
Which is to say, do as I say, not as I do.
naxn-guts-overview
After scratching my head for a while trying to drag the name of this platform out of the depths of my brain I asked some fellow reviewers, CWT is the company of the moment for this unit. From this angle it looks like Teapo caps on the secondary and a Nippon Chemi-con on the primary. You’d be partially correct in that guess, the primary cap is indeed a Japanese Nippon Chemi-Con. The secondary side gets a mix of CapXon and Aishi, while the miscellaneous caps are Jun Fu. That’s one (1) Japanese capacitor, so much for the specs and features page. The box got it right though, so that’s something.
Fan Hub!
Fan Hub!
Transient Filter Part One
Transient Filter Part Two
APFC Overview, Looks Good
APFC (And PWM) Brainbox
APFC Diode
APFC Diode
One of Two Primary Switches
naxn-guts-APFC-Primary-switch
The transient filter has two X caps, four Y caps, three inductors, a fuse, and a TVS Diode. That’s one inductor beyond the minimum for a complete filter, so no issues here, I approve.
The APFC is headed by a CM6800TX APFC/PWM controller. No big surprise here as the CM6800 line being is most common by far in Bronze PSUs that I’ve seen. There are a pair of 20N60 (20Av 600V) MOSFETs doing the APFC switching and a 8S2TH06L (8A, 600V) diode to keep things going in the proper direction. Plus of course the NCC primary cap. Rounding things out is a thermistor for inrush protection. So far, this looks like a solid entry level unit.
Secondary Side Overview
One of Four 12 V Rectifiers
Secondary Caps By CapXon
Some Aishi Caps Too
Some Aishi Caps Too
5V and 3.3V Rectifiers
The Protections IC. OVP/UVP Only
The 12 V rail gets four 40V60CT (40A, 60V) schottkys, 5 V gets a single 30L45CT (30A, 45V), 3.3 V gets a single STPS60L30CW (60A, 30V). For those of you keeping track at home, both 5 V and 3.3 V rails are rated at 20 amps, which makes the huge difference in ratings a bit odd but not a problem by any means. Somewhat more concerning are the CapXon and Aishi capacitors, including some CapXons in Teapo colors. The Jun Fu caps are all on minor stuff, which is good as they’re not good caps. CapXon is about as low in the capacitor pile as I’m willing to go, Aishi I can’t find much information on. All three brands are Chinese. The protections IC only supports OVP/UVP, leaving the unit to rely on the CM6800TX for SCP, OCP, and SIP. It looks like SCP and OCP are essentially the same thing as far as the CM6800 is concerned. What SIP is I still don’t know.
Lastly, the soldering:
naxn-guts-soldering-overview
Main PCB soldering is quite good, no meaningful issues. The receptacle soldering is a different story however.
naxn-guts-soldering-issue
Flaked off solder mask in the lower left, incomplete heating/soldering on the lower right. That’s disappointing. The IC there discharges the capacitors when AC input is removed, it replaces the classic bleed resistors, gaining some efficiency.
Final Words and Conclusion
The basic premise offered by the NAXN ADV is good. The execution I find a bit frustrating.
The ribbon cables are great, they slot through small spaces easily and hide behind the motherboard tray quite easily. The ATX24P connector being ribbon cable is a New and Different thing that I like a lot. Having a standard cable for that and ribbon for everything else has always looked weird to my eye. Being all ribbon cables elevates the cable management capabilities of this PSU into the realm of modular units.
The price however is also in the realm of modular units. At the current price of $99 it costs about $20 more than most other 80+ Bronze 650 W non-modular PSUs. For that matter it’s about $10 more expensive than some 80+ Bronze modular PSUs. That puts the price for having ribbon type cables fairly high. Also important to note, some of those modular and non-modular units use Japanese capacitors throughout, rather than the mid to low bin Chinese capacitors in the NAXN ADV. $20 and capacitor quality is a bit much to give up for ribbons I think.
The looks are fantastic, I really like the finish, I really like the logos on the sides, I really like the ribbon cables, the fan guard looks cool too.
Other than the capacitors, the component choices are odd at times (massive 3.3 V rectifier!) but solid. The capacitors range from OK-ish through Jun Fu, which is another word for junk. To be fair the Jun Fu caps are scattered around the primary side doing relatively light duty, but Jun Fu is Jun Fu, and that’s still another word for “Junk Capacitor”. The CapXons on the secondary side are more reasonable, but a decent Chinese capacitor is still well short of a decent Taiwanese capacitor (Teapo, for instance), and well short of  Japanese capacitors. The Aishi caps I know little about, I’m unceremoniously lumping them in the same bin as the CapXons. Lastly (for caps, anyway) I find it mildly frightening that CapXon is imitating Teapo’s colors, usually companies aim a bit higher than that.
Regulation is best described as “good”. It’s not epic, it’s not bad, it’s not really worth spending much time talking about in either direction.
Ripple control is good as well, pretty much the same deal as the regulation.
The soldering on the main PCB is excellent. The soldering on the receptacle is not. It’s rather bad, really. The unit functioned like that, but I’m disappointed in Enermax and CWT.
The fan is typical for Yate Loon ball bearing bits, it has bearing noise at low speed (not a lot) and isn’t exactly quiet at full speed. Very typical of a unit in this general range.
The connector selection is good overall, four 6+2P PCIe plugs means you can run dual high end GPUs and the PSU can back that up with enough wattage as well. I’d like a couple more Molexes for my purposes.
Let’s summarize a bit and squeeze all the above into a few easy to digest bullet points!
There are pros:
  • All cables are ribbon cables!
  • Looks great.
  • Solid connector selection.
  • Ripple control and regulation well within spec.
There are cons too though:
  • Price is at least $20 too high for performance and capacitor selection.
  • Soldering issues on the receptacle.
  • Capacitors range from “vaguely decent” through “junk”.
At the bottom line, Enermax needs to either swap the caps out for Teapos (or better) or cut the price $20-$30 to make this a Really Good Buy. As it is you’re paying for those ribbon cables with both dubious capacitors and a significantly higher price than the competition. If the cables are worth it to you, it’s a perfectly functional PSU, but I’d wait for it to go on sale or for Enermax to kick the capacitor quality up a couple notches.
Despite absolutely loving the looks and the ribbon cables (even the main motherboard connector!), I feel that the cons are too hefty for an Approved badge. I don’t like paying an extra $20 for significantly lower quality capacitors, so today we have a meh.
Overclockers_clear_mehFor more about what exactly it means, click the meh.
Bobnova
Leave a Reply
Discussion
  1. Go read the MAXREVO 1500W review.
    That PSU is nothing short of glorious.
    I have a Platimax 1350 I'm reviewing right now, it's even MORE glorious.
    The trick is, you have to buy an Enermax unit that is actually made by Enermax. They don't know how to make a cheap PSU, so they farm 'em out.
    The Enermax-built stuff is hard core.
    Personally I think all Enermax stuff is just "Meh", I have fans from them that are garbage that wouldn't cool my old 960 system for CRAP, and there were 3of them in it.
    The fact their PSUs keep getting mehs are just confirmation
    Not at all. You can find Gold and even Platinum units with junk parts/capacitors.
    The efficiency rating has absolutely nothing to do with quality, unfortunately.
    A nice review but I admit that I don't get why people would even want to buy anything less than gold certified PSU, higher efficiency almost grantees better parts and less chance of failure.
    Extra $20-40 bucks is totally worth it from my point of view.
    I agree with you. I paid ~40$ each of my 450w NAXN. When deals are good, you can have an HX650 at just a few bucks over 100$... newegg.ca currently have the newer HX850 at 150$.
    Edit : And AX750 can be found at ~125$. HX650 sometimes ~110-120$.
    I don't really know how closely related they are, though I can easily see this NAXN ADV lasting that long without issue. If you can find this thing on sale for a good price (read: $65-75) it'd be great. At $100 I expect better caps.
    Thanks for the review !
    I own 2 of the 450w "normal" NAXN. One on my HTPC and one on my mother PC running a 3870k/A75. They are decent PSU, the mother one run for ~1yr now but she alwais sleep the PC. I dont live with her be she never complained about noise or anything else. My HTPC is at least 2 yrs old and 24/7 run time.
